PDA
View Full Version : Acura RSX DC5 & Honda Civic EP3
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. A3 Vtec killer help
  2. rsx 2005 types s p 2422
  3. screeching sound at around 2k rpm
  4. 14s on a EP Hatch?
  5. rsx 2005 types p2252
  6. help??
  7. Starter Went Out
  8. Swapping out condenser
  9. EP3 overheated???
  10. Shifter not returning to neutral?
  11. No sound from Avic D3??!!
  12. EP3 Kswap
  13. EP3 hatch is stuck closed
  14. Pictures please! DC5 slammed with 08 Si wheels
  15. rsx a-spec
  16. ep3 start button
  17. Is the buddy club n+ coilovers good
  18. What is a good company to buy coilovers
  19. gutted hondata airbox
  20. Worried about CHP inspection...advice plz
  21. enkeis
  22. Aftermarket header/passing emissions
  23. car dies out one me?!?
  24. Ep3 face lift conversion on a preface lift
  25. More cam questions...
  26. weird spring noise
  27. Multiplex Location 2002 civic si
  28. Buddy club spec II
  29. Storing car any prevenitive maintenace i should do for the DC5?
  30. Experience with CAPA-Certified versus non-CAPA
  31. questions about headers???
  32. Clicking sound when A.C. is off.
  33. Driver's side window doesn't work!
  34. 2002 ep3 cam
  35. is ep3 CTR seats recaro??
  36. new rsx owner, problem with door locks
  37. EP3 HFP Lip w/OEM Foglights.
  38. k20a2 cam help
  39. Cluster bulb replacement?
  40. type r swap knock sensor
  41. I using a ton of gas after my air intake install
  42. RXS-S 02 Front end shaking under high load during acceleration
  43. RSX deck install newbie questions
  44. Mysterious Engine Noise 2003 Civic
  45. WTF is wrong with my A/C compressor?
  46. Question about headers
  47. Code P1157, P0134
  48. The Official EP3/DC5 FS/WTB/WTT July 2010 Thread!
  49. 02 type S, dies when coming to idle
  50. Need a Catalytic Converter
  51. lookin to buy a 02 type-s
  52. K20A3 Kpro
  53. Side Markers DC5 Installation HELP
  54. Check engine light
  55. parts interchangeability
  56. K20z1 chatter at start up...???
  57. Get to 8k rpms then check engine light flashes?
  58. Couple Easy Questions
  59. loud tick, need quick help to get to work
  60. Video: new system flexing the si
  61. k20z3 block help?....
  62. Building a DC5 Track Car @ Showoff Imports, Project DC5
  63. Suspension questions..
  64. coilovers! opinion needed :[
  65. Greddy vs Skunk2
  66. I NEED HELP ON WATER LEAK???, FIRST START UP ON K24A1 BLOCK/ K20Z1 HEAD
  67. K-Pro?
  68. 3rd gear pops out?!?
  69. so my Ep3 is F'ed can u help
  70. RSX radiator suport fit 03 to 07
  71. Who's selling greddy sandwich oil cooler
  72. Turbo Manifold Question
  73. reflash?
  74. Parts For ep3
  75. ep3 stock hood, rims, and side skirts
  76. planning on dc5 purchase bad tranny?
  77. 2002 SI Gauge Light Problem
  78. ep3 Lower Control Arm bushings
  79. what to look for in an oem ITR DC5 lips?
  80. O2 sensor Question
  81. My Milano ep3
  82. 18000-XK2-K0S0 or 18000-XK2-K1S0 for EUDM EP3
  83. Ep3 seat belt buckles in rsx?
  84. Looking at Getting an EP3, any advice?
  85. went to the dyno. not what i was expecting....but wait..
  86. clutch click??
  87. 03 rsx type-s door lock problems
  88. Gauge Lights Fading/Completely Off
  89. EP3 HEADLIGHTS and TAILIGHT QUESTION
  90. how to check timing tensioner?
  91. EP3 stalls out?
  92. a/c filter for 2002 rsx
  93. front break grinding noise
  94. no performance with sport exhaust ep3
  95. rsx rear bumper clips and screws
  96. Popping/clunking noise?!?
  97. Im looking for dc5 wiring schematics :scared:
  98. Tie rod ends?
  99. Need a new primary o2 sensor will this one work?
  100. ep3 k20a2 jrsc vs. k20a2 n/a
  101. tokico D spec (where to find good deal)
  102. Antenna Removal???
  103. which mount kit?
  104. E-brake release button...
  105. need a DIY for the rear struts on a EP3
  106. 05-06 rsx rear end on 03 rsx
  107. airbag swap question
  108. Weird noises!!
  109. Maintenance light
  110. Do I really need a type-s...
  111. simple question!!
  112. Need a part #
  113. Oh hey 4th gear, where'd you go?
  114. EP3 WONT START!!!!!
  115. P/S Breather Problem?
  116. Losing oil too quickly. k20a2
  117. Power steering loss every so often.
  118. DC5 Drag times
  119. Buying an EP3, input on this listing?
  120. do i need kpro with the rbc
  121. Question ? Skunk 2 Stage 2 Cams or A2 Cams on A3?
  122. hondata reflash questions
  123. nology hot wires
  124. The Official EP3/DC5 June 2010 FS/WTB/WTT Thread!
  125. ep power window and locks not working
  126. ep3 timing chain stretch?
  127. *****A/C problems.
  128. Rebuilding front calipers HELP
  129. EP3 K20a3 Starting/Running Issue ***GURUS NEEDED***
  130. Repair manual
  131. Ep3 with xxr 522
  132. EP3 parts question PLEASE HELP?
  133. No Spark, need help.
  134. Buying a type s soon, had a few questions
  135. Funky piston!
  136. ABS tooth count
  137. Albert Lee Photography: Rsquad DC5 Turbo TORONTO
  138. Track Discussion, Kills, Stories....
  139. Busted lower block (girdle)
  140. Clutch rattle when the clutch is engaged.
  141. Check Engine code 41 quick question please help!
  142. 4th annual garden state plaza meet! june 13th
  143. mis shifted from 3rd to 2nd. have no compression in cyl #1
  144. swap help please!!
  145. WTF Flywheel Issues?!
  146. k203 motor problem. need help troubleshooting.
  147. I-vtec decal removal
  148. 17x9 +35 wheels fitment help!!
  149. Help: EP3 Cluster Harnesses Pin
  150. help kpro doesnt read kal's
  151. ELD part number ep3
  152. prc vs prb manifold
  153. ep3 cruise control problems.
  154. heater blower wont turn off
  155. Static problem with speakers
  156. White/Gold Wheels on White?
  157. Any1 have ep3 with blacked out tails?
  158. A/C Switch diagram
  159. Will these rims fit on rsx type s?
  160. Im Looking For Any number Chassis ep3
  161. how much should i sell my blown k20a2 head for?
  162. 03 Civic Si EP3, rebuilt title, yay or nay
  163. DC5 and EP3 Civic BBM Group
  164. Spoiler on an 02'
  165. Sparco Hub Part Number for RSX?
  166. injen intake...CARB legal?
  167. HID's and aftermarket headlights
  168. RC injectors question
  169. How do I know if it is a K20A2 0r K20A3?
  170. 2002 Ep3 Engine Ticking Sound
  171. Vibration issue.
  172. Steering squeak
  173. Worth buying this 2005 rsx-s?
  174. Rsx flywheel cover?
  175. Poped EP3 Motor... what else is a drop on option?
  176. P2647 causing limp?
  177. suspessions!!!! and wheels/tire size!
  178. Hotchkis Lowering springs for rsx????
  179. Any recommendation for Springs/Coilovers? Limit to spend $1000
  180. looking for kpro/nitrous tuner near WV..
  181. K20 for sale
  182. T1R exhaust
  183. Drive shaft shop axles leve 2.9 Helppppppp
  184. shifting issues - clutch? master cylinder? slave cylinder? help...
  185. Sidemarker and Wheel Clearance Questions
  186. DC5 vs DC2 recaros...
  187. 05 RSX S ecu
  188. DC5-R, got code P1253
  189. WHERE TO FIND THE HFP LIP KIT FOR USDM 2002 EP3
  190. glove box is stuck close
  191. 2005 Si power problem
  192. rattling sterring wheel!
  193. Good deal for a 2005 rsx?
  194. EP3 is throwing Code P1298 - just change ELD?
  195. timing chain
  196. looking to buy RSX-S, few issues..
  197. Are the 02-03 OEM EP3 Bumpers Same as 04-05 Oem Bumpers?
  198. Air Filter Size...
  199. will 05 type-s rear bumper fit 03 base rsx?
  200. Got a 03 rsx base model..pro...con
  201. intake runner control location?
  202. Acura RSX
  203. Accidently cut a power wire behind the radio.
  204. Coilovers or Dampers
  205. Radiator support bent?
  206. The end all Differences/Changes 02-04/05-06 RSX Thread
  207. DC5 Factory Colors, Type S Only
  208. Pics of a DC5 with DC2 ITR wheels?
  209. how can you tell if rsx is a type s?
  210. uk ep3 diy grill?
  211. Dash/radio paint
  212. Masatsu Engineering | Official RSX DC5 TURBO Pic Thread
  213. maintenance required
  214. Tint? Yes or no opinions please
  215. Anyone ever have electric lock issues? (ep)
  216. RHD front windshield
  217. what ball joints can i use for 02 base rsx
  218. swap question
  219. Help me with my brakes (dc5)
  220. Can EP3 shocks/springs fit 03 RSX Base?
  221. does anybody use there wheel well
  222. 04 Rsx Leather seats vs 05 Rsx Leather seats
  223. Steering Knuckle Stuck in Outward Posistion PLZ help asap!!!
  224. New Smaller Tires
  225. Need New Struts any Suggestions
  226. want to buy rsx type s shifter cable
  227. VSS Code
  228. how to get fogs to blink with alarm and turn on with parking lights
  229. FYI, switchblade keys for EP3s
  230. cluster fried???
  231. Omni power master failure
  232. acura rsx type S oversize valves and stage 2 cams
  233. 03' RSX-S electrical issues. Rear lights, blinker, window etc.
  234. suspension help
  235. Type R Swap WTF is going on
  236. cluster swap help
  237. ep3 wiring help
  238. DIY Volvo Lip
  239. Parts List: 5 sp ep3 tranny into a 6 sp
  240. Buddy Club Spec 2 exhaust = the same as running straight header?
  241. 07 si wheels on ep3...help
  242. P0135 changed my prim o2 and CEL still on. Help Me
  243. Loose Cigarette Lighter
  244. Autometer Single Steering Column Pod 2-1/16" (Black): Acura RSX 2002-2003
  245. EP3 Caliper Upgrade
  246. EP3 cant start, need help. plz
  247. ****Please help ***** 02 typeS with tsx swap ......
  248. Would these fit the RSX? 18x9 +45 & 18x10 +48??
  249. 04-05 JDM BUMPERS, LIPS & SKIRTS ONTO AN 04 EP3
  250. (EP3) Progress C1 coilovers?
