vtec solenoid bad or sensor!?
Old Mar 9, 2009 | 06:03 PM
germanjohn1's Avatar
New User
Icon2 vtec solenoid bad or sensor!?
i have a swapped h22 and it has a rough idle on occasion and is not hitting vtec...still goes thru entire rpm range? anyone have any ideas as to it being the solenoid or sensor? please HELP!!???
Old Mar 9, 2009 | 06:15 PM
hondachris1994's Avatar
Default Re: vtec solenoid bad or sensor!?
do u have a CEL on. This is the wrong forum for this
Old Mar 9, 2009 | 06:18 PM
New User
wat is a CEL again? im kind of new to this kind of thing. just tryin to find some advice? wat forum would you suggest?
Old Mar 9, 2009 | 06:45 PM
THC07's Avatar
sounds like your oil level might be too low. CEL meaning a check engine light on your instrument cluster.
What ecu are you using? you might not have the right ecu, and thats NOT good for your h22.
Old Mar 10, 2009 | 03:47 PM
New User
im using a p28...ive thrown check engines before and its never effected it....could it be the sensor or solenoid causing this?
Old Mar 11, 2009 | 06:24 AM
THC07's Avatar
is that p28 chipped for an h22?
If not, it needs to be asap.
germanjohn1
Mar 12, 2009 05:58 PM
Novtecdohc
Nov 15, 2006 09:16 PM
AychTwenee2
May 29, 2004 11:05 PM
COMplex.
Jul 17, 2003 05:51 PM
