- Gauge Cluster Retrofits into a 2001 civic?
- need help with 2003 LX Civic, CEL Codes
- ctr sidemarkers for em2
- Need Help With Power Mirrors Please!!
- side skirt DIY or CHEAPP
- car start and die while acceleration and idle.
- Is my Transmission going out ????
- Does This Work Well?
- Gauge Cluster help needed. please help!!!
- What's needed to turbo a d17
- si supercharger
- Radio
- tokicoHP + teinStech = bad? strut/spring rate possibilities? HELP!!!
- Best Short shift kit???
- coils b&g?? need help!
- Aftermarket speakers
- Suspension squeek.
- EX and LX, DX Exhaust Differences
- Everyones 1/4 mile times
- Lifespan of Koni Yellows?
- where to get seat brackets for a 01-03???
- New weird problem with Alarm system
- Need your help with muffler advice!
- projector headlight types
- 2003 civic ex SPRINGS
- 2003 civic ex nitrous kit????? HELP
- what you guys think
- 04 Rear Camber Kit fit 02?
- Advice for codes P1164 & P0171B... Honda picky about O2 sensors?
- HEADERS WANTED!!!
- My Build Thread
- Transmission Bearings
- Anyone know what LIP this is!
- Looking for information on proper removing radio in 2001 Honda Civic EX
- 275whp help
- Front bumper question
- RSX shift box swap??
- First run, 40 shot Civic EX
- Eyelids
- HONDA 2004 CIVIC EX GUAGES
- how do u change the time on the stock deck?
- 2004 HONDA CIVIC Question
- civic for first car
- max boost on ep3
- 05 civic 2dr lip kit
- EP3 swapped 05 EX Immobilizer problems
- Do I have any other options other than a retrofit.
- is this over kill for sway bars???
- EK question!
- HELLPP PLZ
- Somebody help
- SI QUESTION
- Drum to disc conversion
- ecu removal
- 05 grill
- k20
- odd problem
- k20 question???
- xtream coil overs
- engine codes
- HONDA CIVIC - SPEED SENOR
- foglights for em2
- Can U help me?
- Possible '01 Civic LX
- C Pillar Bar
- fuel pump relay(blue or orange)
- Questions concerning exhaust and cat
- struts. (particularly koni's)
- Cannot decide on lip
- Still Problems
- which springs?
- 01 civic ABS FAILURE?!?!?!
- DIY suspension + exhaust ..opinions?!
- When does the trail period end??
- just put in my new coilovers
- cold tranny?
- Anyway to tell the difference between injectors
- can someone help me reach ...turbociviccoupe
- Vibrations leaving 1st
- 2001-2005 Civic Installation Manual
- em2 sidemarkers...
- OEM headlight connectors
- motor mounts suck
- Axis???
- rsx leathers in 7th gen
- still new to honda.
- New member 04 EM2
- ground control
- d17 turbo ?s
- Fixing Headlights
- Wont rev over 4000
- new to forum
- Tein S tech Springs
- Turbo map unit?????
- BLOX exhaust... is it any good?
- Calling out for feature cars... Bradenton/Sarasota FLA this weekend
- Help!!!! Where is the cruise Module on a 2004 honda civic!!!
- Rear camber kit and brake line bracket question.
- 2001 EX, guages fluttering at start up
- Please help 2001 Civic Owners!!
- 2001 Civic EX vs. 91 hatch
- AEM INTAKE...WHAT KINDA STRUT WILL FIT?
- honda ems hid kit
- 94 civic to 94-97 teg ls brake swap.
- Door Chime
- Guide To remove side panel for speakers?
- maintence required
- d17 Injectors
- standard head unit
- Apexi n1 mix up... can it still fit?
- suspemsion problems
- NEW to honda.. had a DSM... few ???
- Steering wheel swap for ES2
- 04-05 Bumper Question
- H22 swap in an 04 civic
- Anyone in the Chicagoland Area Know of a Junkyard?
- Pre Buy Questions.
- Tie Rod Ends?!?
- b an m short shifter
- splash guard
- will this rear sway bar work?
- SRS Light
- Suspensions Problems
- Factory Alarm for 2005 Civic?
- lowering suspension help!!!
- Need some help with my fuel system!!!!!!
- What's needed????
- K-Pro for the D17!!!
- Resetting Mileage
- 6 speed tranny in k20a3
- Engine struggling to stay alive
- has anyone ever ordered from viniati.com?
- Tein SS-P or Eibach pro street???
- Rear Anti-Sway Bar Help
- SiDe MaRkErZ
- opinions please? just want to see what everyone thinks.
- 01 honda civic ex coupe witch k series will fit ?
- K24a4
- i had an idea yesterday
- Wheel size
- socal - Got a new tire hook up! + my coilovers for sale
- Need A Guide That Showes How To Remove the Gauge Cluster
- quick question
- PLEASE HELP IF ANYONE CAN
- Shipping engine, transmission, etc... any really GOOD ideas? *searched*
- My EM2 comments, suggestions?
- 2 questions please help
- Large seats for civic
- Electrical Problems
- honda-tech meet
- Door Panels
- H.I.D question
- FS: pair of Recaro Speeds
- 2001 RF off-brake noise, pads good
- Is my car totalled?
- new intake manifold?
- pic request double din dash kit
- D17 HEAD knock
- Tips for washing out engine bay?
- best ep3 forums?
- 95 Ex fog light electrical problem!
- stupid car dealerships!
- Does anyone know the D17A2 cylinder head torquing procedure
- amplifier remote connection on stock head unit.
- 215 tires on 40mm offset
- I lost my keys...all of them!
- 01 Civic Stiff Shifting
- how much could i get for this?
- Possible Short in my Steering column??
- i need a DIY on blacked out headlights for 02 civic
- Anti-Theft Code
- cops
- EM2 Suspension: What gives less sag in the back?
- got a problem
- so how does it feel?
- how much difference
- b18 into 2001 civic
- Ground Wire
- 2001 civic ex sedan airbag warning light!
- 2001 Auto DX slipping
- AUTO METER RPM TACH
- em2 spoiler installation
- Is this normal for spark plugs?
- Header and Exhaust for Si
- sad story but funny
- civic si section?
- Navigation system from a 8th gen.?
- please help with gauge install!!!!
- went to the strip today :D
- few pics
- ILLINOIS PAINT JOB
- REQUEST PIX>>>>pf 2004 ex with rota's
- Was wondering....
- Exhaust
- Sltuner88 : 2003 Honda Civic NHBP
- GOING 5 LUG?
- The Almighty D17
- Rear Drum Brakes, Should I buy new drums or have them cut?
- k20 and k24
- supercharge? vs. turbo?
- Coolant pushing out
- what else is needed
- If I install a turbo on my car to I have to....
- New Rims... Should I Get Brakes?
- heres something you dont see to often. oem hybrid wing
- Removing a tail light from 2004 4dr. civic
- dezod exhaust
- I need INFO!
- kinda a weird dezod question
- lx/dx exhaust
- grinding noise.. a little help?
- 01 Civic EX Exhaust
- Opinions on this turbo kit for d17 please
- Shift boot ring
- HID guy
- can you change a lx 02 civic engine to a ex vtec?
- White 7thgen with red gt3's (Please Post)
- cheap coilover
- 04 ex cluster in 04 lx
- What should i do?
- o Which OEM wheels look the best.
- NEED 2001 STOCK FRONT BUMPER!
- door panel removal in 04 2 door coupe
- 2003 civic ex fuel rail?
- PS
- Rim Dimensions
- Header Install to stokc Exhaust?
- auto manual 05 civic
- My Build Thread
- Help with headlights
- WTB: K20R full swap
- new bump in the trunk..
- Got pictures of nicely moded 2002 Black 4-dr LX?
- 05 civic EX cluster in a 05 civic VP?
- How to Post, A Tutorial
- 01 Civic AUTO center console removal
- !?!?!? d17 and d16 AUTOMATIC transmission the same?
- CEL code P1705/Short in Transmission Range Switch Circuit???
- carbon fiber hood
- lowering sorings question.
- all engine
- back from bootcamp :)..and i gots a question to ask
- Comptech rear sway bar/tie bar kit for Em2???
- Some cash on my hands......
- H&R Sport springs FS 2001-2005 civic cpe
- H & R sport springs FS
- HID Headlight Adjustment
- Tuner Now available in the las vegas area!
- dc sport header
