- Brake pedal intermittently and unpredictably soft/spongy
- Drivers side floorboard soaked after rain. (2005 EX)
- Wiper Issue - I replaced everything and still faulty
- em2 on d2 coil overs
- Timing belt
- Parking Brake Stuck?
- 03 civic hybrid stalls on start up
- Passanger high beam not working.
- How to open the hood on a 05 honda civic with broken cable and not attached.
- 2003 civic keyless entry not working.
- Is my head gasket blown?
- 2003 Civic won’t rev past 3500
- Car starts then shuts off
- Help sorting issues on new 2003 EX purchase (mainly locking system)
- Car not responding to working key fobs
- Overflow way too full, radiator empty
- Help?
- Circle track '02 Civic EX entering Limp Mode
- ‘03 EX Blown Head Gasket
- 02 civic
- 2005 Honda Civiv new ignition switch crank no start
- P1457 Code???
- Car idles very high and then low after engine swap.
- Connecting rod nut thread
- Civic 2004 LX front crankshaft oil seal remove and replacement cost
- 2001 Civic EX, need help identifying sensor
- Honda amd hyundai trans swap
- Gearbox/ rev.
- Stripped Thread Valve Cover 2003 civic lx
- 2002 Honda Civic Help!
- 2003 civic clutch install
- 7th gen ECU Help
- reciever/dryer replacement 2002 civic ex
- Clutch cover oil leak?
- Intake manifold gasket problem
- 02 Honda Civic ex
- 2004 Civic running without thermostat?
- D17 turbo down pipe
- Door Jamb switch
- New Timing belt tensioner belt rides off edge
- 2003 honda civic
- HVACR tech
- ECU programmble chip
- Headliner parts needed, cant find part numbers
- 02 Honda Civic dx engine swap
- P1298 code. What is this
- Sudden loss of tachometer
- First time motor swap
- 2005 Civic power locks intermittently not working
- 2004 D15b I believe it is a jdm. Need info
- Speakers only play sound sometimes
- Ac compressor bypass
- No brakes, and believe me I’ve tried all I know
- Transmission swap USDM to JDM
- 2003 Civic gets slightly hotter than normal
- 2005 Civic LX 1.7 small braided tube
- Cleaning rust on wheels
- Manual shift cable bushing?
- Car wiper blades
- ABS LIGHT IN DASH.
- Rear Sedan exterior handles
- Civic overheating issue... sometimes. help!
- DIY Door lock switch?
- Blown 80a fuse
- Valve Clearance 2003 Honda Civic LX
- Need some help turboing my d17a2
- 2005 civic immobilizer bypass
- Used Ignition switch
- Need help with 2001 Civic EX P0335 fix
- Auto Dim Mirror
- D17A Swap - gasket/seals/parts replacements
- Weird cluster issue
- Blow off valve line to intake manifold
- Can a faulty ignition switch cause my dashboard and PRND32 to not work??
- Can’t find a short shifter for my 2001 civic
- Aftermarket speakers
- Possible cooling system/electrical issues?
- Stuck in drive
- ODB2 Scan Post Crash
- Tom motorsport exhaust?
- Engine ran, quit and now won't start
- Wheel question
- Thermostat housing on 03 Civic LX pouring out water by thermostat
- 02 Civic LX 5lug swap
- Water Leak Driving me Crazy
- Replaced all the keys the easy (cheap) way
- Bad alternator?
- Head swap on 01 civic non vtech to vtech
- Engine swaps/motor mod ideas
- Installed battery backwards
- Root cause of ISB failure
- 2001 LX 4 Door, Crank, No Start with a twist. Please!
- Check Engine Codes
- Weird grinding clunk sound when accelerating/under low rpmload
- 2004 civic DX- high pitched whine when accelerating. quiet rattle/grind when coasting
- Manual Tranny Countershaft Locknut Torque Spec?
- Changing trans fluid at 100k miles
- How to lock off drive 3 on auto shifter drive 3 itself causes ecu to short
- 2005 Honda Civic Sedan rear seats won't lock
- 10w-40 to 5w-20
- 04 civic VP
- Putting 3 way speakers in the doors,any good places for mids?
- Anyone that might have a front shock off or old one laying around?
- 2001 Civic with SRS light
- 02 civic ex whirring noise after changing rockers
- No compression on cylinders 1 and 4
- 80-01 (p0401) egr system leak detected
- Facing problem of gear in high speed.
- 2004 civic LX K24a2 MT ecu
- Overheating
- 2002 Honda Civic oil pain constant leak
- Shuts off in the rain
- D17a2 build
- Tranny whining. Not shifting when warmed up.
- 2002 driver-side floor water leak, No Moonroof
- SRS Lite Questions, Help...
- K24A swap 2004 Civic LX Sedan
- D17 build
- D17A2 Blown Headgasket Advice
- 2002 Civic Issues?
- D17A JDM Engine VTEC Controller
- Stuck cv axle
- 2005 Honda timing belt OEM or...
- AC Compressor Locked Up?
- 2001 ES5 transmission sometimes being driven with disengaged clutch
- 2001 Honda Civic LX 4dr need help
- Check Engine light with paper clip, 04 civic ex
- 2001 Civic gauge cluster light/ Instrumental panel bulb
- Header
- Radiator fan doesn't kick on-2002 Honda Civic ex
- 2005 honda civic
- Wiring diagram for a/c
- 2005 Civic Hybrid keyless entry
- Emissions warning light
- Blower Motor Noisy
- Which transmission should I choose?
- 2001 civic with no power past 2500 rpm
- Engine grinding on startup. Not stopping
- Engine bolt into timing co er
- Soaking wet passenger floor
- Loud noise from passenger side front wheel
- HELP I NEED TO IDENTIFY THIS CONNECTOR
- Revolutions are slammed down and my civic goes off
- Battery "Issues"
- D17A2 high compression
- Help identifying a hose
- Honda Civic Hybrid 2005 CMP Location PLEASE HELP
- Odometer button
- D17A2 and 5 speed trans swap
- A/C belt makes awful sqeal noise when on
- P0135, battery light, evap, cat, egr, o2s Monitors not ready
- 2002 Civic BMXA Trans rebuilt, started slipping again
- Guy put 6 quarts of CVT fluid in the AT
- 2002 Civic EX 1.7 P0118/P1298
- D17A1 to D17A/A2 wiring
- Low compression after replacing head gasket
- fuel injector power doesn't pulse
- Car coolant temperature
- How much is my car worth
- Barely Passed Inspection
- VXDiag VCX nano pro
- D17A2 rebuilt head install questions
- Rough Idle after Startup when Engine hot
- Crank. No Start.
- Problems after replacing ELD '04Civic LX
- Honda Civic 2005 power connection problems?
- 2003 Civic EX Rattling
- 2005 Civic EX pulsing headlights, interior lights
- Low MPG
- Ignition wires
- 2004 Honda Civic LX SRS Codes ?
- 01 civic rear defroster not working
- New Civic owner here.
- CRAZY dash , headlights and car dies then starts right back up
- Fuel Consumption
- Cruise Control buttons Light up, Don't maintain speed.
- Headlights killing battery
- Flickering/Pulsing lights
- 215 60 R16 Snow Tires on an 07 Civic EX?
- Code 1457 on 2005 Civic
- 2001 LX no spark
- water inside the Honda Civic 2005 SE
- Major idle issue on my 04 civic ex
- Tire size
- Tints
- 2001 civic ex dead
- 2005 civic guage cluster
- 01 civic coupe fender flares?
- Blower motor fuse and relays
- No crank/ noise when I turn key
- Timing belt tensioner
- 04 civic engine change help
- Service Check Connector - Honda Civic LX 2002
- Civic having hesitation, weird shifting, and randomly overheats.
- 7th gen Civic A/T grinding while upshifting
- D17A1 water pump
- An Ignition switch question
- How to set head to TDC?
- 2001 Civic battery light
- Overheating problem
- Help
- 2002 Civic Mods?
- Key Stuck, P and D Lights
- Check engine light on with transmission woes.
- "BRAKE" light stays on dashboard
- smells like somthing is burning under the hood and lot other problems
- Removal of 2001 civic EX sunroof mechanicals for more headroom
- Civic 2002 cluster swap Question
- 2005 Honda Civic 1.7l Stalling Trouble + Relay clicking
- 2004 Civic EX 1.7 Manual Sedan Throwing codes 304,303p,304p, & 300p
- GTX3576 GEN2 vs GTX3076 GEN2
- Stiff clutch all a sudden?
- Low & High Beams (Headlights) - Weird Behavior (Not Working)
- Slight grinding at high revs
- 2003 civic only starts with a coad reader plugged in
- Dash Lights Failing in Civic 2004 LX
- Car smells like GAS
- Tail/Stop light .&. Starting gremlins
- Lost fuel
- SRS
- 2003 Civic Hybrid has thumping at take off
- Brembo brake calipers
- 2001 HONDA CIVIC
- Cam & Crank Shaft Sensor Repleaced but not fixed
- HVAC duct work and heat irregularities
- green key light flashing whilst driving.
- 2001 Honda Civic Brake light/ Starting issues
- P0720 but speedometer is normal
- No power to IAT sensor.
- 04 civic ex looking for good crv swap
- Parts needed for a manual transmission swap
- 02 civic ex in and out of limp mode
- Will tight belt put extra stress on battery?
- Can i pair an OEM Honda FOB to my 04 Special Edition(CDM model)
- Criuse control does not work
- Ran my 05 Civic out of gas and she isn’t happy!!
- CLUSTER SWAP
- D light indicator blinking
- 7th gen civic cylinder 4 misfire - odd situation? HELP NEEDED :)
- Key remote not working on Honda Civic 2003
- Tokico Adjustment Tool
- 2005 Honda Civic VP 1.7L Valve cover gasket
- 2002 Civic LX losing power completely
- EGR Valve
- hydraulics
- Fender flares em2
- High compression E85
- Engine hesitation when going over 80mph, Codes P0300-4
- radiator blowing up
