PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Serious power loss.. electrical problems?
  2. How to change the clock on stock radio?
  3. Question abou how Fog Lights Work
  4. steering wheel
  5. What about lowering suspension for a 05 4drs civic?
  6. DTC P1106 after installing E-Manage
  7. HID Kit??
  8. Overflowing coolant reservoir
  9. engine burning oil?
  10. city lights
  11. reverse, odometer lights out and can not shift automatic in gear
  12. Stereo help!
  13. Sticky automatic gear selector...
  14. the wifes car
  15. Trunk lock
  16. pass power window FUSE BLOWN
  17. 02 civic TPS question
  18. simota aeroform intake?
  19. want to know if rsx type s down pipe will fit 01 civic
  20. 04 civic stage 2 cam question
  21. 01 Honda civic ex compressor how much oil?
  22. Power Slot big rotor kit
  23. A/C Compressor
  24. Rear LCA - Stock to Function7 LCA - Will throw off alignment?
  25. Max rubber/wheel fitment?
  26. 96-00 Hatch Muffler Specs?
  27. maintance required light?
  28. ► Official Honda-Tech Announcement.. Must Read
  29. can a 01 civic fit a rsx type s down pipe
  30. Skunk 2 Recommendation?
  31. oem aero kit
  32. Turbo K20 in EM2 chassis; Is it possible to keep A/C?
  33. cel without a code reader?
  34. HOW DO I GET RID OF MY SRS LIGHT?
  35. T-boned by a relative(97 four door) :(
  36. Paddle Shifter install help
  37. interior help!!!!!
  38. Type r shift boot
  39. Looking for thread...
  40. disk brake conversion
  41. Powder in/around stick shift
  42. rattle, car's cold, exhaust?
  43. Wiper / headlight switch question.
  44. latest developments of my car
  45. milkshake in my engine....
  46. its getting cold and i have a problem with my heat...please help
  47. Clutch release bearing (throwout bearing)
  48. Replace cabin filter?
  49. Looking for a Rear Strut Bar for a 03 Civic. Cant Find one (Researched)
  50. ex swap
  51. Where can I find OEM side skirts installation manual
  52. Noob question about CAI
  53. Transmission fluid
  54. stock strut replacement
  55. ex swap?
  56. exhaust
  57. Strut bar options?
  58. Honda Civic Hybrid 2005
  59. Best oil filter
  60. it all started with a radio code1
  61. No heat and ECU code 9. What should I do?
  62. Progress 22mm Rear Sway bar Installation issue.
  63. some advice will help...
  64. OEM sides, does anybody have the part number?
  65. rsx suspension
  66. Window Issues..
  67. SRS light is on..
  68. So i think my compliance bushing is shot
  69. post your 01-05 drop and speck or setup for 4 doors please
  70. new interior lights wont work...help!
  71. dads that drive coupes/hatches
  72. CEL when running AEM F/IC
  73. 2002 civic lx car alarm
  74. auto tranny question
  75. Cheap place for Struts
  76. 2004 Civic - Lower on Driver side??
  77. Racing Seats - General Question
  78. URGH! Cant find this part online
  79. knocking noise
  80. '05 Civic overheating
  81. Tail light Illuminator went out....
  82. body kits
  83. jus bought a 02 civic need some HEELPP!!!!!!
  84. Popping noise in rear????
  85. fog light fuse?
  86. mph gauge "dropping" / kpro like symptoms
  87. Whats the best size tire?
  88. Proper Torque for Wheel Lugs? (searched)
  89. **HELP**i want to swap in a gsr or h22 instead of the k20**HELP**
  90. stock intake install
  91. wierd noise above 4k rpm? any help?
  92. Brake farts
  93. Hard to shift after it rained.
  94. Blown head gasket on Honda civic Ex.....Help!
  95. Stop lights don't work.
  96. help on install air fuel ratio
  97. Key Wont' Go In 2003 Civic LX
  98. Name this part on K20a motor in 05 civic
  99. Canadian Tire - Brake Fluid, Clutch Fluid, Coolant
  100. Installing new struts to front of 2001 Civic LX
  101. Flushing the heater core
  102. Heater problems again..
  103. Heater problems
  104. ROTA slipstream
  105. Extra revs before shifting up...
  106. weird fluttering sound
  107. header/downpipe
  108. gauge cluster dont work. Funny story
  109. bolt
  110. Plates rubbing together?
  111. 01-05 Coupe vs. Sedan Exhausts
  112. maint' required light
  113. My Build Thread
  114. Having some problems and I don't know what's causing them.
  115. Cold Starts
  116. Random multiple misfire on 2003 Civic EX Coupe when warm.
  117. 01 Civic Headlight Recall
  118. 5 lugs conversion
  119. Engine Block Heater
  120. Keyless entry conversion
  121. b-series in em2?
  122. "Blinking Key" dash light
  123. What components do you cover up when washing an EM2 engine bay?
  124. Turbo Kits?????
  125. Headlight Leaking
  126. Beginner upgrades
  127. GSR SWAP in a 2005 civic
  128. JDM Folding mirrors?
  129. Most Frightening Thing Happened Today
  130. question about getting bigger wheels
  131. 2001 Civic - hard to shift into SOME gears.... ?
  132. 01 Civic Coupe Grill
  133. Selling Price?? HELP!
  134. Speedometer and Tachometer stopped working !!
  135. Window Deflectors
  136. Seatbelt Sensor SRS light
  137. Question about Rear Disc Conversion
  138. Question about EP3 steering wheel!
  139. civic vtec question
  140. 02 civic problems please help!?!?
  141. 2002 civic problems..
  142. K20 swap and A/C lines
  143. Transmission: shifting from 2nd to 3rd
  144. Question for Toyomatt84...
  145. Maintenance Required light has come on.
  146. C.A.I and Header help
  147. Noob question for his New car
  148. My Motor Build
  149. DIY: EDM Rear Fog Install
  150. ¿Random misfire?
  151. how to put air fuel ratio on
  152. civic being crazy
  153. Problems with new cat converter?
  154. rear speakers quit working all together?
  155. Steps to figure out why no heat?
  156. K20a swap
  157. where can you buy jdm headlight projectors??
  158. how to install a glass on the quarter rear passenger side
  159. looking to lower in the spring
  160. mudguards
  161. passwordjdm 04-05 headlights question!!
  162. Timing belt or chain?
  163. Name of Part
  164. Truck keeps opening.
  165. need help with installing h.i.d kit??????????????????
  166. trunk leak
  167. Defroster and Radio Problem
  168. 2004 civic lips
  169. transmition problems
  170. camber kits
  171. K swap and power steering pressure switch
  172. AFTER replacing compliance bushings
  173. How do I remove the shadow left over after debadging?
  174. 01 CIVIC- anyone know how to test camshaft position sensor ??
  175. No heat at all.
  176. Seibon OEM CF Hood
  177. Automatic Lock
  178. Rear Trunk spoiler
  179. Right Side Windows Fuses keep blowing out??!!?? Help please.
  180. ROOF RACK HELP!
  181. What size is the OEM Tire.
  182. need grill instructionsss !
  183. Engine LAG
  184. a/c blower fan clicking
  185. Noise after Progress rear sway bar installation
  186. HELP!! AC Just stopped working!. Nothing WOrks!
  187. THROTTLE BODY REPLACEMENT???
  188. No Heat Sometimes - Help !!!!
  189. 03 civic a/c problem #2
  190. Air Condition - Honda Civic 2001 4door LX
  191. Can someone help me? (4 Door question)
  192. Exhaust HP gain?
  193. help with civicnge
  194. Cam Gear Question
  195. PLEASE HELP RSX SUB FRAME IN K SWAP
  196. ecu help
  197. 03 civic a/c problem
  198. Brakes - Few Questions
  199. How long is Honda Tech Probabtion?
  200. Help! 2005 Honda Civic EX- Blown head gasket
  201. Engine cooling Fan ?
  202. Alignment issues after an accident
  203. 01-03 civic battery relocation
  204. will 00 civic si wheels fit on my 02 em2?
  205. timing belt slipping
  206. seat bracket/slider/mount help please!
  207. problem with gas door on 05 ex sedan
  208. CARB Smog Problems
  209. Looking for a suspension part name (coilovers)
  210. No Interior Light
  211. cleaning my motor
  212. need help 02 civic misfire and wont revv up...
  213. experience with headlights?
  214. Is it recommended to change the Tranny Fluid of an Automatic?
  215. aiming 04-05 headlights
  216. worth buying?
  217. heater mirrors
  218. do these parts fit???
  219. headlight removal
  220. New to the Honda World...
  221. HOW?
  222. Shorted Dome Light Circuit
  223. BUILT d17A2???
  224. My honda Civic!!
  225. 2002 honda civic manual trans fluid????
  226. Are these springs worth buying??
  227. HELLLPP!!!! 2005 Honda EX Coupe
  228. windows is messed up help please
  229. 03 civic ex coupe overheating. need help.
  230. Water + CAI = Broken Engine
  231. 03 civic steering problem
  232. Click noise trying to start
  233. front lip at stock hight?
  234. why is my air bag light on
  235. what does a clicking noise from my axel when it turns mean?
  236. Fog Light Q (searched)
  237. thinking about 2002 coupe ex
  238. Turbs or Swap
  239. Metal to metal grinding noise HELP
  240. Help! Can I raise the Civic's ride?
  241. k20 swap??
  242. power door lock and a/c dont work?
  243. Separated ball joint : Oops!
  244. wat kind of cluch do I need????
  245. newb needs help with installing lip
  246. cars with negative camber!!!!! help
  247. key fob program
  248. Gauge clusters
  249. manual transmition in an 04 civic ex
  250. Lowering Springs and 18" Wheels
