PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Tranny nock
  2. Drop zone struts and springs ???
  3. Hi HT
  4. Turbo setup questions
  5. cutch pedal
  6. 03 headlights fit 04 civic?
  7. 02 Civic OEM front strut question
  8. Turning Off Auto A/C Turn-On
  9. will ep3 lca fit on our cars?
  10. Auto to manual help
  11. Mods for my 04 civic
  12. new flywheel. check my pilot bearing
  13. Cup Holder Removal in 02 Civic Ex
  14. Are EP3 Civic Si seats a direct bolt-in for any earlier generations?
  15. suggestions please?
  16. replacement bulb question?
  17. 17" rims on an 05 EX
  18. Rear Seats out what can I use?
  19. Has this been done before?
  20. Opening the Air Box
  21. Exhaust Question that need be done with this setup:
  22. direct alternator swap for em2?
  23. difference between the 02 and 04 lx engine harness
  24. New Member
  25. Beeps when key is in ignition??? (Searched)
  26. what to do with girlfriends 04 ex
  27. Pointless Landmark!
  28. gas tank latch
  29. Engine fluttering sound in 1st gear?
  30. third Tranny and rebuild? please help getting frustrated
  31. spring unseating?
  32. rear speaker blown!
  33. Fasten Seat Belt indicator light and sound malfunction
  34. Sedan Hood Problem
  35. picture request + wreck update
  36. the shimmies
  37. Anyone used these headlight bulbs?
  38. INFO: 7th. Gen. Civic Chassis Specs./Features
  39. exhaust problem
  40. RSX center console install!!!
  41. torque spec for d17a2
  42. Low Beam Trouble!!!!
  43. Sway bar serious help is this upside down!? why is it hitting?
  44. Getting rid of the Govenor? (Searched)
  45. Opinions on 05 civic lip
  46. sirius
  47. fenders for sedan and coupe
  48. exhuast help!!!
  49. CEL eliminator installation
  50. Im New
  51. Coilovers good or bad?
  52. Headlight question
  53. Aftermarket bumpers
  54. Compliance bushing information
  55. Repainting my civic.
  56. Another header question *searched*
  57. Water on the floor
  58. Hello Everyone!
  59. H4 HID Kit HELP *pics*
  60. Lower control arm issues.
  61. Help with My 2004 d17a2 turbo
  62. New Member
  63. Just an Observation
  64. transmission question, need help.
  65. K question
  66. RS lip kit
  67. noz
  68. Sedan rear kit
  69. 01 Civic EX Sedan - Headlight Replacement Options
  70. My Build Thread
  71. Honda Civic 2002 Shift Lock Problem
  72. quick question: shift boots
  73. 2002 Civic LX Steering/Shaking Problems
  74. transmission question
  75. Instrument cluster
  76. Steering problem
  77. steering wheel, flashers
  78. steering wheel shakes
  79. 2001 Civic EX Door Lock Problems
  80. Heater Control bulb
  81. Heater Control bulb colors?
  82. lowering my car
  83. Rally-like Halogen installation?
  84. megan racing header
  85. 05 springs
  86. dash control replacement
  87. need help - tick tock sound coming from car?
  88. 02ex coilover
  89. Short Ram intake for 02 LX
  90. New member!!!
  91. Heres a dumb question about oil.
  92. repainting trip
  93. carbon fiber trunk
  94. Idle Problem 01 Civic Ex. (searched)
  95. Registration
  96. EDM Fog Light?????
  97. Installing front Progress Sway-bar, need help
  98. Greddy
  99. Custom Exhaust?
  100. CV axle/halfshaft DIY
  101. Exhaust System
  102. lookin to trany swap to standart manual from 4 speed auto
  103. Bidding farewell to my EM2
  104. can you reprogram our ECU'S?
  105. anyone else with a ES1 Turbo????
  106. Honda ES8 RS Reviews
  107. removing seatbelt (bracket?) bolt
  108. Five lug conversion for '04 EM2
  109. paint 99 si wheels
  110. put DSPECS on S Techs or....
  111. 300hp+
  112. header on 05 civic dx
  113. 2003 Civic Fuel sending unit
  114. 02 civic dx cluster swap
  115. daytime running light relay buzzing?
  116. Pic request for front strut bars.
  117. pic request: interior
  118. My Build Thread
  119. 2001 civic radio wont power on?
  120. 01-04 civic alternator fries
  121. what cold air intakes??
  122. Ground Controls
  123. Cam Gears
  124. STEERING WHEEL PROBLEM
  125. My Build Thread
  126. Who Likes The Honda Fit...
  127. This Forum....
  128. 01 civic problems
  129. Spec Antifreeze?
  130. civic as a first car
  131. suspension help
  132. Performance Internals...
  133. 2003 EX Transmission Fluid question.
  134. 2002 Civic LX fuel switch install
  135. My Build Thread
  136. How long will my Civic last?
  137. hupcaps or no?
  138. pic request: tire sizes
  139. Supercharger on an 04 EX?
  140. EVAP replacement
  141. How do i PM someone?
  142. K-pro on 01 civic.....
  143. 03 Civic LX Sedan Lowering Question...
  144. My 2002 Honda civic
  145. scraping sound when i turn the wheel
  146. Different suspension squeak
  147. anyone with B&G springs?
  148. Question about 2001 honda civic ex
  149. side skirts (HELP)
  150. where to get lips for 05 civic?
  151. 4dr Power folding mirrors ( wanted )
  152. Titanium Metallic Coupe Crew
  153. HybridRacing or Haspor Mounts?
  154. Tanabe tower bar + intake pipe, enought space?
  155. d17a1 incector size???
  156. Car overheating
  157. Camber kits for 2001 civic lx
  158. Noisy rear shocks
  159. Air intake set up question?
  160. DC2 Recaro's in our EM2's?
  161. cold air intakes on ?
  162. quick question ... maintenance light blinking but goes away
  163. 02 civic ex sun roof
  164. Replacing 01 Air Bag System
  165. Civic LX Rear Disc Break Kit
  166. Need some information about wheels..
  167. WTF...i got Lambo windows!!!???
  168. random box?
  169. sway bars
  170. exterior Q
  171. spark plugs change
  172. d17 firing order
  173. 5spd swap, clutch bleed probelm
  174. jdm'ed out 2002 civic coupe with the K series
  175. help! weatherstripping coming off!
  176. Power inverter?
  177. EM2 Type R
  178. Question about engine light/ cold air intake???
  179. 5ZIGEN FIREBALL???
  180. k20top/k24bottom. is it possible?????
  181. Need Spring Help
  182. 2 sensors on the manual trans
  183. Windshield related issues - washer fluid & rear window glass
  184. RSX Sub Frame
  185. question on motors for em2
  186. stronger End-Links?
  187. Radiator support is bent, replace or repair?
  188. My Build Thread
  189. Cheap D17A1 NA build
  190. troubleshooting - automatic transmission problems
  191. tranny swap info
  192. ep3 / em2 compatible parts
  193. engine swap question
  194. Fast Blinking Turn Signals....??
  195. any link how to change REAR speakers?
  196. "Si" wheels painted white.
  197. swap into 02 ex
  198. Missing part?
  199. just somethin botherin my mind lately....
  200. 2002 Civic power lock problem
  201. First new improvement
  202. premature water pump failure
  203. My Build Thread
  204. Any tips for hooking up a 01 civic?>
  205. tranny swap. quick questions
  206. My Build Thread
  207. troublshoot
  208. Looking For Ideal Size Wheel and Tire...
  209. 2002 civic Ignition key Stuck in the tumbler.....Common problem ??????
  210. couple questions about welding hangers for megan racing carbon fiber muffler
  211. never run over a pipe on the freeway
  212. Crash Update + I WAS HIT AGAIN TODAY!!
  213. Rear Shock Bolts
  214. Low position seat rail for stock seats?
  215. Annoying aligment issue
  216. how to turn off all the sounds
  217. Strange picture request
  218. EGR Vent Visor
  219. 2003 honda + safc??
  220. Once I Drop My JDM K20A-R.........
  221. transmission
  222. Yellow/Dark Hubcaps
  223. Need White (Daylight type) lights for Honda Civic
  224. Front LCA Spherical Bearing Kit
  225. new em2 driver!
  226. For Better or For Worse?
  227. dash conversion
  228. help me decide what front lip i shoud get?
  229. what's good brake pads?
  230. general question...
  231. Ipod
  232. Hondata
  233. 55mm shock on 04-05
  234. 01 civc ex want to convert to 02 si cluster
  235. Fuel Door/ Trunk Release Cable Busted.
  236. Fuel Door/Truck Release Replacement
  237. just want some opinions
  238. spyder air intakes?
  239. axelback vs. catback
  240. 16" Rim correct fit 2001 civic????
  241. disc conversion on 05 civclx
  242. sup everyone..
  243. Did your HID's do this....
  244. do coilovers have to be adjusted exactly?
  245. EM2 coupe loose suspension noise....anyone else?
  246. Possible bad transmission?
  247. Radio Code under CD player???
  248. Alternator Issues (searched)
  249. 2004 Civic headlight probs
  250. k20 swap in 02 civic
