EP3 Problems
Old Sep 5, 2013 | 11:56 AM
VTEP's Avatar
Default EP3 Problems
Hey guys.. I have a bit of a problem. I have a K20A2 EP3 and I recently installed a JRSC with 650 injectors. After 4 days of running well the car started to have two symptoms . The car only starts if it’s a cold start, if I start it and wait 5-10 minutes and turn it off and then on again it won’t start….only if I wait 15-20 minutes. The second problem is that the car idle surges between 1000 and 2000 RPM. If I unplug the water temp sensor the car starts with no problem. I ordered a new water temp sensor hoping that this will solve the problem. What am I missing ? Thanks in advance.
Old Sep 6, 2013 | 12:20 AM
VTEP's Avatar
Default Re: EP3 Problems
P.S.
There is not check engine light on , and the temp stays normal. These are the only symptoms. Beside this the car runs fine.
I changed the water temp sensor today and i have the same problems.
Old Sep 6, 2013 | 02:04 PM
nahonda04's Avatar
Surje.motorsports
i am assuming you have kpro and you are tuned?
Old Sep 6, 2013 | 09:20 PM
VTEP's Avatar
Yes
anthonye77
May 21, 2013 08:21 PM
KayTran
Dec 16, 2008 12:06 PM
Pilot05
Sep 15, 2006 03:44 PM
streetracerof06
Dec 7, 2005 10:01 PM
jabenne
Apr 4, 2002 05:50 PM
