Ignition Base timing with cam gears
Old Mar 15, 2009 | 11:17 PM
mrx's Avatar
mrx
Default Ignition Base timing with cam gears
Hallo,
i've a small question. Then turning the intake cam with cam gears, you are not able to dial in the base timing (15-16°) with the distributor any more when going above +/- 4°CRK on the cam gear.
When then turning the cam gear for example to 6°CRK the base timing is far more off then additional 2°CRK - why is this like that?
and how do you tune the ignition base timing back to normal?
Best regards
cliff666
Apr 19, 2006 10:49 AM
[HrZn]4life
May 13, 2003 03:17 PM
Jockobo
Jan 23, 2003 03:48 PM
slowman
Nov 29, 2002 05:27 PM
Black96Cobra
Oct 28, 2001 11:06 PM
