icv problems
Old Jan 2, 2014 | 12:08 PM
Austin.em1's Avatar
Default icv problems
okay so long story short, i had the whole throttle bounce problem and figured id give it a shot and clean the thing before i spend 200 on a new one, so i got it off the tb and cleaned it and made sure not to get any in the plug, i got it all bolted back up and ready to go and started it and it ran like complete S**T, i figured i needed to drive it and when i did it would hit the fail safe at 3k rpm and it had 7 codes, the two that were problems were p0107 and p0108 which are complete opposits of each other so i un plugged and plugged the map sensor back in and it quit hitting the fail safe but still runs like *** and the throttle bounce is worse....help!
Old Jan 3, 2014 | 09:30 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: icv problems
Couple of things. How did you clean it with what? Also did you replace the TB gasket when you took it off and make sure you didn't break the rubber gasket on the IACV?
Also did you by any chance move the timing of the MAP sensor? Might want to check it's calibration
Old Jan 3, 2014 | 07:34 PM
Austin.em1's Avatar
i cleaned it with intake/ tb cleaner, and im not sure how i would have changed it, how do i check it? and no i didnt replace the tb gasked but i planned to tomorrow just the eliminate that, and i was careful with the rubber gasket but it was a tiny bit streteched so i got a new one to put on tomorrow too.
Old Jan 4, 2014 | 12:34 PM
Austin.em1's Avatar
it needed a tb gasket and new iavc gasket, i out some rvt on with the rubber gasket and it did the trick!
Old Jan 4, 2014 | 06:14 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Sounded like it.
xtegb16x
Dec 21, 2005 03:01 PM
Turbo_Mike
Aug 25, 2005 08:01 PM
DjFreeze
Apr 9, 2004 10:39 AM
MetalKill
Apr 30, 2003 09:51 PM
