chipped p75 check engine light problem
hi guyz i have a 95 turbo accord with a p75 chipped for vtec on crome. well today my check engine light came on out of nowhere. i went into h and r block started the car up and check engine light came on very dim. so i turn the car off started it up again and like 10 seconds while the car was running the check engine light came on this time bright and solid. so i try to check the ecu for codes and there was no codes. the check engine light just stayed solid. the car still runs fine vtec engages and everthing. do u guys think my ecu is bad. also i checked grounds and connects everything was good.
