vtec not kicking in right
Old Jan 21, 2009 | 03:37 PM
boostedeghatch's Avatar
Default vtec not kicking in right
i have burned several maps with the willem eprom burner and they have all came out good with no problems. i have recently bought another civic and got a socketed p72 ecu. i burned an all motor map to a atmel at29c256 (the chips i've always used) with vtec set at 5300. i test drove the car and vtec will kick in at 6k all the time. i set the vtec at 5k and vtec will still kick on at 6k. i've tried reburning the map a few times, but i still get the same results. anyone have any idea why this would happen? i never had this problem before.
any thoughts.
Old Jan 21, 2009 | 04:27 PM
mtber's Avatar
Default Re: vtec not kicking in right
1. Verify the data on your eprom chip
2. Try setting vtec at 4500 rpms just for testing
Old Jan 21, 2009 | 08:16 PM
verify it after i burn the map on it? its been like over a year since i burned chips, so i may be leaving something out.. dunno.
i will test it at 4500 on my next day off and see what happens
i put the chip in the burner
i check the id
erase chip
do a blank test
verify chip
clear buffer
then i load the map
then i burn the map on the chip
i think that the order i do it in. i'm using crome with a willems burner
Old Jan 21, 2009 | 08:28 PM
mtber's Avatar
Sounds like you are doing it correctly.
When you open the .bin file is the vtec point what you previously saved it at ?
Perhaps your tachometer is off ?
Old Jan 22, 2009 | 03:27 AM
yeah, the vtec is still set at 5300 when i open the .bin
i thought about the stock tach being off, but i tried a friends ecu when i first got the car running and his vtec is set at 4800, but with i think an h22 map, and it kicked in right at 4800.
i tried another chip this morning and vtec still kicked in at 6k. i'll reburn it and set vtec at 4500 to see what happens.
also, i did burn my friend a chip and the same thing happened to him. vtec set at 5200 on his chip, but it didn't kick in until 6k. he drives a 99 si . before i reburned a new map for him, vtec was kicking in at 5300 where vtec was set at on the previous map.
when i burn the .bin on the chip, the buffer won't stay at 800 correct ? (its like xx800 when you clear the buffer, don't remember exactly what it is. i'm not at home or i would check)
i would like to try one of your chips, but i would just hate to buy one and the same thing happens you know.
Old Jan 22, 2009 | 08:56 AM
Spunkster's Avatar
Maybe J1 has been cut
Old Jan 22, 2009 | 09:25 AM
you think that would cause vtec to kick in later than what its set at?
i'm going to get a friends chip and try it out in my ecu to check if vtec kicks in where his vtec is set at. i'm not sure who he got his chip from , but i know vtec kicks in when it should on his car.
Old Jan 22, 2009 | 03:56 PM
mtber's Avatar
If j1 is not properly jumpered the ecu is not reading the chip at all, hence the reason your chip is not doing anything.
Old Jan 22, 2009 | 04:48 PM
then wouldn't i get a check engine light if its not reading the chip right? i have a gsr motor in a eg hatch. i don't have the knock sensor, iabs, or an o2 sensor. they are disabled via the .bin. if it wasn't reading the chip, i would think i'd get a cel ....
Old Jan 22, 2009 | 08:04 PM
mtber's Avatar
Yes, you probably would :-)
Old Jan 24, 2009 | 04:21 AM
i got a chip from my friend and tried it out in my ecu. the vtec on his chip is set at 4800 and when i tested it in my ecu, vtec kicked in right at 4800.
think something with the willem burner is not right?
fasterthanueg
Jun 16, 2013 06:51 AM
Coutts
Engine Management and Tuning
Jul 16, 2010 12:36 AM
chu77
Sep 28, 2006 07:28 AM
Metal Head
Jun 8, 2006 11:19 PM
Metal Head
Jun 3, 2006 03:53 PM
