crank sensor? b16a2
Old Feb 27, 2009 | 01:42 AM
delsolicious's Avatar
New User
Icon6 crank sensor? b16a2
hey guys i have a del sol vti 1993. i have been told that the crank sensor is in the distributor, or just below the timing covers, or in the fuel pump. my distributor had gone but is now replaced and im still getting a code 04 (CKP crank position sensor) from the ecu. any suggestions? thanx guys!
Old Feb 27, 2009 | 09:39 AM
honda.lioness's Avatar
Default Re: crank sensor? b16a2
The CKP sensor is in the distributor housing for your Del Sol. (It is on the oil pump housing on some newer Civics yada.) You can get the basic idea of its location from the top drawing at http://honda.lioness.googlepages.com/distributorbearing
Double check: Did you reset the codes? Checked all wires to the sensor?
Have you messed with the wiring under dash much? If so, there's a post here by a guy who said his CKP wiring got messed up: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/cel-code-4-a-1796830/
Old Mar 3, 2009 | 03:43 AM
New User
yes cheers for the post, i'll look further into it. my car had been stolen so the wiring was messed up a bit, and my distributor had gone so i replaced it. i;ll let u know when ive solved it thanx.
gpwap1 s2k
Aug 27, 2010 03:25 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
gundamgsr
Jul 2, 2004 04:53 PM
Nvious R
Oct 28, 2003 06:27 PM
