EJ Full Throttle Wiring...
Old Jan 26, 2009 | 03:47 PM
mxglory258's Avatar
Default EJ Full Throttle Wiring...
Just recently swapped my boosted B18 out of my EF into my 94 EJ EX.
The EX was originally auto. When tuned full throttle shift and launch control were added.
The car starts w/out having to depress the clutch.
My question, is how do I wire the clutch switch into the ECU to get my full throttle shift working?
I'm great with almost everything EXCEPT ecu wire numbers lol. So any pictures would be greatly appreciated.
Thanks in advance. I've tried google and came up empty handed.
Old Jan 26, 2009 | 04:58 PM
mxglory258's Avatar
Default Re: EJ Full Throttle Wiring...
The ecu is a 1980 or a P75. I Know I have to ground one side of the switch, all I need to know aside from that, is which wire do I splice into, or simply cut and wire into the switch from the ECU.
Also need to know if i can simply cut it, or if I have to splice it in.
Old Jan 28, 2009 | 07:10 PM
HiProfile's Avatar
I think its this wire, since the starter is disabled unless this used/not used. Can't recall what polarity it needs, but the desc indicates +12V.
B9-STARTER SIGNAL starter signal Blue/red, Battery Voltage in the START position (clutch depressed on M/T models)
http://www.superhonda.com/forum/f55/...inouts-217405/
billyhoe
Dec 21, 2020 11:52 AM
julezeve
Honda Civic (2001 - 2005)
11
Jul 26, 2009 02:03 PM
SpeedingHatch
May 22, 2006 09:58 PM
Mark27
Audio / Security / Video
Apr 13, 2002 08:30 PM
raene
Aug 1, 2001 07:21 PM
