PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. 2003 Honda Civic vibration
  2. Heavy duty engine mount recommendation?
  3. Service Manual Circuit Diagram Symbols
  4. 2002 Honda Civic Electrical Woes - Need Expert Help!
  5. Ready monitors not completing
  6. 05 Civic, Canadian Si, Leaking coolant
  7. 2003 civic Radio Fades out , comes back on
  8. 2005 Civic Ex Special Edition
  9. EP3 questions to a new owner
  10. NEED HELP WITH HONDA CIVIC EX 2002
  11. 'Key in' alert and 'headlights on' warning has stopped working
  12. 03 Civic d17 5 speed clutch problem
  13. Car dies when braking/stopping
  14. What is this part?
  15. Bell housing leak? Broken bolt?
  16. Vtec Swap to Non Vtec
  17. Rev9 wastegate
  18. Engine destroyed???
  19. Oil pressure light on ,please help!!
  20. Driver's side front window stuck down
  21. Wonky shifting
  22. 2004 Honda civic hybrid
  23. 2001 Honda Civic lock problems
  24. HELP PLEASE!!! Cylinder 3 bending valves
  25. Possible bad head gasket
  26. 02 D17 Crank No start
  27. Overheating Issue 2024! Is it worth buying new D17???
  28. 2003 Honda Civic Turbocharger Upgrade
  29. D17A wtih non-vtec Head
  30. 2001 CIVIC EX WONT IDLE
  31. Do you need a special lower bolt for exh man heat shield?
  32. Timing belt
  33. B18b1 help!
  34. Fog Light Switch Bulbs
  35. JDM swap non VTEC won’t start.
  36. What's a good way to detail or refinish my transmission before I reinstall it?
  37. Honda Civic 2002 1.7 manual transmission
  38. Positive battery cable help 2002 Honda civic
  39. HONDA CIVIC EP2 D16V1 WHAT SHOULD I DO ??!!
  40. Please help
  41. 2004 civic stuck in 2nd gear ! Help
  42. What is this bracket?
  43. What is this clip?
  44. Flywheel replacement
  45. 2002 civic si start problem
  46. Rpm drop in neutral
  47. Skunk2 drop in cams and Stock PRB intake manifold
  48. Proper tool to bend inner tie rod lock washer?
  49. Re-pack tie rod end with grease?
  50. Should inner tie rod threads get anti-seize?
  51. Crank sensor delete on em2
  52. Give me some options
  53. Worth rebuilding transmission while it's out?
  54. CAN ANYONE HELP ? BRAKES LOCK (DRAGGING)
  55. How many bolts mount 01 Civic manual trans to engine?
  56. Seems like these engines pull a lot of threads
  57. Trans mount bolt won't budge
  58. What connector is this?
  59. Passenger Window stuck in the up postion
  60. Long Buzzer sound when braking at end of pedal - any help is appreciated
  61. (02) Civic GX NGV Cranks but won't Start.
  62. 2001 Accord - Misfire P1399
  63. Is there a Name for this cap?
  64. 2005 civic em2
  65. Chassis
  66. 05 Civic 1.7 #3 misfire
  67. 2001 civic clicking noise when coasting/slowing down
  68. 03 Civic Climate controls NOT WORKING
  69. 2003 Honda Civic Hybrid throwing P1655
  70. HELP: I need help Finding what the retaining clip is called on top of fuel pump;
  71. Battery light stays on
  72. Speakers not working
  73. Right high beam doesn’t work
  74. First post new to the forum
  75. Radio issues.
  76. 2002 honda civic problem
  77. Manual Trans Pops out of 2nd gear
  78. 2002 civic HELP four door 1.7 litre delete ac PLEASE
  79. Short term air/fuel trim messed up
  80. 2002 Civic 1.6L, alternator output 12.7v.
  81. No Dash Info and Stuck in park
  82. 2001 honda civic lx passenger door lock pin/clip
  83. Tough Troubleshoot
  84. 2001 civic ex coupe
  85. Help with k series Transmission
  86. Honda civic transmission
  87. 2004 Civic LX power steering whine
  88. 2003 Honda Civic Small Red Light Cntr Console
  89. Over heating
  90. Does the ECM change ignition timing and fuel mixture with bad downstream o2 sensor?
  91. Vibration in steering wheel
  92. Honda Civic ep2 won’t stay running.
  93. Leaky Exhaust valve help!
  94. 2002 Honda Civic Ex
  95. Intake manifold clogged
  96. What new transmission for a 2003 Honda civic executive to make 170hp
  97. 2003 Honda civic ex coupe condensate drain leaking coolant
  98. Need help!! Fans not working unless jumped or A/C on (only for 1 minute)
  99. Trying to identify plug
  100. Please help me find out where this sound is coming from! (Video included)
  101. Honda Civic Dimension 2001 shifting problem
  102. 2004 Honda Civic DX power distribution box (fuse box under under) wiring diagram
  103. 2002 Honda Civic battery light flickering new battery/new alternator
  104. Limp mode
  105. Maintenance questions
  106. Civic 2005 key fob reprograms successfully but does not work
  107. 12v light and IMA light after getting BOTH batteries replaced
  108. Need help with power steering
  109. Engine and head combinations
  110. Economy Remap on 55 Civic 1.4 SE
  111. Anyone know of a seal conditioner that works?
  112. EP3 Style Spoiler
  113. HELP extra bolt
  114. APPLE CARPLAY HELP
  115. Help
  116. Immobilizer and key
  117. Ep3 Type R skirts on EM2 (Possible?)
  118. Heat issues
  119. Lurching sensation in 3rd gear
  120. 01 civic No power
  121. D16y8 Intake Manifold on D17a2 (I think?)
  122. 2001 Honda Civic Swing No Start
  123. 01-05 Hybrid 1.3L Manual Clutch?
  124. P1298 code secondary code
  125. C0300 code on 2002 EU8, no performance issues
  126. 2005 Sedan Door and fender swap
  127. 2002 Engine into 2004 model
  128. rough shifting
  129. Should I have the tranny fluid changed?
  130. 2004 civic lx transmission on a 2005 civic ex??
  131. Car starts and idles until warm, then sputters and jerks once in gear.
  132. Headlights
  133. 2001 Civic HX starts and idles fine but stalls under load once warmed up
  134. engine light
  135. Need help determining source of oil leak
  136. Swapped Transimission For JDM.
  137. Engine seized up???
  138. No flow to upper radiator hose, water pump checked, good, new thermostat, flushed rad
  139. Lifter noise/loss of power/stalling/overheating
  140. 01 civic ex Kswap and manual swap
  141. TRANSMISSION PROBLEM
  142. 2005 Civic Flashing Green Key (Crank No Start) Please Help
  143. ECM Part Numbers and Replacement
  144. broke my front axle. stupid question. do I have to tow this home?
  145. 2003 Civic EX dashboard gauges malfunction
  146. Freeze plug on head missing after machine shop. Will JB weld hold??
  147. Squealing noise mainly when dowsnhifit
  148. No brake lights 2004 Civic
  149. I have a strange problem with my 2004 civic lx with the transmission.
  150. PLM-L04 Pinout - 2004 Civic EX
  151. Honda civic
  152. 2002 Honda Civic EX Crank No Start
  153. 2001 Civic Camber
  154. 2003 ex vs 2005 lx VVT Solenoid
  155. can't find parts in South Africa
  156. 2001 Automatic Honda civic DX changes gears but doesn’t move
  157. 2004 Civic has spark and timing is right, won't start
  158. Looking to Buy Civic - wierd noise on acceleration
  159. Boosted d17a1
  160. How big of rims can I go?
  161. 03 civic ex has no power on acceleration
  162. 2005 Honda civic lx coupe automatic 02 sensor
  163. Need Help With Stalling Tried Everything - 2005 Civic
  164. 03 Civic EX complete rebuild help and advise
  165. Anchor for engine mount
  166. 02 Honda Civic EX Transmission
  167. 2001. Honda civic timebelt tensioner bolt hole is it fixable help!!!!!
  168. Throttle body swap with JDM engine
  169. Codes P0108 and P0113 After Valve Adjustment
  170. Code on radio
  171. Weird sound while coasting
  172. need some advice here. car is dead, thinking of part out?
  173. 2002 Honda Civic ex coupe, is this damage repairable if so what's the estimated cost?
  174. Where to buy after market car parts?
  175. 2003 Honda Civic lx 1.7l starts rough but dies after idling up
  176. 04 Honda Civic clutch problem
  177. Engine Knocking on Heavens Door
  178. 2001 Honda civic ex wont shift past reverse? please help!
  179. Civic 2004 - Auto Trans
  180. What's going on?! , 😭
  181. Honda Civic LX 2001
  182. Schematics
  183. Throttle cable loose from gas pedal.
  184. 2002 Civic SI - Disconnecting VTEC valve electrical connectors
  185. Running slightly rich
  186. Honda tires
  187. P1259 DTC: VTEC quit working
  188. 2004 Civic EX Auto
  189. '05 Civic front driver turn signal light stays on but won't flash
  190. Car shuts off at a stop, multiple engine codes.
  191. Intake /ram air/plenum needed ?
  192. 2001 civic LX
  193. 2003 Civic DX Problems
  194. 7TH GEN SPECIFIC Ball joint kit + adapters
  195. 2005 Civic Coupe - Issues
  196. ALL POSSIBLE OIL LEAK POINTS on a GEN 7 CIVIC
  197. 04 odometer mileage only not lit up.....
  198. 2002 EX Cluster in 2004 Value Package?
  199. EP3 EPS and ABS light turns on
  200. Recent ignition interlock install causing problems
  201. Alternator charging @ 11.5v. Running fine. Should I expect trouble?
  202. 2002 Civic EX P0301
  203. Cooling hoses
  204. Head Gasket Issues
  205. 2001 odd idle issue
  206. heater issues
  207. 2002 Civic SI (hatchback) transmission leak
  208. Battery postive cable routing.
  209. Ep2 ECU pinouts
  210. Odd A/C issue
  211. Ignition Tumbler Issue
  212. Honda Civic 03 D17A1 to D17A2 question
  213. 👋Hello all of my Honda Fans 🤜🤛 bmxa trans help
  214. 2005 Civic fuel pressure
  215. 2004 Honda civic hybird won’t start or crank
  216. Cracked EGR valve?
  217. AC nightmare help
  218. Engine and ECU swap help
  219. Oil Block
  220. Can someone help me Identify this distributor?
  221. I just put a 2001 LX 5 speed on the road and there's a few issues
  222. Hazzard not working Honda civic ep2 2004
  223. 5th gear pop out advice
  224. Coolant leak above oil filter! Need to resolve ASAP!!!
  225. '02 Civic Hood Release Replacement -not broken plastic-
  226. Honda Civic 2002 Strange High RPM, Misfire and Gasoline Smell
  227. Misfire on clyinder 4 after head gasket
  228. Cranks but wont start
  229. Bad Clutch?
  230. In Cabin Fuse Box 2004 Honda Civic
  231. Wipers issue advice
  232. 2002 civic sir 2l loping idle
  233. right front vibration
  234. Few questions about my 2004 Honda civic vp 😁
  235. Front passenger tire wearing on outside edge
  236. 2005 SiR 2 door hatchback window regulator issues - could use some guidance
  237. 2004 Civic EX shudders coming to a stop
  238. 2001 Honda Civic LX Coupe M/T OBD not reading has power.
  239. Will a k24 harmonic balancer bolt fit my d17a2
  240. Crankshaft Bolt Broke off inside on takeoff
  241. New (remanufactured) transmission won't go into reverse
  242. Freon refrigerant question
  243. MICU question! Please help
  244. 2003 honda civic ex tail lights
  245. Any Suggestions??? Drive light issue
  246. trunk leak troubleshooting
  247. Attempting S20 trans on 04 civic
  248. 2003 civic won’t shift past 4k rpm’s!
  249. 2005 Civic DRL Issue with LED Headlights
  250. broke ear off bell housing. thoughts on success of welding on?
