- Problem after installing new Transmission/Clutch/Flywheel
- rebuilt trans
- Vancouver Island Poker Run for Charity
- Help: EP3 remove door panel inserts
- just got cams
- new wheels....maybe
- new member, looking to buy a rsx
- For those of you who have experience with a Megan Racing Header
- 02-03 SERVICE MANUAL!!!!
- Just bought a type s - This noise is killing me!!
- 2002 rsx window not rolling up correctly
- Ignition lock cylinder issues.
- Oh no, not another immobilizer question!
- 16" wheels
- ep3 rear lower control arm
- help key wont turn
- 05 RSX-S, added Skunk2 Pro Manifold, now bogs and dies after 5 seconds.
- Steering Rack Rebuild???
- Quick K20 Axle Question
- Fuel Pump Instal DIY
- anyone riding on function and form coilovers for the ep3??
- 16inch rota jspl on RSX?
- Cant figure out a scraping noise coming from RF tire
- skunk2 70mm v. 74mm TB
- SD MEET!!!
- local dyno day pics n video
- DC5 Sidemarker help!
- Infamous Spoon EP3!!!
- Temperature gauge not working
- auto/manual shift light on 2002 rsx
- who makes orange spring and retainers ?
- K20A2 Oil Pan Removal Help
- Konig Runway 17x8 35 offset on a EP3
- need some advice. poss. trans trouble.
- Torque specs and bolt pattern for k20
- evap system purge control valve
- Gearbox drain plug?itr dc5
- Electrical Problems?? Help Please.
- skunk2 intake manifold on a base
- Looking to buy RSX. Questions, ticking sound etc.
- Spoon Calipers installation on EP3 HELP!!
- The official EP3/DC5 April 2010 FS/WTB/WTT thread!
- SD 619 Ep3 RiDeRs
- How To? Cam-Positioning Sensor! Please assist. (PIC's)
- Teal Enkei's
- installing 05 stock heads and tails in my 03 what do i need?
- EP3 cigarette lighter plug removal Q?
- Red Honda Emblems for EP3 not fitting USDM 04 SI...PLEASE HELP!!
- 03 Si Failed emissions for EVAP??
- Front end clunk
- Whos car is this?
- EP3 energy suspension question
- 15 inch rims.
- hfp lip with fog lights help
- Hondata Question
- car fax report pleaseee?
- wtb; knock sensor for K20 engine (ep3 CTR)
- need help asap
- DC5 w/Vibrant Universal Flat Black Muffler 2.5" & Vibrant Ultra Quiet Resonator
- Probably Buying my 1st EP3
- The New guy, but not new to the game...
- my car caught fire!
- Aug. 7th 2010 RPM Car Show
- Hondata ECU Reflash now only $295!
- personal opinion.
- Stock radio volume control knob
- What tactics do you use to change your oil on your dropped rsx??
- Old wheels
- dc5 backyard special front bumper
- HFP Lip - Where to buy?
- Ep3 Arches
- just got kpro in
- Smart Polish clay bar.
- RSX+K24A2+Kiddracing header= what swaybar
- Thule Roof Rack
- dc5 secondary o2
- 03 Civic Si Hatchback EP3 Tail Light Removal?
- Quick rear brake advice question...
- JDM EP3 Window Visors
- Maint Req'd light
- dc5 test pipe?
- EP3 w/crazy CEL need help!!!
- Chilton or Haynes?
- which set up wld be best for my a3?
- EP3 Suspension problem..
- EP3 headlight/taillight question
- how to tell diffrence between the cams
- To buy or not to buy!
- lowering my stock 2004 rsx type s
- Clutch choice for 04 rsx-s jrsc at 9psi
- P0219 Engine Overspeed Condition???????
- Civic Hatch SI
- Doing a stealth alarm install on my Ep3, need some help...
- type-s base differences
- blown k20a2
- Another newbie here...
- ECU PRB vs PRC
- 5-lug conversion help!
- vacuum line Q?
- Spoiler or No Spoiler?!?
- HELP!! I'm locked inside my Acura and can't get out!!!
- Installing Cusco B-Pillar into EP3
- just ordered kpro
- DC5 exhaust HELP!
- stock ep3 with a2 cams quastion
- Ep3... Help!!!
- Can I remove this?
- High quality interior carbon fiber vinyl wrap.
- Front and rear Type R emblem
- can i run a k20a3 with a k20z ecu?
- RSX Driver Door Lock/Actuator stopped working?
- help with seats
- help with noise/knocking ***video inside
- DC Header Question Please Help(DC5)
- Changing my friend's pass. cv axle
- hose i think is leaking water
- rear wiper?
- Cusco front bars for DC5
- 2003 EP3 not running right!!! HELP!!! PLEASE!!!
- Intake duct similar to dc2>>>>>>
- This Weekend
- Which year to buy 02-03 or 04-05 for ep3?
- Car pulls to right one day after alignment?
- EP3 Idle Issues, IACV? Got Code p0505
- help ep3 6 speed
- Tokico D spec
- skunk2 short shifter
- EP3 : Alignment problem after five lug conversions.
- Pic Request - EP with dr-20's, works, flashbacks
- walbro 255 issues
- how well will an EG lip fit?
- YO INEED UR HELP!!!PLEASE
- EP3 Cyl 1 not firing.
- Just out of curiosity ...
- Heater question
- fuel pump/sending unit problem
- FOG light wiring help
- location of ep3 fan switch..
- Your first VTEC experiences or memories.
- HELP! AC Compressor siezed in 04 Si Hatch
- need a part number
- valve adjustment this weekend - need guidance
- 16" rsx wheels
- K-Pro Vs. Haltech Ecu
- Blue Rear Seats?
- new to kpro
- K24A2 into 02 Type-S
- Help Been trying to install Shift light to Back of Cluster "green Wire"
- Help i want to go turbo ep3
- Oh Snaps! Josh's EP3's Mini Shoot...
- Cricket Noise between RPM's
- No heat!
- DC5 or EP3 Please help
- can i use 05-06 honda emblems on my 03 type s
- Kelford Stage 1 Cam Test K20A2
- Aftermarket Seats
- new to honda tech.
- volvo lip help
- understanding my vin
- key fob not programming
- Help! squeaking under the hood!!!
- 2002rsx 2004rsx different?!?
- New England EP's
- 15" steelies 04 ep3?
- ephatch down?
- German Civic EP Mugenstyle
- Ground Control question
- gruppe M for EP3
- lower ball joint recomendations
- headgasket???
- need peoples opinions plezz..got a k20a3
- TO ALL GARRETT TURBO FANS... BE WARNED
- 03 Type S Possibly Swapped??? Searched
- Rear tires rubbing. 215/45/17
- Jun Integra tire and wheel setup.
- Turbo vs Supercharger
- 02 Type S VSS pinout
- EP3 Fog ligts concerns
- abs light??
- left headlight
- Need help asap! Strut and Spring install
- reverse lockout switch help
- Are all RSXs approved for California emissions/smog?
- turn singal relay diagram help dc5
- EP3 head swap ?
- New to the RSX world
- Suspension Noise
- Are all Ep3 si and stick? or are there any autos?
- question about 2002 type s bose woofer....
- clutch install with rsx type trans 02 into a 02 ep3
- dc2 vs dc5??
- Refurbished RSX bumper.
- Help! Trying to avoid taking something apart...
- Boosted ep3 Project
- PLEASE HELP k24a2 swap into a 02 type s questions
- adding motion sensor to a stock alarm possible?
- HELP!
- EVAP monitor will not set!
- 2002-2006rsx. whats best?
- DC5 Setting up for road race
- dc5 clutch master cylinder help
- Progress sway bar advice needed.
- RBC intake manifold vs Skunk2 Manifold
- Sticker removal
- K20a3 question?
- Braided brake line recommendations?
- 3M Lens Restoration Kit: Quick Review, Comments
- is a new head gasket needed?????
- Any of the DC5/EP3 Squad Members going to be at Eibach???
- k20z1
- Question On Rebuilt Transmissions
- 03 dc5 itr suspension on a 03 civic si - help..
- AC not working
- rsx needs a master cylinder & a diff
- 02-04 k-pro converted to 05-06?? possible?
- 2002 Civic SI will not go above 4000rpms.. starts bucking
- k20a3 head work
- Rust issues?
- Problem Civic!!! Please Help...
- 06 RSX-S cylinder pressure
- HELLO GUYES
- Car wont start and fuel pump doesnt prime!
- AUSTRIA needs HELP from USA Honda Fans
- 2002 RSX-S...pros/cons
- HELP!!!! 06 RSX Halfshaft trouble
- positive ground k20z1!!!!
- Burn smell what could it be?? Help
- Ingalls Stiffy Noise
- Redline MTF review.
- '03 EP3 - front end "creaks" and "grunts" and "pops" (not cereal)
- loud engine
- Aftercooler Parts finally gathered
- EP3 headers
- K20A Type-R Transmission
- Won't pass 4000RPM 2002 RSX
- LF Base RSX or Ep3 engine harness
- jrsc install
- need help. k20a2 engine harness
- EP3 steering wheel extension?
- 2003 Acura TL rims on a RSX
- Radio code for 2002 Civic SI
- What color rim do you think?
- Energy Suspension motor mounts review and tips.
- Second gear grind and Third Gear pop out.
- EP3 shifting
- Which oil is best for k20? Amsoil, Royal Purple, Mobil 1 etc...
- 2002 Honda Civic 1.7 Diesel 3dr
- worth the price for an ep3?
- rsx crank no start
- driving around with 3 quarts of oil. good or Bad
