question about gas
ive heard that if you got a b16 you gotta fill it up with 91 gas, i barely got my car it has a usdm b16 ive filled it up once with 87, and i wanna clarify to make sure i can put 87 and i dont have to put 91.
Check the owners manual and use the octane rating that it says to use.
If you use a lower grade than recommended you could see poor performance and fuel economy. Due to knock timing retard. If you run low octane in a high compression engine you may start to hear a knock. If a knock sensor detects this it will retard timing. Over a prolonged period this is not good for your engine or your fuel economy. It would probably be cheaper just to by 91 in the end.
vandersmissenc
18
Nov 10, 2005 10:17 PM
