PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. Koni & GC
  2. help in picking a muffler
  3. I'm sure I did something wrong?? need knowledgeable rsx person
  4. Clutch going out?
  5. Im back! DC5 bearing ?'s
  6. ep3 brakes and turbo help
  7. New car: Check engine light from lower-octane fuel?
  8. Selling my '05 RSX Type-S, how much should I ask for it?
  9. Getting a new key for an 03 RSX Type-S
  10. EP3 oil leak and some CELs....
  11. Type R EP3 Seats
  12. aem v2
  13. Acura Rsx Type S Noob question?
  14. Timing troubles...KPRO??
  15. Intakes?
  16. Power Steering info!
  17. 03 RSX ac problem
  18. ep3 o2 sensor for 05+ rsx type s? will it work?
  19. Tire size for my ep3!(wheel details)
  20. 04 ep3 new stereo problem question
  21. How much would it cost to fix synchro on 02 type s
  22. Whats the difference between the shells/chassis of a DC5 Type s and base model?
  23. servicing help
  24. 2005 Civic SI P0135 code
  25. 2005 Civic SI P0135 error code
  26. k20a3 anybody know of any piggybacks?
  27. HELP! Misfiring and Check engine light on again
  28. EP3 overheating
  29. 05 SI not starting
  30. HFP lip kit......Group buy from Honda??
  31. kouple questions k24a2 build
  32. DC5 Type S - 'D' flashin on cluster
  33. 02 Civic Si...now what?
  34. tdo4hl turbo in a k20a3?
  35. Need advice - EP3 Civic is pulling left (tyre / steering issue)
  36. 03 si bumper questions.
  37. I'm having problems with my ep3!!!!
  38. apexi vs greddy exhaust
  39. k20a3 cam wore into cam cap and holder
  40. Civic EP1 dashlight issue
  41. SI Aftermarket Altenator Install HELP!!
  42. ep3: lights not flashing when using remote
  43. 04 ep3 burning oil question
  44. Drive safe
  45. can i directly swap a k20a3 from an RSX into my 02 SI?
  46. Stock exhaust vs. Megan Racing
  47. quick cam and camshaft question...
  48. daily driver cams and camshaft?
  49. A2 motor with z1 ecu?
  50. Cheapest shocks?
  51. Anyone purchase a Ep3 HFP lip kit new, somewhat recently?
  52. 2006 TYPE-S STOLEN WEST ORANGE NJ :(
  53. Questions
  54. Advice on DC5 Purchase:04 vs 05
  55. HELP!! compression tester stuck in plug threads
  56. K24A4 Intake Manifold RBC?
  57. hello i have got honda civic 2002 steering rack problem
  58. Honda civic 2001 1.6 5dr Gear shifting issues.
  59. 04 ep3 si burning alot of oil
  60. Odometer issues
  61. DC race header
  62. Batery relocation in the TRUNK on a dc5 or ep3 , can you post some pictures .
  63. Starting problem clicking noise
  64. Spark Noise nears ABS/Valve Cover
  65. Constest help
  66. k24/20 swap In a 05 rsx-s
  67. Need electrical help!
  68. What happened to my transmission?
  69. which is better
  70. exhaust brands
  71. Mugen bumper on an 02 dc5?
  72. Quick question on head unit wiring on EP3
  73. What should I do with my RSX interior? I have the money...
  74. DC5 R susp on civic EM2! Difficult to do?
  75. tanabe products, need opinions
  76. 04 civic si ep3, what should i do next
  77. will 99-00 si's fit on ep3
  78. Quick clutch compatability question?
  79. 67-01 CODE
  80. Rsx or dc5 brake reservoir tank on ep3?
  81. Titanium Nitride Coated Headers
  82. honda civic si ep3 04 exhaust question
  83. New clutch problem. gears grinding! please help.
  84. Just did oil change - dripping from filter and plug (yeah, haha noob!)
  85. Having problems with stock CD player...
  86. 2004 civic si disc changer
  87. my initial impressions with a 5.0FD and other goodies
  88. looking for ep3 carb legal headers
  89. 03 Civic Si, 4k rpm power crap-out
  90. Engine Knock
  91. RSX type s (02-04) vs (05+) coilover fitment?
  92. 2003 civic si wheel size?
  93. Civic fuel filter issue
  94. Couple questions about tuning an 04 SI w/ k24 block
  95. Type R wing
  96. Exhaust
  97. intake manifolds
  98. Auto Climate Control Swap to EP3
  99. Help help prc type r ecu install into rsx type s please
  100. ep3 bouncing off limiter
  101. Transmission Fluid
  102. alarm doesn´t work after radio install
  103. EM2 with K20a3 Swap Unsolvable CEL P1167
  104. Reving at 7200rpm which it suppose to be 7900rpm
  105. K20 throw body differences?
  106. help with my exterior
  107. Lowering my 02 type s
  108. Ep3 Carbon Fiber Cargo Cover.
  109. rsx radio no sound
  110. type s seats
  111. RSX RADIO CODE DILEMA NEED HELP ! Please !
  112. shocks/struts/springs help
  113. Good size rims for EP3's
  114. EP3 Lock Problem (Unlocks and immediately relocks itself)
  115. ep3 bumper kit
  116. Ep3 EPS differences?
  117. High pitched whine, other issues...
  118. 100% OEM suspension issue. Ideas?
  119. Bearings
  120. bad turn signals
  121. lower seats
  122. Ebay lowering springs
  123. K24a4 swap into ep3
  124. 02 rsx engine removal help
  125. ep3 service recalls?
  126. Looking for 05 RSX-s Service Manual
  127. Acura RSX Type S k24 swap question?
  128. K20a2 Possibility of clutch installed backwards?
  129. door lock question
  130. EP3 Facelift city lights
  131. '02 RSX-S Minor Clutch Slippage
  132. need help with conserns about rhd conversion
  133. Aftermarket EP3 Fenders Quality/Fitment
  134. Where is the PGM-FI relay located on a DC5?
  135. rebuilding my buddies k20
  136. tire sizing on ep3
  137. Turbo kit for EP3?
  138. Previous owner... Massive front Sway bar
  139. Quick exhaust question (b-pipe?)
  140. rsx rype s wiring ecu wiring
  141. My DC5 make over!
  142. Installing type r spoiler
  143. Window molding trim?
  144. Throwing a code for HO2s
  145. Authentic JDM DC5 Emblems?
  146. ITR Brembo Seals
  147. 02 type-s vtec not engaging all the time
  148. Buying an Ep3 Need help again!!
  149. Ordered supercharger.. and I want to make sure I get the right accompanying parts.
  150. help!!! timing chain
  151. Ep3 carbon-fiber spoiler decision help!
  152. MY DC5
  153. K20 Spark Plugs... Anyone using NGK V powers?
  154. RSX C pillar bar question
  155. Easiest way to adjust coilovers.
  156. EP3 motor needed...suggestions
  157. Wheel fitment issue.
  158. 05 rsx type s turbo info
  159. Wiring harness issue
  160. newbie idk if this is the right place for my question
  161. Motor Mounts EP3
  162. Ep3 suspension
  163. where can i srart with this? weird issue
  164. K20a3 motor K20a2 trans
  165. need advice on an ep3 purchase
  166. Ep3 Engine suggestion
  167. Ready to toss my $9k for a 06 RSX premium, BUT.....
  168. TPS cuts out at full throttle
  169. i need help with exhaust
  170. Raising vehicle back up?
  171. any RSX's come with black interior color ?
  172. Boosting an ep3
  173. 04 ep3 shakes when reach 40mph
  174. 05 RSX or 06 Si?
  175. RSX seats kill my back
  176. Idle issue on 2002 Rsx base model after o2 change
  177. k20z1 hondata base map help
  178. How are the ep3's????
  179. Loud valves k20a3
  180. tpms on wheels?
  181. 02 RSX Base K20a3 Valve Lash Specs
  182. RSX; Heater doesn't work
  183. EP3 misfire
  184. The common window issue...need to know what to buy
  185. JDM Honda Civic EP3
  186. EP3: Got new headunit and 6.5" speakers. What else do i need to install?
  187. ep3 help
  188. Replacing Trailing arms EP3
  189. EP3 Type-R K20A2 slight hesitation when warm
  190. Ep3 heat??? help!!!
  191. Finally buying a Type S after 3 years of saving, have a few questions for owners.
  192. 02si vtec problem
  193. 02 civic si vtec problem
  194. What Kit would you choose?
  195. Top Reasons Why a Clutch Burns
  196. Just Replaced my Clutch: 2002 DC5-S
  197. K series head casting identification
  198. 2002 RSX Type S
  199. Knocking / ticking noises
  200. Need help with RSX Starter or Altenator?
  201. 02 ep3 si mantince req light does not go out
  202. 150,xxx miles this engine good??
  203. Can 2 car seats and my 11 daughter, fit in the rear seats of a Ep3?
  204. Rolled over RSX
  205. cracked clutch case question
  206. Replacing Cat in Cali + CEL P0420
  207. RSX battery drainage
  208. HELP, 2002 RSX ELD?
  209. Honda Civic Si at Presentation of Mary Video
  210. Massive Oil Consumption...HELP
  211. 2002 Acura Rsx won't start!!
  212. k20a3 clutch and flywheel to k20a question
  213. Acura Rsx Base A/C compressor noise???
  214. Will DC5 Type-R stock suspension fit my 2002 base model?
  215. Ep3 air blowing out of wrong vents?
  216. 05 RSX-S with A3 swap? Wtf! :/
  217. rsx start up problem
  218. dc5r stock resonator & pipings
  219. Bumper and headlight conversion?
  220. Koni yellow with aspec springs rsx?
  221. Clutch issue?
  222. JDM steering wheel.
  223. Skunk2 and 18s
  224. Need Advice For DC5 Suspension
  225. help weird ep3 ac noise!! video inside!
  226. Advice needed: RSX-R vs 05-06 front
  227. should i get an ep3
  228. installing koni yellows on an EP3
  229. Always Blowing Air DC5
  230. finding Rsx-s seats
  231. The Official Q1 2012 EP3/DC5 WTB/WTT/FS Thread!
  232. K24 turbo won't fire up
  233. Need Help ASAP on rotors please read!!!
  234. Please Help!!!
  235. Help... Can't start 53plate type r
  236. jdm K20A swapped into type s, problems. Ideas?
  237. FOR SALE RSX & EP3 parts
  238. is it a good idea to replace a pass. side engine mount with a hasport one?
  239. Clutch could be bad but not sure? Any thoughts or help
  240. Coilovers? I need hepl deciding
  241. flywheel love
  242. having issues hooking up kaypro
  243. 03 Rsx type-s JDM engine
  244. whats the choice??
  245. dc5 type R into dc5 type s
  246. Soon to be ep3 owner.
  247. boost cut
  248. 03 RSX-S VTEC malfunction
  249. EP3 lowering springs
  250. spark plug broke inside ep3
