i-Vtec to "Real" Vtec? What does this require?
Old Jun 29, 2013 | 09:31 AM
Spooner15's Avatar
Default i-Vtec to "Real" Vtec? What does this require?
So i bought a base model 2002 Honda Integra with a K20A3, i-Vtec. It's a fun car that is a lot of fun to drive. What i'm looking into doing is getting "real" Vtec out of it without doing a engine swap. Is it possible to swap the head, Do I have the right idea here or am I way out in left field? I'm good with cars but not too knowledgable with the Honda motors yet.
So my first question is this even possible?
My second question is what is required to do something like this if this is possible?
Old Jun 29, 2013 | 09:56 AM
Orangevirus1's Avatar
Default Re: i-Vtec to "Real" Vtec? What does this require?
You can just swap the V-tec's.
Old Jun 29, 2013 | 10:21 AM
Spooner15's Avatar
Well, that's 1 sarcastic, completely useless post.
Thanks AssHat!
Old Jun 29, 2013 | 10:30 AM
Thanks AssHat!
No problem!
I-Vtec and "real" Vtec are nearly the same.
except I-vtec is even better, because it controls all outputs of cam timing, not just switched modes.
what makes you think I-Vtec is Fake Vtec?
you're not in Left field, you're not in right field, you're not even on this planet anymore...
know where I found that information?
The very first link on google.
Asshat!
Old Jun 29, 2013 | 10:36 AM
doood's Avatar
been there done that
No problem!
Asshat!
OP is using the wrong terminology. but you're just an idiot.
know where i found that information?
all your posts to date. please dont try to sound intelligent because it's obvious you're not.
Old Jun 29, 2013 | 10:39 AM
I wasn't trying to sound intelligent. I pretty much copied something I found onlline verbatim
Old Jun 29, 2013 | 10:43 AM
doood's Avatar
well then, maybe you should copy the part about how the k20a3 only has 2 lobe vtec on the intake cam that's primary focus is fuel economy and not the traditional 3 lobe vtec on both cams.
Old Jun 29, 2013 | 10:50 AM
Spooner15's Avatar
Proving my point. But hey, by all means, thanks for taking a whack at it.
To move on with things:
I realize that i-Vtec is not "Fake" Vtec, But it is not "True" Vtec as most know it. There is a reason I put these terms in quotes. i-Vtec combines traditional Vtec with VTC (Variable Timing Control). I personally enjoy the "Kick" that "traditional" Vtec offers. I knew going into the purchase of the car that i-Vtec was not what I was looking for. Which brings us to this thread.
Old Jun 29, 2013 | 10:52 AM
Spooner15's Avatar
*Applause*
Old Jun 29, 2013 | 10:58 AM
doood's Avatar
i-vtec is still true vtec. your engine just doesnt have it.
Spooner15's Avatar
The research that I have done, I have gathered that it is possible, with a K20A2 Head, and a Kpro. But is doing this swap advisable?
Old Jun 29, 2013 | 11:00 AM
Spooner15's Avatar
Ok, Honestly still learning here but that makes sense. As you said before, I am using the wrong terminology. I did my best to approach this the best way I could.
Old Jun 29, 2013 | 11:23 AM
doood's Avatar
think of what you have as an updated version of vtec-e found on the older d series. i personally wouldnt do the head swap because the cost to power ratio is ridiculous.
Old Jul 6, 2013 | 04:10 PM
brettnahmann's Avatar
OP, your engine does have i-vtec. like said previously, it doesnt "kick" like a b-series vtec would only because its the a3. the k20a2 or k20z1/3 have i-vtec and definitely kick. unless you spend big money, your k20a3 won't get it.
my advice: save your money for a k20a2 (rsx-s) or a k24 . use your car as a daily while you save up because it has the same torque (give or take a few ft/lbs) as your better k series engines. but to throw money (atleast to get 50+ hp) at a k20a3 is a waste because unless you upgrade many parts to it, it wont be much faster than one of those motors.
Old Aug 1, 2013 | 01:21 AM
onetimelife's Avatar
Thanks AssHat!
yes it was..
Old Aug 1, 2013 | 04:14 AM
yusenglor's Avatar
K20A3s are garbage to build.
Justin9891
Honda Civic (2001 - 2005)
Jul 3, 2018 11:10 PM
l Love JDM
23
Jan 29, 2012 08:49 AM
panchlow
10
Aug 15, 2010 03:28 PM
GSteggy153
Apr 8, 2010 12:29 PM
B18Redline
Sep 27, 2002 03:13 PM
