Only one cyln running lean please help...
Old Feb 3, 2009 | 07:47 AM
fly_high_gsr's Avatar
Default Only one cyln running lean please help...
hi guys, i have 94 gs-r head with usdm itr pistons 81.5mm
skunk2 pro 1's cams
skunk2 springs and retainers
I tuned my car and put down 194hp and 136tq and car was tuned on chrome program. Now after 4 months i decided to check my spark plugs and see how its burning, so i take out every single spark plug 4 and 3 looking good so far and when i take out my spark plug in no 2 clyn here its get very interesting, spark plug has no tip. Wtf color was grey white and i know for sure it was running lean, so i replace spark plug and start my car took it for drive came back take it out still burning white, i dont know if its cold or lean, i went back to my tuner he added 10% more fuel and still burning white no difference. Last i switch injectors and still same problem, then i try to retard my ignition timing no luck, so now i'm just tired of this **** finally i give up with this motor .'Note' my cyln no 2 was helicoil because i messed up spark plug thread on head, i dont know if that can cause this to run lean or plug not going all the way or its going to much down where it cant burn gas fast enough, i need some help if u cant help dont waist my time and keep u'r comments to your self and if any one willing to help i appreciate it thanks.
I always use 93 octane
I USE ngk's 7 spark plug
I do not know why only one is running lean and what is really causing it, or is it my tuner who mess up.
Old Feb 3, 2009 | 07:43 PM
SolAssassin's Avatar
Default Re: Only one cyln running lean please help...
one way to get answers quick is by making multiple threads in the same forum with the same question
Old Feb 10, 2009 | 05:53 PM
postman's Avatar
if its on one cylinder , probably not a tune issue
fly_high_gsr
Engine Management and Tuning
Feb 3, 2009 10:47 AM
fly_high_gsr
Feb 3, 2009 10:25 AM
92CivicSiR2
Sep 22, 2004 01:30 PM
JDM R98
Aug 16, 2001 06:32 PM
