Ep3 issues- wont idle smooth and dies at wot
Old Jun 13, 2013 | 12:26 PM
77highboy's Avatar
Default Ep3 issues- wont idle smooth and dies at wot
Just swapped the motor from a base rsx. I kept the ep3 intake. The compression is good on all cylinders. It won't idle/run smooth and will bog out at wot. No cel. Just put new plugs in it. It has good power under a load until you hit wot then it dies. Does anyone have anything I should check out to fix the issue?
Thanks,
Ken
Old Jun 13, 2013 | 08:17 PM
Gtimportfanatic's Avatar
Default Re: Ep3 issues- wont idle smooth and dies at wot
did you keep the same throttle body that the car used when it ran ok?
Old Jun 13, 2013 | 08:36 PM
77highboy's Avatar
Yes. After searching for hours and double checking for vacuum leaks and wire connectors. I think it may be that one of the guys helping me put the defouler on the primary o2 sensor instead of the secondary. It's acting like its dumping fuel.
Old Jun 14, 2013 | 01:12 PM
77highboy's Avatar
Took the defouler off the primary and reset the ecu and still the same troubles.
Old Jun 17, 2013 | 05:43 PM
77highboy's Avatar
Does anyone have any ideas?
Old Jun 17, 2013 | 11:01 PM
with no dtc showing up that's def weird. does your check engine light show up when u turn the key? just to make sure
Old Jun 21, 2013 | 04:16 PM
77highboy's Avatar
The light comes on when I turn my key on. It was throwing a code for the primary o2 sensor so I bought a new and and it runs a little better but not like it should. Still dies when you mash the pedal.
chris d
Sep 10, 2015 03:35 PM
92d15b7
Mar 30, 2011 06:01 AM
vtecgsr98
Apr 2, 2005 01:24 PM
GOTNOS
Nov 22, 2004 03:19 PM
drunk
Dec 29, 2002 11:43 PM
