got a question
Old Jan 23, 2009 | 08:41 PM
blackedoutwk's Avatar
Default got a question
I have a 2000 civic dx with an lsv in it I just ordered a rywire jumper harness for obd2b to obd1 I am planning on hooking my neo up to it but do I wire the neo into the jumper harness or the body harness?
Old Jan 24, 2009 | 07:44 AM
sander's Avatar
2.7(p/t)
Default Re: got a question
I am only assuming your talking about an AFC-neo?
If that is the case, always try and wire in to the adapter harness just because it will save you headache in the long run if you decide and remove it later, then your body harness isn't all tore up.
Old Jan 24, 2009 | 08:09 AM
yes it is a afc-neo. and thxs for the help just wanted to make sure before i started to mess with wires
Ken Lam
Jan 22, 2017 08:38 AM
EFinAwesome
May 19, 2012 12:31 PM
D3U1LT
Jan 24, 2005 10:47 AM
