3 bar map sensor wiring
Old Feb 15, 2009 | 09:49 PM
Got traction's Avatar
Default 3 bar map sensor wiring
anyone know the wire colors for a 97 y8 on the map sensor? tried to follow the instructions on hondata's site but that was for b series and my wire colors were different
Old Feb 15, 2009 | 10:00 PM
mtber's Avatar
Default Re: 3 bar map sensor wiring
Use a multi-meter to confirm the colors/signal etc.
Generally green = ground
White = signal
Yellow = Power
Old Feb 17, 2009 | 11:53 AM
omniman's Avatar
Although the wire colors are different from years and models the pin out is the same.
from left to right looking into the sensor at the pins
left pin 5 volt source
center pin is ground
right pin is volt out or signal
92redhatch
Jan 12, 2007 01:25 PM
ZenDynasty
Dec 17, 2006 11:43 PM
PINKS
Jul 11, 2006 11:57 AM
Ski11z
Jul 15, 2004 08:36 AM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
