burned up computer?
Old Feb 28, 2009 | 05:17 PM
slowturbocx's Avatar
Default burned up computer?
can someone tell me if this controls an output of power. I assume this because i am getting a code 21. I am not getting any power from the computer to the silinoid.
Old Feb 28, 2009 | 05:26 PM
mtber's Avatar
Default Re: burned up computer?
q31 has nothing to do with vtec.
From the picture you posted, it looks like some one converted your ecu to vtec using a generic transistor. Your code 21 issue is probably due to a faulty vtec conversion by who ever chipped the ecu.
Concerning q31 being burned, you probably plugged your evap purge solenoid into your intake air temperature sensor, damaging your intake air temperature sensor & your q31 transistor. Simply replace the intake air temperature sensor & remove the transistor at q31, the ecu should still function.
Good luck!
Old Feb 28, 2009 | 05:30 PM
hmmm. i did have a problem with the air intake temp sensor before and i changed it. the problem now however is im not getting power from a4. could you point me in the right direction as to what i am looking for here? thank you for your fast *** reply.
Old Feb 28, 2009 | 05:32 PM
mtber's Avatar
Honestly I couldn't tell you what your problem is with your vtec converted ecu. As I mentioned before it doesn't look like a very professional conversion. The issue could be anything....
Check your wiring to ensure you have the proper wires running to the iat sensor.
Old Feb 28, 2009 | 06:10 PM
Relic1's Avatar
the issue may be related, remove the blown part and go from there.
the fundamental questions... has it ever worked?
what have you changed since it worked?
When did it stop working?
Old Feb 28, 2009 | 10:35 PM
RACEPAK's Avatar
just a quick question. can a vtec/pwm convertion may pop a cel 22?
Old Mar 1, 2009 | 09:47 AM
mtber's Avatar
vtec & pwm have nothing to do with each other. By the looks of your ecu pictures, your ecu does not have pwm support added to it.
The code 22 can be due to not having a vtec pressure switch or it maybe due to a poor vtec conversion.
Old Mar 2, 2009 | 11:04 AM
zCivic's Avatar
I think I found the problem. There is no jumper in J10 below the C60: 1uF 35v tantalum. Make sure but from what I can see there is no jumper in place there. Also check IC14 and see if you can read anything on it like 5050 or 5151 because when I tried to be cheap and reuse 5050's they very rarely worked correctly. Is it engaging vtec then CEL or is it never engaging and starts with a CEL.
Old Mar 2, 2009 | 01:16 PM
thanks guys.
Old Mar 4, 2009 | 12:18 PM
boosted k20's Avatar
u can only use the 505 for vtec conversion on the older style circuit boards. the new style board, u must use the 515 or else u will get a CEL for vtec after it pops for the 1st time
Old Mar 5, 2009 | 01:38 PM
zCivic's Avatar
This is partly true even if you use 5050 in older boards they will give a CEL more often then not.
Old Mar 5, 2009 | 04:41 PM
93turbo16's Avatar
Not really. The 5050s work perfectly fine for the older boards...
ek9adrian
Jul 31, 2007 10:38 PM
civicdragger818
Oct 24, 2002 07:10 AM
DLB1994
Aug 18, 2002 03:42 PM
DLB1994
Aug 18, 2002 03:29 PM
