how hard is it to chip a ecu?
Old Mar 14, 2009 | 09:16 PM
honda_guy_07's Avatar
Default how hard is it to chip a ecu?
whats all needed to do this and what the best ecu to chipp everyone around here is running p28s is there anything better then that
Old Mar 14, 2009 | 09:54 PM
93turbo16's Avatar
Default Re: how hard is it to chip a ecu?
I think you need to read a few threads that are located in the FAQ at the top of this forum!
But otherwise.. it is not that difficult to chip a obd1 honda ecu. BUT if you are not very good with a soldering iron or haven't soldered small printed circuit boards before, i would suggest just having the ecu sent out and chipped professionally. As I have personally seen dozens of ecus that were ruined by a few people who thought they knew how to solder.
Old Mar 14, 2009 | 09:55 PM
mtber's Avatar
View the video on http://www.phearable.net/tech
I do not recommend you try chipping an ecu without practicing on a useless ecu. I also recommend using high quality tools or leaving it to a professional.
Old Mar 14, 2009 | 09:58 PM
supraccordlx's Avatar
If you can solder and desolder with out cooking up boards it's not that difficult. Practice on junk ecus or other small circuits. The p28 is used because it's already vtec: the p06, p75, etc need to be converted to vtec along with chipping. If you need some one to chip your ecu just shoot me a pm.
nihad
May 3, 2009 10:20 AM
Doubledeala
Oct 15, 2004 05:00 AM
bigwig
Oct 14, 2003 02:19 PM
ls95hatch
Mar 15, 2003 03:02 PM
