Crome ECU Problems
Old Mar 13, 2009 | 10:04 PM
ls_turbo_#97's Avatar
Default Crome ECU Problems
I have the crome programmed ecu and before I got my car tuned I never had a problem. Now ever so often my likes to sputter and not let me give it gas hard as if its like backfiring. Does anyone have any solutions to my problem?
Old Mar 13, 2009 | 11:21 PM
jdmkid626's Avatar
Default Re: Crome ECU Problems
I would also like to noe..my car does the same thing..and it also iddles stooppid..all I can say is FUUWWWK CROME!!!
Old Mar 14, 2009 | 07:08 AM
THC07's Avatar
FUUWWWK yourself! dont blame **** on something you know nothing about.
OP, take it back to the tuner that tuned the car, tell him to correct it.
If he says the problem is not with the crome... get a secound opinion, then start trouble shooting, tps, fuel, things like that.
Old Mar 14, 2009 | 08:12 AM
koczeka's Avatar
Not Crome problem.
Old Mar 14, 2009 | 08:08 PM
N1 Andy's Avatar
R.I.P. Andy
I would say the tuner half assed partial throttle tuning, don't give chrome a bad name because your tuner or yourself doesn't know what he's doing.
Just because you have an ostrich and a chip burner does not make you a tuner.
Old Mar 14, 2009 | 09:57 PM
93turbo16's Avatar
What is your setup? If it has larger injectors it sounds like either a "hole" in the fuel map or a TPS enrichment problem. Which both lie in the tuning.
Old Mar 14, 2009 | 10:00 PM
supraccordlx's Avatar
Sounds like a timing issue. Post up the map.
Old Mar 15, 2009 | 05:59 PM
Ls_dx's Avatar
retard your NOSS timing, run 9's
Old Mar 16, 2009 | 06:24 PM
jdmkid626's Avatar
I got it tuned by eriks racing in Baldwin park..At first I thot that was the way it was suppose to b.iddling problems,backfiring when I gave it full throttle,starting problems. but then I talked to BC from Bisimoto n he had told me that crome wasn't reliable n most of his customers had blown motors from crome so he stoped tunning crome..im saying fuwwk Crome from my experience..I herd it was good thats y I ran that inda first place..
Old Mar 16, 2009 | 08:30 PM
jdmkid626's Avatar
not trying to give it a bad name or anything just that my experience wasn't good wit Crome..
Old Mar 16, 2009 | 08:34 PM
THC07's Avatar
That’s ridiculous!
Go spend 500$ on hondata, if you cant operate Crome.
Hondata for dummies, has an easy user interface.
Old Mar 20, 2009 | 12:08 AM
v8killaz's Avatar
chrome is easy as ***
im a noob at tuning and i know how to work it
but whats ur afr
B16-CRX
Engine Management and Tuning
26
Jul 2, 2011 02:25 PM
Dan_the_MaN
Oct 26, 2005 08:33 PM
PolySquared
Nov 29, 2003 06:09 PM
