??? about ECU
Old Feb 1, 2009 | 07:36 PM
speed_demon018's Avatar
Default ??? about ECU
I have a 94 civic d16z6 and my vtec dont kick in and my rev limiter is coming on at 6500 rpm so was just wondering if someone could answer me if this was an ECU problem
Old Feb 1, 2009 | 07:43 PM
mtber's Avatar
Default Re: ??? about ECU
Is your check engine light on ?
If so, check your codes & get back to us.
Old Feb 1, 2009 | 07:47 PM
no CEL
Old Feb 1, 2009 | 07:56 PM
mtber's Avatar
What is the exact model of the ecu? 37820-p28-a01 ?
Old Feb 1, 2009 | 07:57 PM
A02
Old Feb 2, 2009 | 04:23 AM
93turbo16's Avatar
Does the car get up to operating temperature?
Old Feb 2, 2009 | 11:40 AM
yes it does
Old Feb 2, 2009 | 02:02 PM
mtber's Avatar
I would suggest probing the vtec signal wire for 12 volts while performing a street test to see if the ecu is sending 12 volts to the vtec solenoid.
My guess is that you are not "feeling" vtec & thinking it isn't working when it actually is.
Old Feb 2, 2009 | 06:03 PM
this is not my first honda nor first single cam vtec its not a matter of feeling it i can t even here the motor speed up and then that would not explain why my rev limiter is coming on at 6500 instead of 7200 like it should
Old Feb 2, 2009 | 08:06 PM
93turbo16's Avatar
Still it is a good idea to test for 12v from the ecu to the vtec solenoid while driving. Just have a friend sit in there with a test light or voltmeter.
I have seen stock tachs be off that far, so who knows.
Brown House
Engine Management and Tuning
Dec 1, 2017 02:31 PM
error2k
Mar 3, 2010 12:47 PM
mayfly
22
Dec 21, 2008 10:48 AM
Nyquil_Accord
Sep 28, 2004 09:36 PM
wiber1
Mar 24, 2002 04:21 PM
