wiring up a o2 sensor simulator
Old Feb 10, 2009 | 04:29 PM
GsrIntegra789's Avatar
Default wiring up a o2 sensor simulator
hey guys. im trying to figure out how to wire up an o2 sensor simulator for the secondary sensor. I bought this simulator http://www.o2simulator.com/index.php...products_id=14
the wires on it are white, black, red, yellow. my question is how exactly do you wire it in. do you still need to have the o2 sensor there? or do you cut the o2 out and just use the clip. now what colors go to what . on the o2 clip the colors are black,black,white , green. Is anyone using this? Can you guys please help me out i need to pass inspection
Old Feb 10, 2009 | 07:03 PM
Default Re: wiring up a o2 sensor simulator
come on guys someone help me here.
Old Feb 10, 2009 | 07:16 PM
Blown90hatcH's Avatar
Designed for Acura only installation.
Will NOT work for RSX.
Completely sealed waterproof package.
Small size 1"x0.25"x0.25"
1 Year warranty.
Secondary sensor signal is required.
Can not be used with heater resistor.
NOT for primary o2 sensor.
Off-road use only
....So you need a secondary O2 signal, you can not use for your primary O2 and you can't use a heated resistor setup....hmmm what's left?
Old Feb 11, 2009 | 02:06 PM
this is for the secondary o2 sensor the reason for it is because i dont have a cat. I need to know what color goes to what ...
Old Feb 11, 2009 | 08:37 PM
Tomdata's Avatar
those things are a joke. They never work right. If you already don't have a cat on your car then you obviously don't care about emissions. Just get and OBD2-OBD1 conversion harness and a properly tuned OBD1 ecu.
Old Feb 13, 2009 | 11:20 AM
thanks. but thats not the problem. here to pass inspection you need a stock ecu. my car is not stock, i turboed it last summer. But in order to pass inspection i had to put my stock injectors back in stock ecu, evap sensor. all of my monitors have set in except the secondary o2 . and that will never set in bc i dotn ahve a cat which is why i wanted to use a simulator to get rid of the MIL.
phoshyzzle
Oct 18, 2009 07:52 PM
rasinhell
Jun 22, 2005 04:16 AM
donton
May 2, 2005 03:52 PM
boostinb18
Jul 26, 2002 01:31 PM
