- Honda civic 2001 coolant flow direction?
- replacement key for a 2003 civic hybrid
- Brake booster question
- 2001 Civic EX 5spd Radiator PN?
- ECU won't flash- Please help!
- Starting Issues
- Need Help '02 civic P/S cavitation at 2500 rpm
- Hose Clamp for Upper Radiator Hose?
- 2003 civic acceleration problem
- 2002 honda civic crank no start issue
- Muffler Broke Off... No Tail Pipe. Am I safe?
- d17 short block
- Reinstalling Transmission Issues
- 2004 Civic LX
- Closed Loop Temp Signal?
- JDM D17
- tranny mount fluid filled/
- Rubbing Sound
- Re: Oil Leak: from Oil Cooler and Coolant Lines
- Exhaust Backpressure test..fun stuff
- P1457
- I dont know what I did to my axle :S
- Headgasket Gone Wrong
- Will 2001 civic bumper fit 2001 el?
- Honda Civic Hybrid IMA and check Engine problem
- Rear trolley jack point on 2004 civic ?
- 2003 Honda Civic, Manual Transmission start problem
- Civic Coupe 7g auto box SLXA
- heeeeelp! Rear coilover install mistake!
- Maybe overheating?
- Diagnostic Issue: Use of A/C possibly causes ECT to increase?
- Power windows
- still receiving P1361 code after replacing camshaft sensor. What could be the issue?
- 2002 Civic - Break Down/ Stalling - Diagnosis needed!
- What bearings/seals to replace in transmission?
- D17a2 turbo kit help needed
- how bad is this?
- A/C Reduction: 2003 LX
- Swap engine
- D light is blinking and D3 light is steady
- 14 inch or 15 inch for 2002 Honda Civic
- Coolant Reservoir Overflowing, all tests passing.
- Highway trouble- 03 Civic EX
- Why is the side mirror still loose?
- Which exhaust tip should I get?
- Ground Issue?
- Apex'i VTEC Controller Removal from OEM Harness
- Need Help Diagnosing Check Engine
- RPM gauge not working
- 2005 honda civic overheating
- Bad Input Shaft Bearing?
- 05 Civic Electrical......Gremlin?
- Not a D17A1?
- HELP! Need compatible ECU. Civic Coupe EM2 '04 EX AT
- noise from IAC
- 2005 Civic ES2 k20a3 swap
- Turbo K-swap EM2?
- Voltage EGR valve
- Appropiate tire size for new rims
- Air-Fuel Sensor install on '02 Civic LX
- Engine will not idle in neutral
- MCU or a ground or ? 2002 Civic EX 4D, AT
- What does this sound like?
- possible head gasket or air traped need help
- My civic
- Interior lights not working
- Low Voltage at Engine Fan
- Civic A/C Gone. Mechanic says ECM/PCM?
- White Smoke and Oil Leak?
- Cam shaft pulley bolt
- P0135 and P0141 codes
- Head Gasket...to use any liquid gasket material
- Lost Power
- HONDA CIVIC 2004 AUTOMATIC STALLS ON IDLING AND ENGINE RPM DOSNT INCREASE WTH RACING
- Steel wire under body broken
- My second replacement fuel pump as gone bad. Any ideas what is causing this?
- Trans stuck in 3rd
- 2001 Civic Crank No Start. No injector pulse
- 2001 civic shift solenoid
- Cam install issues.
- Civic 04 Wont rev past 3k, need help
- key with out chip stuck in ingnition
- Civic just blanks out and dies
- honda civic 2002 showing code P1361
- 01 civic lx
- 04 coupe window master switch help
- EGR problem
- My 01 civic jerks during acceleration
- Another 2001 honda civic goes into 'limp mode' ?
- springs
- civic 2004 sport whistling noise front wheel
- Headgasket replacement in Civic DX 2005
- 01 coupe lowered
- 2002 civic issue d17a1 HELP!!!
- DIY head port and polish
- Alternator Trouble? (Car turns off while driving & Battery Light comes on)
- SRS code help - - what is it?
- A/C goes out after hitting high RPM's
- Clutch Cylinder Wont Engage
- 2001 civic lx door
- 2002 Civic EX Coupe
- no dash lights 2002 honda civic
- Question about flushing AC system
- Oil Leak?
- Oil in Coolant After New Head Gasket Install
- 2003 auto civic, bogs down and dies when in drive
- overflowing which is leading to overheating
- 2005 Honda Civic loses power
- D17A Swap into 2004 Civic Lx. Vtec ECU Pinout?
- Curt
- 01' Civic Wont Start After Getting Hot
- auto electical help
- ATF for 2004 LX
- 2004 Honda Civic loosing coolant
- 01 Civix EX wont start
- Civic Ex Loss of Power/Acceleration
- Which throttle body fits on d17a ? H22 b20 or?
- 2004 Civic a/c draing the battery.
- Kindly Requesting Your Opinion on My Civic EX 2005 Experiencing Leaking Issues
- 2004 honda civic hybrid headlight - driver's side
- Cam and crank sensors
- steering is awkward
- Keyless Entry Malfunction - Civic 2003
- Apexi VAFC wiring
- 01 civic will not start
- Door lock cylinder issues
- 04 civic VP fuel gauge
- Odd issue - 05 civic shuts off at idle
- WHICH COILOVER
- Mohammad
- P1259 code issue...tried all I know to try
- Check engine light flickers with music
- 04 civic - passenger window not coming down?
- Green key not turning on..crank no start
- Front Parking lights / signal not turning on
- BMXA Transmission
- 03 civic wheel fitment trouble
- Overheating somewhat
- 2003ex civic 5spd
- Transmission swap on 2003 Acura el
- a/c clutch confusion
- 2005 Civic Ex Special, P2646, 4k Rev limiter
- New Key
- Parking brake adjustment ?
- SRS light
- 2001 Honda Civic sputtering
- Any guides on changing positive battery cable?
- Ecu swap without dealership?
- How-To Nitrous with an automatic, D17A1?
- Car dies after installing fog lights
- E Brake Light stays on
- hello
- Rim/bolt pattern size
- D17A1 Misfire/Rough Idle - High Compression
- 2004 civic engine swap issues
- 2001 Civic Ex P0740 Code
- 2003 civic vtec-gutless
- Sedan spoiler on coupe
- 2005 Honda civic frozen trunk and driver door locks
- Side Skirt Securement
- wiring diagram needed for civic 1.7 2003 and civic si 2005
- What coolant hose is this?
- programing did not work on honda civic 2002 remote why
- Threaded hole for motor mount broken!
- 02 civic no start
- Would I be able to use these rims?!
- 2007 Honda Civic Power steering fluid change
- Need help with electrical problem (very confused)
- Relay Buzzing and Highbeams problem
- Dashboard light problems!!!
- civic ex high beams ground, low beam no ground
- Backfire/Bogg after 2500rpm
- honda civic type r 2002 clutch problem
- 2001 Honda Civic Sputter
- Radiator Hose Size?
- Does the starter have to come out to do clutch?
- honda civic 2004
- 05 Civic Ex Unexplained Oil Leak!?!
- Gas door
- 2005 civic ex belt noise after new timing belt
- Need wiring help: 05 Civic LX Wideband O2 to 03 Civic Narrowband O2
- 2004 Civic Hybrid IMA issue???
- 2005 Civic with strange wires? Help me identify? LOJACK?
- Honda civic, slow on acceleration upon giving gas, leggy
- Only runs with scanner hooked up!!
- 2005 Civic Hybrid Transmission Info Needed
- Civic lx electrical issues
- OBD Code P0460 in Honda civic 2003
- Oil leak
- Power steering rack noise?
- Auto to Manual Swap Details?!
- Em2 advise on performance and visual parts please
- 2001 civic engine swap looking for mechanic help
- 2001 Honda Civic ex headlights and dash lights dimming while accelerating help!!!
- 2002 Honda Civic transmission help
- civic will crank but not start
- 01 civic LX won't start
- 05 Civic Hybrid CVT Transmission
- B20
- Canadian built car with US cluster work?
- 2003 Civic EX Axle--CV Joint
- Blown head gasket?
- Is my clutch going...?
- 05, Chasing a danged oil leak......
- 2001 Civic Ex Cylinder 2 and Cylinder 4 Misfire
- 2005 Honda Civic runs rough when accelerating
- 2001 honda civic
- D17 block differences?
- D17a1 to D17a2 questions (02 civic LX)
- Does Exedy Clutch and flywheel need to be Balanced?
- Oil Seperator Plate?
- Clutch or Tranny Problem?
- Need info on Civic HX in Canada, if there is any Canadian version of HX
- Change oil ....WHEN.....as per the manual
- D17A8
- overheating / fan switch
- D17a2 Injectors 550cc or higher
- 05 civic cruise not working.
- 2004 Honda Civic wont go into 1st gear
- Civic 04 need help
- Civic 04 gas pedal not responding with engine light on. Few startups later now workin
- D17A7 converted to petrol knocking issue
- O2 Sensor + EGR Sys monitors refuse to clear
- No Ground Pulse
- Rubbing noise
- start and stall issue
- What Head gasket to use on d17a?
- Car has hiccups when gas tank is half full
- Key won't move to "Off"
- 02 Civic EX Stock Radio Acting Very Weird
- 2003 Honda Civic A/C question
- Pulsing brake pedal/ no brakes
- Short ram or cold air intake for 02?
- LT and ST fuel trim
- Opinions on a used car
- Help - 2004 LX Difference between brake boosters
- Code P0782 2-3 shift malfunction
- Replaced Vertical LCA Bearings with Moog
- Help me with vtec pressure switch please
- 02 civic ex timing belt cover bolts
- 2004 Civic Electrical Problem
- Best engine swap for 02 Civic Coupe LX
- 2003 honda civic 1.7L...stalling at stops
- starting problem with 2003 civic
- 2003 civic GX (CNG) crank no start after changing oil
- 2002 Honda Civic 1.7L Missing
- Reinstalling dash on Civic 2001
- Ongoing coolant leak and overheating
- 02 Honda civic limp mode problems (P0420)
- Got the dreaded PO 420 code.....
