Ep1 - Few Electrical Problems - ANY Help Is Appreciated!
Hi Chaps, How are we all today?
Been waiting for answers on others forum for a while and been told that this is the place to be so here it goes. Got an EP1, had problems with the ABS, so fixed all that but when I got it theres loads of other faults I wasn't informed about, now I still got it at a price that is stupidly low, so don't mind really, if I list the faults is someone able to try help me rectify them? I will fire away! Any help on any topic is appreciated!
1.Central Lockin - Nothing works when the ignition is off? No remotes (the have new batteries) unlock from drivers door and it does that door only? However if I stick ignition to position 2 and flip the switch on the drivers door I can lock and unlock all doors and boot, but the remote fobs still don't work. THINk I've checked all the right fuses, any ideas on relays? What else to check? Ironically my interior lights don't work and there was no CD player? Possibly linked?
2.Passengers Windows - As if it's got now power? Checked 10A fuse on the drivers side, doesn't work from any of the window controls? This door looks as well like it has been de-locked as there is no barrel this side? I have the barrel and wire? Maybe connect this back up? and see what happens?
3.Heaters - Again another power issue, turn them on any settings and I get nothing, will soldering a 1ohm resistor to the transistor fix this?
Thanks in advance really hope someone can help with any of the above!
Appreciated
Simon
Appreciated
Simon
Appreciated
Simon
Appreciated
Simon
MoonSha
Nov 20, 2004 09:15 AM
