nitrous through hondata
Old Feb 22, 2009 | 12:44 PM
1993gsrcivic's Avatar
Default nitrous through hondata
to run nitrous through hondata do you use a dry kit or a wet kit or it dont matter
Old Feb 22, 2009 | 01:27 PM
xenocron's Avatar
Default Re: nitrous through hondata
Doesnt matter...you can activate anything you need to with the outputs and a relay setup.
With a wet kit you wont need to add fuel when spraying but will still be able to pull appropriate amounts of timing. With a DRY kit, you will be able to add fuel and remove timing as necessary.
Old Feb 26, 2009 | 06:50 PM
jewjew bean's Avatar
how exactly does that work? Does it switch to a new fuel and ign maps?
Old Feb 26, 2009 | 10:10 PM
mtber's Avatar
You can set it up however you like. Simply read the hondata help files & review the software settings.
preludeshdriver
Nov 1, 2005 07:04 AM
nicklk
Jun 6, 2005 04:54 PM
TypeR1558
Mar 25, 2002 02:13 AM
