running a chipped ecu without a chip?
Old Feb 3, 2009 | 07:04 AM
LS stretch's Avatar
Default running a chipped ecu without a chip?
ive searched but havent found a definate answer.
ive been told that you can use a jumper wire on two of the pins on where a chip would go on a chipped ecu and you can run the ecu as if it were never chipped or "stock" again.
The ecu i have and would like to do this to if at all possible is a P28
Old Feb 3, 2009 | 07:12 AM
mtber's Avatar
Default Re: running a chipped ecu without a chip?
You would remove/cut the jumper at j1 on the ecu.
For more information read http://www.phearable.net/tech
Old Feb 3, 2009 | 08:40 AM
LS stretch's Avatar
thanks
david76008
Engine Management and Tuning
32
Apr 1, 2009 07:07 AM
hondaEg_808
Mar 25, 2008 11:10 PM
95sloweg
Jan 14, 2008 05:46 PM
tubed-ef
May 2, 2007 11:35 AM
TypeR0wnz
Feb 15, 2003 04:47 AM
