PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. just installed esmm, now get a torque dampener?
  2. Installed TYPE-R intake manifold bad idea now..
  3. Check Engine Light after Transmission Fluid Change
  4. Help repairing scratch on 2004 White Base RSX
  5. 2003 Si FOB issue
  6. RSX suspension questions
  7. RSX TYPE-S lower ball joints where to buy?
  8. Rattle at 2-3k revs
  9. Stealth mode exhaust!
  10. Ugly Headlights
  11. EP3 aftermarket exhaust loop hole for the popos?
  12. after installing skunk 2 74mm tb and fuel rail
  13. 02-05 Civic SI Racing Headers
  14. RSX-S Straining at 3k and up.
  15. Kazz LSD Speedo Gear..
  16. 2003 civic SI pass airbag deployed question.
  17. K Sport Kontrol Pro Damper System EP3
  18. question bout ep a2 swap not covered ^^^ there
  19. 2002 EP3 gauge cluster fuser keeps blowing
  20. Considering local 2002 EP3... price opinion?
  21. 2002 rsx wont start!! help!!!
  22. How do I replace a ball joint?
  23. Code help
  24. 02 rsx failed smog, HELP!!!
  25. Weird Noises 2006 DC5 Base RSX
  26. rsx type s radio not working
  27. Ep3 suspension mod
  28. RSX Type-S Automatic possilble???
  29. serpentine belt need help
  30. 02-05 Honda Civic Si - Perfromance Parts
  31. clutch install starter question
  32. 2003 Civic SiR A/C operational intermittently
  33. whats the best suspesion EP3
  34. 2002 Honda Civic SI...VAFC-II Help!
  35. I'm new!! here's my 04 base
  36. New
  37. Im new
  38. ep3 recommended shift points from manual?
  39. spark plug gapping
  40. complications with ep3 engine into dc5
  41. Might buy higher mileage EP3 or DC5, what to look for?
  42. motul 300 gear (gearbox oil) 75w 90 ctr ep3
  43. Deep scratches on front bumper
  44. Hearing Noises on my rsx. help !
  45. Civic gearbox whine
  46. RSX-S check engine light
  47. Oil question
  48. frontcamber is +2 stuck there?
  49. megan racing coilovers help
  50. My DD
  51. Code: P0118. Has anybody had this?
  52. Extended shifter
  53. Interchangeability of passenger door mirriors on different years/trim levels of rsx
  54. Specs for ECT Sensor, please!
  55. Japfest 2 UK + my LSB EP3 Video and Pictures
  56. Really need techs input on this one....
  57. D14Z6 cambelt change
  58. Any way to connect mp3 player to...that
  59. Ep1 bought without oil in it
  60. are they all ep3s?
  61. Just installed raceland coilovers....
  62. HIDs on my EP3
  63. Grandpa needs help!
  64. Show me pics of a peakboost downpipe installed please
  65. Civic si 2002 - Ticking noise after 40MPH (3rd gear and +)
  66. RSX or Celica - can you tell the difference?
  67. The Official EP3/DC5 FS/WTB/WTT Summer 2011 Thread!
  68. Honda civic si 2004- need wiring info for air/fuel sensor.
  69. Can't find the dip stick lol
  70. Wheel hop when cornering...
  71. some sort of humming sound from the front? =/
  72. driving at high revs in type r all the time
  73. Ep3 thule rack
  74. My Vtec Wont Crack.
  75. Which resistor to slow down blinkers? And thermostat question
  76. 2002 honda civic si front bumper!
  77. Honda Civic Type R Supercharged - Knock Sensor Help
  78. Keyless entry remote FCC# for EP3
  79. Spaz went hellaflush...
  80. Do all USDM DC5 seats have side airbags?
  81. D.I.Y Swapping front sway bar from DC5 to EP3
  82. p0341 CMPS
  83. MCU vs ECM
  84. 03 civic hatch sir
  85. Rsx cruise control diagram....
  86. CEL 1259
  87. buying from clubrsx.com
  88. aspec spoiler question
  89. EP3 e-brake light stays on!
  90. Need help identifying engine
  91. Question to all you guys of EP3/DC5... Please answer!
  92. replacing rsx timing chain
  93. horn wont stop honking
  94. base model rsx 70k head gasket replacement
  95. rsx blower motor
  96. Finally Bought my Ep3 :)
  97. Question about RSX Endlinks
  98. 02/03 ep3 to 04/05 ep3 5 lug conversion
  99. Rota Slipstreams
  100. i found oil in my exhaust tip
  101. Air conditioner (A/C) issue and place to fix in Birmingham UK
  102. 2004 Civic Si hatchback window regulator
  103. FS: cleaning out for new parts
  104. Driver side glass problem
  105. Air conditioning not working - no errors in diagnostics
  106. shift linkage not re positioning itself
  107. clunking noise from rear
  108. Replaced VSS and I'm Still Throwing Code. Please Help!
  109. what to do? stripped/seized lug on loose stud
  110. 02 rsx wont start after spark plug change
  111. I know we don't do showoffs but....
  112. Looking around for my first honda :)
  113. K20A2 Fuel Rail Question
  114. Transmission limits Type S
  115. 02-04 RSX base lowering springs
  116. how much does this gen cost?
  117. Does anyone have 04' RSX rear bumper (red)?
  118. DC5 R suspension question
  119. anyone know if k20a2 or k20a3 girdles are the same as the k20a-r?
  120. spc or ingalls front camber bolts?
  121. Greddy E-manage For Sale!
  122. 2 way alarm
  123. 03 rsx fog lights
  124. ep3 primary o2 sensor help
  125. oscillating idle IAT?
  126. 04 Acura RSX Type S, Jumped Timing?
  127. timing chain tensioner
  128. need help with my o2 civic
  129. RSX PROBLEM!!??!?!?
  130. EP3 AT MILLER MOTORSPORTS PARK
  131. Code PO600
  132. EPS, Instument panel and A/C stopped working
  133. EP3 ALARM PROBLEM
  134. 02 Rsx-S any faster?
  135. EM2 to EP3
  136. K20A2: what is this vacuum fitting?
  137. Have you EP3 owners noticed...?
  138. Relocated Battery Exploded
  139. AC problems EP3
  140. ep3 exhaust
  141. What spacer would i need
  142. "A" acura colored badges/emblems
  143. coilover uneven? alignment fix?
  144. What does a FULL bolt-on 05-06 RSX Type S consist of?
  145. Type s sub replacement with AM sub
  146. rsx engine shut off help!
  147. transmission/shifting issues
  148. Supercharged exhaust question: Stock + headers/downpipe? or full Catback?
  149. ep3 greddy banjo bolt
  150. EP3 towing
  151. Throttle Body Issues
  152. 03 black housing headlights
  153. EP3 Chassis Needed for Suspension Mockup at Muellerized
  154. EP3 shaking at 40mph and above
  155. EP3 lowering springs question.
  156. Koni strut insert into a EP3 - Need some help!
  157. rsx/civic
  158. How to tell if RSX mirror is heated?
  159. Reverse lights not working...
  160. D.I.Y Making an ITR MOMO airbag work
  161. Wiring problem please help:-(
  162. Got new front brake/chassis stuff.
  163. LED Reverse Light Bulbs 05 RSX
  164. which jdm rsx has stock HIDs?
  165. Delete account button?
  166. D.I.Y Tapping Vacuum Ports
  167. strangest noise coming from Belt, pulley & tensioner area..(w/ video)
  168. integra dc5 cooling plate
  169. Help me remove my radiator support frame...
  170. p0115 ep3
  171. Valve adjustment?
  172. Fuel Cutting out at 4000 RPM
  173. 4.0 Final Drive with TSX 6th Gear Review
  174. Wich Oil? help please
  175. What other model shifter cables will work on an EP3? (please help)
  176. Wingless EP3s? Yay, Nay, Meh?
  177. After two years got my AUDM Cluster
  178. need help identifying pin
  179. MTF
  180. MAX REVS FOR MY built k20a2???????
  181. 2002 ep3 ball joints
  182. D.I.Y Swapping Tails or Replacing Gaskets (05/06 rsx)
  183. DC5 passenger rear knuckle/EP3?
  184. 03 SI hard to shift 5th to 4th
  185. EP3 front bumper lower grill question?
  186. annoying rattle
  187. race header throwing p1166 and p1167?
  188. 06 RSX 5speed standard
  189. speedometer help please please please k24/6sp rsx kpro
  190. 03-05 si
  191. wheel spacer question, trying to fit 17x9 low offset
  192. new 03 Ep3 coils?
  193. pic request: Enkei PF01 on an ep3
  194. aem wideband install
  195. EP3 stock hp possiblities????
  196. type s parts
  197. Who all from the ep3 squad will be going to IA Nash in july
  198. guess my suspension/wheel/tire setup
  199. 2002 integra rsx to 98 honda civic dash swap
  200. E-manage in EP3 HELP!!!!!!
  201. Clunking/knocking in rear suspension
  202. 05 civic si--salvage title?
  203. 2003 EP3 Fuel Filter Issues
  204. 06 si nav in a 04 ep3
  205. Going bigger/wider, leaving the bicycle tires behind. (wheel/tire size input needed)
  206. is it ok to run 87 instead of 93?
  207. QUESTIOn for DC5 ITR Headlights! help!
  208. Please give me your opinion - regular color spoiler or carbon spoiler???
  209. engine question
  210. How to identify a Type-S Trans and Head
  211. ECU-Questions ???
  212. K24/K20 WHP
  213. DC5 Type R muffler
  214. HFP Suspension for EP3 - Did Alignment Setting Change?
  215. struts and alignment
  216. 02 rsx not working the best
  217. koni shocks
  218. 2005 civic si manual
  219. The Official EP3/DC5 FS/WTB/WTT April 2011 Thread!
  220. DC5 airbox on EP3.?
  221. TRS - How to install window net + kit?
  222. EP3 Si for the track?
  223. K24 K20 Vtec help
  224. Power Steering Problem
  225. Key Immobilizer for RSX question
  226. ukdm civic type r cluster in ep3
  227. Spark plug reading, check out my plugs
  228. Spark plug threads on k20z1
  229. Vision Type-DC carbon mirrors
  230. Rsx 02 starting problem!!!! Please help :-(
  231. D.I.Y Replacing Shifter Cables DC5 (Hybrid Racing for me)
  232. Need help with JDM EP3 Type R - Honda expert advice welcome!
  233. K20A2 vibration problem
  234. What is good website to order part for your car?
  235. My 03 Type S before and after the new parts!
  236. D.I.Y Rear wiper delete with plug
  237. D.I.Y Redline Shift Boot with stock collar
  238. D.I.Y EP3 Steering wheel swap
  239. D.I.Y Easy tool to remove air in coolant system
  240. D.I.Y Batter in the trunk
  241. D.I.Y Painting A-Pillars
  242. D.I.Y ITR Pedals Instal
  243. D.I.Y Red Door Inserts / Removing door panels
  244. D.I.Y Valve Adjustments
  245. D.I.Y Hood Dampeners
  246. Type-'S'paz Official DIY thread!
  247. D.I.Y EPS into DC5
  248. D.I.Y Fender Rolling
  249. D.I.Y Simple Bay retouch up painting
  250. D.I.Y Installing Cusco Bars and Harness Bars
