On the cheap
Old Mar 2, 2009 | 12:13 PM
4drEF's Avatar
Keyboard Humorist
Default On the cheap
As I'm piecing this car back together after a blown transmission I have put together a decent turbo kit for it. Motor is a D16Z6 block with OEM Y8 pistons, Y8 head, Y8 intake manifold (guess that is pretty much a Y8 motor now?) I have a virgin P28 as well as a P06 that's supposedly been converted to run vtec and boost (I have only opened it up to verify that it's been chipped).
I've never taken a car to a tuner before, but I KNOW that's what needs to happen when I get this running again. I plan on running the P06, but I will run a basemap from Phearable for the short while before taking it in for a tune. Would there any benifit to be found by chipping the P28 and using it instead of the P06?
This will be a daily driver hoping to put down 180~200hp. What else do I need to buy before I go for a tune? It seems that ECTune+Ostritch is the big thing right now, but is there a less expensive way I can go about this without compromising reliabilty?
Old Mar 2, 2009 | 06:46 PM
mtber's Avatar
Default Re: On the cheap
If the p06 was properly converted to vtec, there will be no difference between the p06 and p28's performance.
Reliability is generally found in tuning & a well put together vehicle (craftsmanship).
rpmraper
10
Jun 12, 2011 08:25 AM
senate33
Apr 23, 2007 07:25 PM
gmcrxsi
Aug 13, 2005 12:27 PM
Doug684
Jan 8, 2005 12:51 PM
