Honda Civic Si 2002 P0420 Code HELP!!
Old Mar 28, 2013 | 07:25 AM
armydrivera's Avatar
Default Honda Civic Si 2002 P0420 Code HELP!!
P0420
Catalyst System efficiency below threshold
I bought the car with this check engine light and its been hell i changed the full exsaust an aftermarket one and replace it and the person i bought from said he put new sensors in and that wasnt the problem. What do i do whats the problem? i have seeing this check engine light and want to see it gone.
Old Mar 28, 2013 | 09:05 AM
Default Re: Honda Civic Si 2002 P0420 Code HELP!!
BUMP
Old Mar 28, 2013 | 10:37 AM
SickSi99's Avatar
Catalytic Converter may need to be replaced.
Old Mar 28, 2013 | 11:27 AM
Should I get an OEM cat is that the problem you think?
Old Mar 28, 2013 | 11:30 AM
SickSi99's Avatar
You can't go wrong with OEM.
Old Mar 28, 2013 | 12:58 PM
johnsonuy's Avatar
I have the same issue. You're going to pay at least a stack + if you go brand new oem. And it'll be a headache looking for a used one with little mileage. I'm going with a magnaflow direct fit 49 state just to get rid of the error + bolting on the heat shield to cover it up to pass smog.
Good luck to you
Old Mar 28, 2013 | 03:14 PM
mizle's Avatar
yeah thats what i would do if i had that code, and im sure it will pass smog with the mangnaflow as well. the o2 sensors are working because they are reading the efficiency of the chemical reaction. If an o2 sensor was bad it would more they likely be the downstream and have a totally different code.
Old Mar 28, 2013 | 03:36 PM
So the aftermarket for the Si's aren't good? Will that catalytic work on the aftermarket exhaust system I have ? I don't need to replace whole thing right ?
Old Mar 28, 2013 | 03:43 PM
How much are you spending on all that?
Old Mar 28, 2013 | 07:37 PM
mizle's Avatar
i was just sayn "if" i had that code thats what i would do. Buy the mangnaflow cat. better air flow and still legal i believe.
Old Apr 1, 2013 | 09:46 AM
lsturbo*'s Avatar
http://forums.clubrsx.com/showthread...=842256&page=2
I have heard aftermarket catalytic converters can be he'll.
Also aftermarket o2 sensors can be problematic
You need an OEM cat at a minimum, then if the code still appears, replace the rear o2 sensor, then if needed the front A/F o2 sensor.
Note the last post in my attached link is an OEM cat for sale.
Old Apr 8, 2013 | 04:53 PM
T_Virus's Avatar
or if you don't care about emissions, it is time for you to get a "RACE HEADER!!!"
Old Apr 8, 2013 | 11:47 PM
BONTY_EP3's Avatar
Yea, you're going to have to replace the cat. If you don't care about replacing it and the check engine light bugs you, get a defouler.
josephlety
Honda Civic (2001 - 2005)
10
Jul 7, 2010 09:15 AM
soMedic
Jul 27, 2006 08:08 AM
vega_ROCKS
Jun 25, 2005 01:12 AM
