CEL on but no codes in hondata s300
Old Mar 11, 2009 | 09:20 AM
steven_highet's Avatar
Default CEL on but no codes in hondata s300
My cel is on even thou i dont have any codes in hondata. Anyone ever have this problem?
Old May 15, 2009 | 09:27 PM
SinglecamMitch's Avatar
Default Re: CEL on but no codes in hondata s300
sometimes i throw a code that wont flash when u jump it but if you veiw your codes on hondata smanger it will show a overheating code... Hope this helps
Old May 21, 2009 | 10:51 AM
10secivic's Avatar
what color is the light on the inside of the ecu ? If i remember correct it sould be green until you hit the log bottom then it transistions red and green. If its fed then there maybe a problem with the installation.
Old Jul 20, 2009 | 12:24 PM
honkyb18c's Avatar
single cam mitch
At the moment my s300 is tellin me that I am overheating yet i have another water temp gauge and the temp is fine....I am also throwing a CEL light.
Any explanation?
Old Jul 20, 2009 | 01:55 PM
mtber's Avatar
Originally Posted by honkyb18c
single cam mitch
Any explanation?
What is your water temperature reading while datalogging ?
Old Jul 20, 2009 | 08:15 PM
honkyb18c's Avatar
my water temp shows me around 96 celcius at highest maybe 97
Old Jul 21, 2009 | 04:48 AM
mtber's Avatar
What temperature is your water temperature overheat warning parameter set to ?
Old Jul 21, 2009 | 06:45 PM
honkyb18c's Avatar
i do not know...i no that NOTHING was changed in the hondata...
i swapped a b20vtec into my car...took my b18c out.
when i plugged everythin back in...i contine to get a ECT code...yet all sensors are plugged in
Old Jul 22, 2009 | 06:17 AM
mtber's Avatar
I repeat...
Old Jul 24, 2009 | 09:46 AM
honkyb18c's Avatar
the pronblem was my water temop sensor plug was loose...well the connectors are loose
Zaraki
Mar 31, 2008 08:26 PM
l2yanE
Oct 22, 2005 12:58 PM
KiNG $h!t
Nov 21, 2004 12:03 PM
FOrSfEd
Nov 16, 2003 03:09 PM
VisualAutoMotoring
Jul 28, 2003 10:47 AM
