Before /After Ignition Map D16Y7 critic please.
My setup D16Y7
450cc blue tops
stock Map
T3 turbo
38mm wastegate
DSM BOV
intercooler
arp head studs
Go autoworks DP, dumptube and cast mani
Neptune RTP
everything else stock
I am okay with tuning still learning and new.. the first pic is my ignition map that I am currently running , pretty conservative and safe..
, after running on it for awhile not making any other ignition adjustments, I decided to redo the ignition map smoothin everything out more and add a little more timing to the whole map. please comment any advise? critic please willing to learn !
Pic one before
pic two after adjustments, comments would be great aswell as pointers!
450cc blue tops
stock Map
T3 turbo
38mm wastegate
DSM BOV
intercooler
arp head studs
Neptune RTP
Pic one before
yea I have been reading up on how to read spark plugs have a bunch of good links, I will have to read about how to achieve Max brake torque on a dyno though. I made myself a Det can HMT style with a mechanics stethoscope threaded to the block it works okay except when the fan come son
and a little hard to listen when the WG opens up .
another question the changes that I made in the second ignition map am I running to much timing through out the map? maybe I shall try it out tomorow morning then pull my plugs and see how they look.BTW I am running NGK BKR7E's forgot to mention that
and a little hard to listen when the WG opens up .another question the changes that I made in the second ignition map am I running to much timing through out the map? maybe I shall try it out tomorow morning then pull my plugs and see how they look.BTW I am running NGK BKR7E's forgot to mention that
RACEPAK
Engine Management and Tuning
Jan 18, 2012 01:04 PM
rice4life
12
Jan 5, 2005 05:27 PM
