- Electric RSX
- EP3 Steering Column Questions
- Need Help
- 5 speed accord transmission in 02 rsx type s
- Ep3 trans into Rsx type s
- 2025 Acura ADX
- Can you fit Honda Hx wheels on a 03 EP3 si?
- EP3 front wiper arm compatibility
- rk07 bbn injectors
- 2026 Acura RSX
- EP3 not going into 4th gear
- progress cs3 on ep3?
- 2003 SIR EP3 Clutch repair
- Transmission Part #
- Coilover issues 2003 Adcura RSX type s
- 20 PSI Fuel Pressure
- k20z1?
- Honda Integra Type S Cluster!!!
- 2005 JDM EP3 Exhaust
- 17x8.5 +30 Pic request
- High Idle and Rough crank?
- aftermarket oil pan on k20a3
- Unboxing of PCI's New Rear Upper Control Arm
- What DC5 Type S parts can I put on my Base model DC5?
- EP3 si exterior fuse box the same as other models?
- Civic EP3 A/C compressor does not work
- Any good shops for turbo install in arizona
- Acura rsx issues
- help acura rsx limp mode
- Skunk2 ultra street manifold
- What is my car worth?
- Help with ep3 transmission
- 45 minutes of driving and then the engine quits!
- Door lock issues after break in
- Need your help - 02-04 vs. 05-06 Type S
- not lowering EP3 but bought the stuff
- K20A3 Jackson Racing Supercharger Rebuild?
- Ep3 replacing engine mounts
- EP3 floor panel heatshield help!
- Building EP3 in 2024
- I need the SAE DOT number from the facelift headlights
- Rear fog light wiring question
- Questions about rsx-S I’m looking to buy
- 2003 Civic Si (EP3): Recommendations for good Honda mechanics in Michigan?
- Code P1077 and P0166
- Are They Compatible?
- EP3 Hatch Won't Open!
- 3rd gear grind :((((
- Suspension compatibility dc5 and cl7/9
- car wont turn over.
- Turbo Kit for RSX
- Clutch kit Recommendations
- WILL DC5 RAD SUPPORT FIT IN EP3?
- Has anyone tried the single piston 96 Rl caliper upgrade?
- DC5 Tein Coilovers
- EP3 Transmission Conversion/Build
- Electronic Load Detector (ELD)
- Signal lights don’t work but Hazard lights do!!
- I need help identifiying a 2006 rsx base tranny.
- 05 Si hatchback misfires
- Just got new adjustable RUCAs
- Daily driver suspension for EP3
- Identify - EP3 Front Lip
- GTX3076 1.01 AR ON STOCK Κ20
- Intermittent bumping? at 60mph+
- EP3 Camber Kit
- Rim Offset Issue
- 2002 Acura RSX type s high rpm 6K<
- DC5 Type R Electrical Problem
- Top Secret Tuning RSX
- Need help figuring out why my car is running too rich p0172 code
- EP3 condenser fan?
- RSX Auto to manual swap question…
- 2006 RSX type S Kpro Dyno Run
- upstream o2 sensor wiring harness side help
- 2002 Civic Si Ep3 hatchback front end radiator fix
- Honda ep3 intermittent no start when hot
- Lock button on key fob doesn’t work
- Problem with EP3 doesnt drive like its suppose to
- Am I running too lean? AFR: 15.3-7 ish at idle
- Rsx god speed coilovers
- EP3 upgrade to Rsx Type S brake system assistance on products
- Base rsx
- Type R front end conversion to USDM EP3
- Fuel Level Sending wire (No Ouput)
- '02 EP3 replace coolant overflow tank
- Can somebody educate me on how the EP3 and the DC5 are related?
- Replacing ignition cylinder
- Need assistance
- DC5 Budget LSD
- Airbag maintenance? How do we keep our cars safe?
- Rsx base circle track racing HELP
- starting issues? EP3
- I have Acura 2003 rsx my windows drover and passenger broke out are thier compatible
- 2004 Honda Civic SE 1.4 Hatchback - Single Beam to Dual Beam
- Test Driving a 04 si need ideas of what to look for
- EP3 Si - Hatch/trunk lid fitment compatibility USDM/NADM w/ EDM or JDM
- 2 issues 04 Si
- Correct rim size for a 2003 EP3
- transmission bracket compatability?
- Bad Hood or Bent Frame?
- Whats the ep3 si stockrev limiter
- 2002 si p1166
- 03 RSX Type S readiness monitors.
- Need help with calibrating tps sensor
- K24/dc5 type r 6 speed into 5th gen prelude
- RSX Header that will clear K24 Swap
- Have 02 base At .with 05 k20z1 and 6 speed
- 2002 Honda Civic Si - Engine rotation direction
- Water leak in the trunk of a 2002 Civic SI
- Finding original DCR5 Springs - Help!
- Transmission problem
- Base RSX k24 Swap vs Type S
- RSX swap options
- 2003 Acura RSX Sport value?
- Ep3 2002 alarm issue 😑
- A little help with rear sway question please....
- 05 Integra DC5 Air Fuel Ratio Sensor
- Do sway bars make a difference
- Es to Dc5 type R JDM Conversion help
- 2003 Civic Si raise to stock height?
- Which Ep2 mods can carry over to Ep3?
- Headlight wiring diagram/harness
- Can I put 13” steelies on my ep3?
- CEL p1454
- 02 rsx type s stutters
- Good clutch for 500hp 400ft lbs
- 04 rsx base w auto trans. I need to know what pin to jump for ny vss
- RSX base or Type S K24A2
- Manual to Automatic
- p0341
- L15b7 swap in honda civic eu1
- ep3 w- six speed lsd pass clunk half shaft?
- 02 Si occasionally won’t start after a drive?
- Weird Steering Pull 2005 EP3
- RSX-S Part-Out: What Has value?
- Type r vs type s subframe different part #
- Need help with CEL codes
- 2002 RSX Type-S Power Steering Whine, Heavy Feel, Steering Wheel Vibration When Warm
- RSX WONT START REMOVE ENGINE
- 2004 EP3
- 02 EP3 SI brake light & battery lights on dash.
- Swapping into chevy vega
- will a 2005 manual 6 speed fit a 2004 type s
- 03 Civic Si SRS light on, no code?
- 2004 Civic EP1 - Heating temperature regulator does not work
- Bizarre AC Problem - Worked fine then when turned off low side shot up to 350 PSI
- Questions, about the MK7 Honda Civic SI (2005)
- EP3 won't start, broken plastic on carpet
- 2004 honda civic si idle problems
- RSX HELP(not a car head would like to be)
- Ep3 Type r Power Loss Help!
- dc5 type R 2005
- 02 rsx type s
- 02 Acura rsx k20a3 after stage 2 clutch replacement will not go in reverse
- COmpatibility: K24 accord gears in RSX base transmission
- 2002 Acura rsx DC5
- Dash kit won’t fit!!!!
- New injectors/ Hondata K-pro
- what ecu do i need?
- 04 base rsx
- Gen 2 TSX Injectors
- Ep3 p1259
- Xtra HP for a 2004 Civic Si
- No Alram No Stereo Working
- Ep3
- Fans issues
- Steering feels weird after DC5R wheels put on
- new, looking for info on wheel fitment
- Help!
- K24 swap without K pro
- RSX-S engine replacement
- Doing a k24/k20 swap have a few questions
- Ep3 issue to really make you think
- P1259 nightmare!! 04 rsx base
- Ep3 we just finished up, dyno results
- 02 Civic si p0325 knock sensor help
- TRANSMISSION LEAK...what should i do ...
- Ep3 HFP front spoiler
- P2229 barometric pressure sensor error
- weird rattle
- EP3 Transmission Compatible Housings
- Type S 6 to 5 spd PPG gears
- K20a2 piston to valve clearance
- 2002 Civic SI - Seat fabric
- Tokico Shocks
- RSX newbie, some problems
- 02 civic si... what the heck is going on??
- Aftermarket Gauges
- 02 RSX Type S Injector Identification
- Fitting cruise control in Euro EP3 Type R
- Weird RSX problem, won’t go over 1500 when floored
- Hydraulic Issue or Clutch Itself? Clueless.
- K24 swapping my ep3
- K20 help!
- Ep3 what is this and what does it mean??HELP!!
- Help I changed my wire harness and now my car won't start
- Please help! Can’t rev past 4000
- Acura rsx type s acceleration issues
- Need help with a k24 into a 2005 rsx wats all needed
- New built
- K24 Mods
- To upgrade inner tie rods or not?
- K20_K24 how CKP, CMP and TDC count.
- Turbo EP3 pulling left and right under acceleration issue
- What is this?
- Question about the connectors in 2005 type S
- 2004 JDM Honda Civic XS 5 Dr Hatchback
- Advice for my RSX rebuild
- Change stereo
- DC5 VSS code
- Acura RSX stalling
- Theft recovered 05 type S- need ECU, immobilizer, key help
- DC5 overheating
- Rsx type s
- Heating problem Civic 2003 1.4 Hatchback
- Power issues FROM HELL
- Ep1 K20A2 swap
- Bleeding Slave...No fluid?
- 2002 honda civic hatchback 5door RHD
- RSX - Is there a trick to reinstalling the A/C expansion valve/heater box side cover?
- Start problems on '04 RSX base - flummoxed!!
- 2006 Acura rsx type s tuner
- Unbelievably Loud Exhaust
- Spoon N1 Silencer
- 03 EP3 Swap Recommendations
- 2002 base RSX brakes onto 2003 ep3
- K20/k24 swap into Rsx type S
- EP3 Stock Ride Height Measurement (Fender to Center of Hub)
- EP3 Battery Re-location and Catch Can install
- How often do A/C expansion valves go bad?
- Civic ep3 help suspension
- 2004 Civic Si EP3 Battery Relocation
- Acura RSX base Automatic transmission issues
- Help! EP3 Electrical Issues!
- Ktuned HALL effect TPS, P0123 high voltage
- EP3 K24A2 with horrible vibration/harmonics issue
- clutch replacement, replace oem or aftermarket?
- I'm trying to buy parts for a Honda CR-V 2002 RD4 japanese specification from the UK
- Wrx seats in dc5
- RSX K20A3 Timing Chain Tensioner Reset?
- 2004 civic si barn find 48k miles
- Honda civic limp mode/dies when I stop.
- 05 Civic SI EP3 engine with rod knock
- Thoughts on ep3 engine tick
- Vtec bypass?
- Vacuum hose seal up?
- 04 civic si hatchback master cylinder missing screw
- DC5 ECU Problem and how to buy ECU chip
- Pulling an EPS controller from an EP3
