ignition timing??
Old Jan 29, 2009 | 12:20 PM
I CRX I's Avatar
Default ignition timing??
how would one read ignition timing from the ECU? im usuing freelog but i dont understand how the ignition timeing is read.
Old Jan 29, 2009 | 09:14 PM
98vtec's Avatar
moderator emeritus
Default Re: ignition timing??
those freeware programs cannot read ignition timing.
you'll need something like eCtune, Neptune, or hondata or any of the standalones to properly datalog actual ignition timing. the timing you see in the table is often not what the engine sees.
Old Jan 30, 2009 | 05:59 AM
I CRX I's Avatar
but arent all these programs pulling from the same place in the ecu? how would i be able to read them from say a hondata program? ive heard that most hondas are @ 16 degrees of timing from factory but is that at idle or across the board?? just a little confused on this whole timing thing
Old Jan 30, 2009 | 07:11 AM
dyingwish's Avatar
Honda specs 16* BTDC, +/- 2*. That is your base timing. The ECU makes changes in closed loop operation to meet preset running conditions based on current sensor values. Only the above mentioned system monitor BOTH table ignition values, and actual ignition values that the ECU is actively adjusting.
eg grom
Jun 25, 2009 09:27 PM
jdmb16ef8
10
May 4, 2008 04:47 AM
maxmax
May 14, 2006 03:37 PM
RTW DC2R
Mar 9, 2004 09:09 AM
