alternator help plz!
Old Feb 16, 2009 | 07:55 PM
jdm_speed's Avatar
Default alternator help plz!
im planning to put a new alternator belt on. all i need to do is loosen up the top adjusting bolt and slide the belt right off and put the new one on in no specific position right? and how tight does my belt need to be? thanks
Old Feb 18, 2009 | 01:01 AM
Jnote's Avatar
Default Re: alternator help plz!
thats all you need to do and you want your belt pretty tight so it dont fall off. get the belt as tight as you can by using a pry bar or a big wrench and then tighten it up. thats what i have always done and it has worked for me
jrzy2nR
Jan 20, 2006 05:25 PM
failed
Sep 4, 2005 05:59 AM
519[H]Si
May 25, 2004 09:25 PM
blackccoupe
Sep 23, 2003 03:00 PM
