Is this p05 ecu set up for Vtec?
Old Feb 13, 2009 | 12:51 PM
schmiddr2's Avatar
Default Is this p05 ecu set up for Vtec?
I have searched and found there are certain components added for chipping an ecu and certain ones for changing a non-Vtec ecu to a Vtec ecu. Here's a guide on adding Vtec to an ecu -- http://mycomputerninja.com/~jon/www....1720-1500.html . My ecu seems to have all this stuff. I hate to ditch it and buy a new one before I know. So can anyone tell me for sure?
Old Feb 13, 2009 | 02:51 PM
93turbo16's Avatar
Default Re: Is this p05 ecu set up for Vtec?
Yep. It has vtec components installed.
Old Feb 13, 2009 | 04:05 PM
schmiddr2's Avatar
Thank you
Can I use it as is to run an non-Vtec set up? Can I just disable Vtec using Uberbdata?
Old Feb 13, 2009 | 04:27 PM
93turbo16's Avatar
Originally Posted by schmiddr2
Thank you
Yep. Just use a P75 map.
Old Feb 13, 2009 | 05:04 PM
schmiddr2's Avatar
That's freakin helpful!!! Thanks again
Old Feb 16, 2009 | 11:32 AM
HiProfile's Avatar
Just be wary if you do use VTEC. It looks like they didn't use the typical OEM-type SK5151 component (bottom right, IC14). It does work with a certain substitute, but the wrong part will throw a vtec code when enabled.
Old Feb 17, 2009 | 02:20 PM
illusive's Avatar
Thats a scary looking conversion job done on that ECU
Dave Brabant
Jun 28, 2018 01:17 PM
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
integra3586
Oct 15, 2007 03:22 AM
lebrecht22a1
Oct 15, 2006 11:08 AM
