Crome and starting a new engine for the first time
Old Mar 5, 2009 | 11:22 AM
MantisX's Avatar
Default Crome and starting a new engine for the first time
I will be installing my engine back in my car this weekend. I did new pistons, rods and some head work. I know the best practice is to start it so as not to wash out the rings.
Other than a known good basemap, are there any changes I should make within Crome when starting the car for the first time? Should I lean out the idle maps more?
I have 450cc DSM injectors, walbro 255 pump and the pistons were changed from stock 9.2/1 to 9.3/1 compression ratio. I also have an LC-1 for A/F purposes.
Thanks all
MantisX
Old Mar 5, 2009 | 08:57 PM
mtber's Avatar
Default Re: Crome and starting a new engine for the first time
Start the car, watch the a/f ratios & proceed from there :-)
Old Mar 6, 2009 | 03:47 AM
Walterronny's Avatar
try to learn how to read plugs too.
Old Mar 6, 2009 | 06:29 AM
MantisX's Avatar
Hi,
So would 14.7 AFR be fine as a target ratio for a first start and idle?
Thanks all
MantisX
Old Mar 6, 2009 | 03:45 PM
maddog20's Avatar
when you first start the car the A/F should be richer due to the Post Fuel..then ECT/IAT compensations. Once the car warms up yea 14.7 is a good target good luck!
Old Mar 6, 2009 | 04:47 PM
98vtec's Avatar
moderator emeritus
Originally Posted by MantisX
Hi,
Thanks all
MantisX
i usually try and get it around 13.8-14.2 at cold start (may need to be richer in areas where it gets insanely cold). Just remember that 14.7 is ideal (theoretically a perfect burning of fuel) for operating temperatures (180+*F) but not for cold engine temps.
start with a known good map and go from there. If you have a wideband then you are all set.
Old Mar 9, 2009 | 06:37 AM
MantisX's Avatar
Thanks guys for the info! I was able to get the car primed and started correctly. Now to get her tuned.
Thanks everyone
MantisX
Adammhenry
Jan 21, 2013 02:26 PM
lyzer227
Feb 7, 2009 12:02 PM
Shinbo
Nov 7, 2004 11:16 AM
EK45VTi
Jul 30, 2004 03:40 AM
gtcali
Jun 25, 2003 10:12 PM
