help with msd
Old Jan 17, 2009 | 01:29 PM
Navy_CRX's Avatar
Default help with msd
Hi
My buddy just gave me an msd 7al-2.
i have no idea what it does or how to install it.
thanks for any help
eddie
Old Jan 17, 2009 | 09:15 PM
mtber's Avatar
Default Re: help with msd
Sell it & run your oem honda ignition system.
We have made 600+ whp on stock distributors without a single problem.
Old Jan 18, 2009 | 02:04 PM
ek4galapi's Avatar
yeh...oem's plenty good for well up to 600+whp
Old Jan 18, 2009 | 03:03 PM
sander's Avatar
2.7(p/t)
I would tend to disagree a little here. The factory Honda coil and ignitor are places of concern for me personally. Sure, it is absolutely possible to make 600 or more on a stock coil and ignition, although I have seen cars that have crapped out at 350, 400, 450,and obviously the higher you go, the higher rate of failure.
I would always personally error on the side of safety, over build your ignition with nice components and worry less about a potential problem in the future.
To further my point if this means anything to you, I ALWAYS have a spare known good distributor with me at a dyno just in case.
Old Jan 19, 2009 | 06:05 AM
mtber's Avatar
I do too, however I have seen factory honda ignition systems to be more reliable then the general msd 6/7al with a cap/coil etc. (The most common upgrade on honda/acuras).
This is not to say that a properly setup m&w system wouldn't be awesome on every car, but for the money a factory honda ignition system does very well!
Xtreme_Cause
18
Jun 22, 2020 08:27 AM
Kilpuri
May 25, 2009 06:59 AM
unFOB4U
Aug 17, 2002 08:44 PM
GTEater
Jun 24, 2001 02:58 PM
