Crome Base map?
Old Jan 19, 2009 | 12:19 PM
Nick998's Avatar
Default Crome Base map?
Hey I just got the moates chip kit for my p30-010 ecu. It came with a blank chip and I was wondering if anyone has a good basemap for a stock B16A in a crx? I have access to a computer at my school with a chip burner so I would like to burn a map to this chip with crome.
My specs are a stock B16A with a header, full exhaust, and AEM Hybrid CAI. I would like knock sensor disabled, stock rev-limit (8200 right?), and V-tec kick in at 5000rpm.
I would be willing to pay for the map I just don't wanna have to buy a chip with the map already on it since I already have a blank chip and access to a burner.
Old Jan 19, 2009 | 12:24 PM
93turbo16's Avatar
Default Re: Crome Base map?
Just open up the P30 base file in crome and set the parameters to where you want them and save.
Then burn it to your chip.
Old Jan 19, 2009 | 12:33 PM
Nick998's Avatar
So the p30 basemap is alright? just set the vtec and other things the way I want them? as far as disabling things goes what is ELD, atmospheric pressure sensor, injector test circuit, and vtec speed check?
Old Jan 19, 2009 | 01:28 PM
GhostAccord's Avatar
I would suggest that you do some reading about EFI tuning and the basics of the Honda PGM-FI system before you go moving or disabling anything. You aren't goign to get any gains from moving the VTEC to where you want it. It has to be set to where the engine makes best use of it. For that you need a dyno.
If you are unsure what an ELD, baro sansor and VTEC speed check are then you need to do a some reasearch into how your car works. Try doing a Google search on each item and see what you can come up with.
Knowing as much as you can about each part of the PGM-FI system before you start messing around with it would be the good place to start. There is a sticky at the top of the page called "Good reading for tuners" give that a boo. And there are a few good books out there on EFI tuning as well.
Old Jan 19, 2009 | 05:37 PM
Nick998's Avatar
My Vtec doesn't kick in until 6200 rpms now which is kinda high for a B16 in a crx. My old OBD0 ecu had vtec kick in at 4500.
Old Jan 20, 2009 | 09:18 AM
Nick998's Avatar
when burning to a 27SF512 chip do i need to specify the hex number or anything?
Old Jan 20, 2009 | 10:14 AM
if your burning the chip from Crome. All you have to do is make sure you do a test connection. Then make sure that there is a Check in “Used for 27SF512” under File->Settings->Real Time Programming in Crome.
Or
Originally Posted by Relic1
chip start address - 08000
chip end address - 00ffff
buffer start address - 000000
buffer end address - 007fff
file offset - no idea, burn1 does not use that. I'd guess 000000 since there should be no offset since you're addressing the location directly with the 256 bytes of data.
Old Jan 20, 2009 | 10:36 AM
Nick998's Avatar
Im using a superpro/280 universal programmer they have the SST 27SF512 chip under devices. The only options I have when I first open the bin file are buffer address and file address. When I set the buffer address at 8000 it looks like it will burn on the latter half of the chip.
Old Jan 20, 2009 | 11:34 AM
kicked25th's Avatar
true
Old Jan 20, 2009 | 12:30 PM
Originally Posted by GhostAccord
Or
Old Dec 14, 2009 | 05:24 AM
A-Man's Avatar
hey anyone have a base map for a d16 with a close setup to mine?
i have a d16z1
with ycp 12:1cr
4-1 header
stock cam and head
please can anyone shed some light
Old Jul 17, 2010 | 03:36 PM
evo500's Avatar
i am in this same boat i have a p28 ecu in a b16a and need a base map and cant find one anywhere. all i can find is p30 in b16 or p28 in a d16
Old Jul 17, 2010 | 03:43 PM
A-Man's Avatar
im starting to think it doesnt matter what ecu you run. i think it just matters what engine u got.
but besides it saying d16/b16 as long as it has vtec. you can just use the base map fuel and ignition settings and copy them into a p28 ecu.
i dont see the difference. but i might b missing the point here
eg6bro
Engine Management and Tuning
12
Feb 25, 2012 12:27 PM
RiipTiide67
Aug 23, 2011 03:54 PM
gsxr1k05
Jan 15, 2007 12:58 PM
AZNracerx1989
Jan 16, 2006 07:41 PM
