- Front suspension, what are the weak points?
- EP3 Cluster Brightness
- Wrecked RSX ideas
- just got a turbo ep3
- Quick Mid pipe question
- Possible Brake Problem?
- Help with theft recovery repair
- tires, yoko s-drive vs. nitto motivo
- Joining wires of the replaced Frontside left Passenger door
- 2006 rsx base and 05 civic si turbo questions
- My brothers new best!!
- The Official 2014 EP3DC5 WTB/WTT/FS Thread
- Honda Civic 1.7 Diesel 2003 UK
- CLUTCH MASTER CYLINDER problem
- Ep3 Extended Wheel Studs...What studs to use?
- 04 accord trans k24 work in a 04 civic si with a k24
- Hybrid Racing Shifter Assembly for RSX!
- Throttle body spacer
- What did I get myself into? 2005 Si HFP
- Putting a jdm motor in my base rsx
- TPS vs MAP
- 2002 Honda Civic Si Hatchback Issues shifting gears
- A-Spec Part numbers for an EP3
- Secondary o2 Sensor use for narrowband A/F Gauge?
- Ep3 USdm rear bumper with hfp rear lip
- Thinking of getting an EP3?
- What model is my car?
- Spun Bearing help
- Looking for EP CTR rims...not having any luck...
- Rattle at rear windscreen driving me crazy (DC5)
- Low beams stopped working simultaneously. Here is what I already know.
- Battle of the Coilovers
- Shorter Tie Rids
- EP3 power locks wont work !! HELPP ! :(
- Rsx base auto to 6spd speedo not working
- The end of all swap questions thread!!
- Exhaust manifold ep3 vs rsx base
- k20z1 and a2 trans into 02 ep3
- FD suspension on DC5 type S
- 2002 Acura RSX won't idle
- Making exhaust quieter
- Brake Calipers EP4
- Rsx Tire size! Helpppp
- HELP - engine fault code
- k24a4 in rsx base model
- 03 Si needs new suspension
- Rsx fender liner
- K20a2 Swap into EP3
- 2002 Acura RSX Type S - Silver; Stolen in Chicago
- Sticking brakes
- Swapping a k20z1 into a 2002 civic si
- Ep3 Will Not Run
- K20 vs K24
- hazard button
- broken oil pan help
- 2003 rsx-s vs 2005 rsx-s
- Ep3 and Rsx-s A/C Compressor...Interchangeable?
- New member, I have a problem....
- Accelerator pedal not working, engine light up
- cam cap wear?
- should i buy???? help
- ShowStoppersUSA: Reviews?
- Frankenstein Water Pump?!
- Ep3 front end conversion?
- Acura RSX Rolled Over
- RSX-S wont stay running after rebuild!! Help
- RSX cruise control switch
- K20A3 Motor Rebuild and Turbo
- K24A2 Swap into 02 EP3
- 2002 Honda Civic SI Engine Rebuid Questions.
- JDM K20A Type R Swap on 02 EP3 (SI Body)
- Hood not aligned, looks raised.
- Intake sound like bomb
- Starter Grind on extremely cold starts, starter not disengaging.
- Clutch Before or After?
- k20 camshaft upgrade
- Door lock Problem(I did research, but still not sure whats wrong)
- P0325 Did almost everything possible
- Oil pump housing needed to swap in JDM K20A?
- DC5 Lowered supsension problem
- check engine light on
- LSD Question
- EP3- (pending) p0138 code
- 02 RSX Parking Light Socket
- Need ID on this part
- The years have not been kind to her....
- EP3 Transmission Help
- Megan ep3 lower springs , fit my rsx base model ?
- Flasher relay unit on 2002 Civic Exec
- Revo short-throw shifter failure
- Trip/reset Button Help
- R. engine mount question
- 03 type S, intake manifold question [without Kpro], also o2 CEL
- teal powdercoated valve cover
- Ep3 Shift boot question!
- JDM EP3R k20 high idle
- new to me 03 civic Si
- battery relocating behind bumper?
- First Car
- Bilstein PSS9 questions...
- Fog Lights
- Looking at buying this RSX. Opinions please
- Want to help me fix my car?????? 2.0L SI
- The case of the dead power outlets
- New To The Import World
- JDM K20 Type-r into 2006 DC5 problems car shuts off after 5 seconds
- Knocking sound, LCA bushings???
- jdm ep3 rotor selection
- 2002 Civic Si Electical Problems
- K24/K20 Build Need Advice!!!
- Knocking Noise Front Right Side, when driving on bumpy roads
- intermittent issues with my clutch
- RSX misfire issues
- BuddyClub
- screen goo
- DC5, EK suspension
- witch one RSX or Civic SI?
- EPS ECU....EP3 type R vs USDM
- price check on a black rsx-s interior panels
- rsx v6 swap?
- help
- Looking For RSX-S.What you think of this one?
- Ebrake light stays on, now my ebrake are locked!
- 2002 RSX heater core headache
- Transmission reassembly steps
- Prb ecu?
- Ek k20 kpro issues
- DC5 climate control wiring diagram.
- Civic ep2 D16V1
- Can't get RSX transmission off engine
- EP3 Exhaust help needed
- UK EP3 P1298
- Is it worth it?
- 2002 Civic Si - No Compression/Has Spark and Fuel
- Concerns with Performance Mods on Base Auto
- k20a2/k20z1 transmission question
- Starting/Idling issues.
- turbo?
- Ep3 or Rsx
- RSX Oil Leak - Can't Find Source
- Will Civic Si Brake Calipers Fit RSX TypeS?
- doors wont stay locked
- climate control bulbs
- No power to A/C, Recirculation, Rear Defrost Buttons
- ss brake line opinions...
- save the day
- 2002 Type S - 200k miles -maintenance suggestions
- Which Years Are Best
- cheap turbo kits
- Rest in Pieces Type-R number 20654
- Rounded the VTEC solenoid bolt. Help
- Rsx ride feel
- Help a noob out please!
- backfire through intake 02 civic si
- Vibrant Muffler Fitment
- Stupid mistake, need help
- 2003 Si jumped timing, possible piston/valve damage
- Rev limiter engaging @5500rpm after upshifting. Has anyone experienced this?
- 15x6 +38 rims onto 04 Si
- looking to purchase a RSX
- MAINT REQ Light on
- answer this
- 2002 RSX Type S odometer back light
- Plummeting gas mileage
- Stock and phantom tach not working! Help!
- Stock RSX Rails on DC5R Recaro's??
- what kind the bumper is this ? jdm??
- ABS sensor
- New 2002 Civic Si Owner!!
- EP3 purchasing help
- Strange wire near exhaust heat shield? Please help!
- Power to fuel pump probs!!! Plz help!!
- New e-brake cables for EP3?
- Exhaust diameter JDM EP3
- '04 EP3 - Suspension squeaks
- which sensor is this?!
- revving up and down
- RSX Door Locks Issue
- Steering Wheel Upholstery
- Hesitation,Bog, Flat spot?
- full throttle =5500 rpm
- ctr cluster in ep3...climat control light doesn't work
- Clutch replacement labor costs
- headlight bulbs
- What goes in this hole?
- k20a3 - Rotella T6 oil analysis
- Srs seat connectors cut. Need help with wire colors
- Popping from CAI around 3k rpm blinking CEL
- cylinder question on k20
- Vanity Plates for 03 Si
- K20 with a DC5 box,,problem!!
- type s torque spec ?'s
- Engagement and creep problem
- ep3 tail lights
- EP3 Hesitation Issue
- Hand Brake Light On !! Please Help
- Need help with O2 Sensor..I screwed up!
- Looking to gain knowlege
- 02 ep3 super poor gas mileage
- Air horns?
- need help on locating o2 wires
- 02 RSX Passenger Door Key Hole Part??
- 04' Civic SI rear caliper drags after break job
- rear bbk
- 05 rsx type s speedometer not working
- help? intakes & body kits
- a2 swapped ep3, ecu question
- Non S Brake upgrade- a Success!!
- P1259 & P0134
- Knocking Sound (yes I searched)
- buttons are working but cars not locking
- Help?! Oil drip in left front rim
- Advice on 53 plate EP3 CTR
- Replacing front 06 DC5 wheel studs help
- buying a 03 ep3 and have questions
- help
- 04 ep3 k20a2 head swap question.
- Choose intake
- Low beam caps for EDM CTR headlights.
- DC5 R input?
- 6-speed base rsx help
- new to my rsx type s any help or advise ?
- Has anyone ever ordered from this site?
- BC cams + SK2 valve springs + Hondadta ECU reflash = no run
- No Vtec crossover after oil change...
- Hard Shift, Somethings Broke
- Clicking / Popping Noise Coming From Front Drivers Side Axle (Not Normal Turning Pop)
- Radio wont turn on after replacing battery
- Door Locks Switch only works sometimes...
- 04 Si won't fire. Need help..
- K20Z3 gear box into K20A3
- Accidently Downshifted!!!
- Help with motor decision on my dead 02 Si
- k20a3 ac compressor growl/whine
- Transmission issues...
- Help! 2003 civic k24 turbo si
- How to fabricate my own manual shifter bushing
- Mechanic said Ebay Intake = blowing hot air into Cabin??? o.O?
- Cel p1166 and 1167 (i've done everything?)
- A Fuel return Question For Type Spaz.
- Please need help with 02 Civic SI 3dr
- K20A-R Low power. Feels bogged.
- my ep3 k20a3 won't start plz help
- just got an 02 type s what can i expect?
- need help!! with temp gauge
- 2005 RSX Type S Warm Stall
- Thinking About Buying A Honda Civic Si
- Looking for ECU!!!!...
- DC5 exhaust help
- ep3 intake manifold question
