7lb/ flash to 9lb Kpro
I have gone from a 7lb Hondata Flash to 9lb Hondata Kpro. I am a pure novice and have no idea how to program and tune this RSX. Does anyone have some parameters for oxygen fuel mix ratio? My Vechile to be more specific is a 2004 RSX Type-S. Help?
get it tuned. now.
dicking around with critical values like fuel and ignition timing when you dont know what you're doing is a sure fire way to blow that thing real quick.
Yeah you shouldn't be playing with those yourself if you do not know what you are doing... that is the easiest way to blow something up.
Even if we have matching cars, my car tune and your car tune will be completely different. If you want to try tuning your car yourself you need to buy yourself a Wideband and watch your air/fuels and knocks.
Also go on Hondata's website they have tutorial videos or youtube.
Spaz, TY for Your help! My car is far from stock but up until now it has been tuned by a Hondata flash for 7lbs boost wuth a JRSC. I have gone to a 3.2 SC Pulley rasung the boost to 9lbs,
Spaz, I have the K-Pro, the O2 Sensor Kit, Boost Gauge Kit and Two-Hole Pillae Pod. My only thought was that there might be a safe or neutral sraering point for fuel/air ratio. I have an excellent Mech but he has not computer tuned.
Also Spaz, do I need ab after-cooler and what do You recommend?
