- Air blower
- d15z1 into a 7th gen?
- 2001 LX cruise control not working, please help!
- 01 Civic front end shaking on take off
- Rise in Temperature
- Oil leak question, (Pictures included)?
- Need help with 02 Civic LX
- Immobilizer Key
- civic 2004 adjust front lights direction
- Just installed coilovers, now I smell burning
- Civic 2004 Cruise Control light
- Optimum Compression in D17?
- Best place to get D17 replacement motor?
- Speedometer STARTS at 60 as if it's at 0
- over heating
- Noob question about exterior.
- Should I repair my 2001 EX?
- Ignition help question
- Back again! Now Clutch is slipping.
- em2 EPS swap from ep3, Electrical question??
- P0420
- 2001 EX Cluster lights up but the miles/trip odometer don't?
- 04 automatic tuning...
- Honda Civic Coupe 2002 - no high beam
- Why isnt there alot of 02-05 civic builds?
- Center console on a 02 dx?
- pulsing lights?
- tsx swap
- Transmission Identification
- 01 civic the transmission is making a grinding noise
- Transmission Oil Change
- Rods and piston?
- 2003 honda civic loosing power when cold
- near complete loss of power 2002 honda civic lx 1.7ltr
- need help find my old em2
- Help on taking off bumper
- Unbranded eBay motor mounts? Should I buy?
- shifter problem
- d16y8 oem header. will it fit on a d17a2?
- New Exhaust Manifold, Options
- weird noise on driver side from engine
- 2005 honda civic running hot
- auto trans rebuild
- My Speedometer Doesn't Work In My '02 Civic!
- Cruise Control in and out
- Cluster swap problem!!! (No more constant power in the car)
- Alternator/Battery problems?
- Honda Civic 01, Cannot Full Rev Loss of Power
- 2002 Civic trans problems
- Transmission lag from 1st to 2nd gear.
- d17a1 compression #'s
- My lights on dash is coming on
- 2001 civic lx dashboard lights?
- wont start. now fuel pump relay action and no check engine light on key up
- cia differences hx and ex
- 2001 Honda Civic ex over heating
- over heating/leaking anti-freeze
- Clutch and pressure plate 92-00 fits?
- 04 ex:How to use oem keyless entry remote when the is started?
- Over heated motor lately? Every wonder why? Answers inside.
- Car pulls to sides.. and Squeaking & Crystal Grinding
- Lost Power
- Replaced Timing Belt and Tensioner after Civic Jumped Time... Now Cylinder Misfires?
- Losing power during acceleration + Jerk
- P1298 Honda civic 2002
- Idle problem
- 04 auto lx into a 05 auto ex
- Em2 k20 swap
- is my civic totaled
- Honda has trouble starting sometimes and when it does it shakes?
- Post swap DTC 15 A/C problems
- Input shaft bearing, what bearings to replace?
- 03 civic Cluster Problems
- 1st car, need opinions plz!
- Dealership tinted windows, or independent shop?
- Honda Civic LX 2-door coupe. Headlights quit working.
- Honda Civic 2001 LX Model jerking and stopping in traffic?
- 2004 Honda Civic SI Sedan Humming Sound Please Help!!!
- 02 2dr civic airbag module interchange
- rebuilt engine cannot turn over by hand with trans
- Can I get a part number? Interior...
- 03 Civic LX cluster/interior lighting not working
- Civic 2002 compressor unit belt -- Help!!
- 2002 Civic occsional stumble/dies
- 01 EX Knocking noise
- Air/Oil Separator
- 02 civic no crank signal
- 2002 Si Civic Engine Light
- flooded 02 honda civc hx - key won't turn ignition
- 2001 civic vacuum diagram
- 2005 honda civic lx coupe left strut
- 2004 Civic Hybrid A/C / Heater fan stopped working
- Replacing instrument cluster bulbs........
- Rattle and Humm
- Car won't start - have battery power though - thoughts?
- 2002 Honda Civic EX Coupe Idling Rough In Neutral
- SRS
- 2002 engine swap hx to ex
- track ready
- Will 00-02 Accord Side skirts fit a 02 Em2? OG EM2 owners chime in please
- How to get my HP up drastically with D17? (Not using turbo)
- Check Engine Light ON
- P1362 and P1361 CODE
- Information needed on manual tranny refill
- Will rsx coilovers fit my 04 civic sedan
- good battery and alternator no electrical at all
- Engine Noise
- 02 EM2 Civic Si Oil Problem
- 5spd Jumps out of 3 and 5th
- how to take off main req off of my dash board ?
- Engine stalls when it is cold.
- Denso O2 Sensor for Civic 2002 (Manual)
- 02 Civic LX: tranny drain and refill .. vs tranny flush?
- EM2 with problems.
- cost of labor + parts suggestions
- 2004 5spd MT Civic
- 2001 HONDA CIVIC LX .. Blinking D code P0715
- New Alternator Humming
- Error code P1456
- Normal RPM
- Please help: Rattle in reverse in neutral
- Bad gas mileage on a 02 Civic Si (Canadian EX)
- Car looses power
- 01-05 front end conversion bulkhead question??
- Headlights out...
- Engine not turning over w/ lights blinking
- -noob alert- 05 civic gasket/engine swap
- Car stutters when cold starting in weather below 0, tested battery...
- Car won't engage in park key won't come out of the ignition
- Brake lights won't work!
- 2001 civic timing after broken belt
- Transmission popping out of gear
- transmission slipping
- A/c
- need to change slave cylinder for my clutch hydrolics need help !!!
- Need your input on this, timing cover issue, not sure if its anything to worry about
- Front lower control arm bushing issue.
- gauge cluster only works sometimes
- Possibly fried ECU?
- 2002 Honda Civic EX Help
- How do i change my wiper blades?
- swap the D17A a K20A2
- Question for Canadian Honda techs regarding key codes
- 2001 Honda Civic LX A/C not working
- Whats the point of the coolant resouviour on 7th gen civics?
- Bad Alternator?
- 05 Civic radio code
- 2004 civic hood into 01?
- EVAP code P1457, where is canister?
- 2004 Civic front end question
- I need the install guide for the OEM front under spoiler (01-03, non aero)
- 2002 Civic LX confusing mechanics
- 2002 civic ex won't start....dont think its the same.
- 02 sedan civic lx p0304 misfire
- New Owner of 2004 Civic Value Sedan. Maintenance and What to expect.
- 01 Civic, lots of error codes, and low idle
- 02 lx civic speedometer reads 10mph high
- Transmission Fluid Temperature Sensor
- Driver Side Automatic Door Lock
- best way to drop engine but keep a/c intact
- broken lugnuts
- Ep3 5 lug parts list
- Cluster pinout help 7th gen
- Why oh why arn't my brakes working?
- 2001 honda civic dx will not turn over or crank
- Civic 2002 EX turns off
- Where the throttle cable brackets bolt to
- Reverse Vibration (after T-swap and new mounts)
- Hit the curb by accident
- '01-05 vs '92-'00 motor mounting points
- 01 civic battery light wont turn off READ!!
- New guy / DLC pin 7 communication issues
- Auto transmission housing won't separate
- have other civics have this problem, too?
- Are these mirrors with turn signal, OEM for Em2's??
- Fuses..good, bulbs good, still no brake lights!
- Gear Shifting Problems
- stabilizer linkage
- Lost another transmission.
- 2005 Civic Hyrbrid - Bleed Clutch
- Civic 2004 spark plugs
- A stuck horn
- Cold Air Intake on '02 Civic EX?
- 02 Civic EX front brake questions????
- 2003 Civic Sedan LX Door lock & installing wireless entry question
- '04 CEL - P0340 Generic Camshaft Position - Advice Required
- compression specs 2.4
- Replacing front motor mount 05 Civic
- cheap performance upgrages
- 2002 honda civic pops out of 5th gear
- 2005 Honda civic lx coupe special edition
- Resonator removal pros and cons
- Replaced battery: car won't start, and cluster is wonky
- Engine out need to get pwr windows up
- CEL: P1456 Evap Code
- P0700 Error Code
- Car is in limp mode, but why?
- D17A1 auto transmission to D17A2 engine
- New member.
- Love my Civic, I want a Turbo!
- Civic Instrument Cluster erratic
- DOOR LOCKS AND DRL NOT WORKING !!!
- 2001 Civic Transmission problem. Doesn't seem to go into gear.
- Converting speedo from KP/H to MP/H
- Spring shreaded my timing belt
- 02 lx high idle
- Steering wheel civic 03
- Strange Issue with Engine or Tranny
- Want to convert from Automatic to Manual
- Passenger Rear Window Stuck Down
- which lip??
- knock sensor replacement
- head bolts
- USDM and JDM Swappable ECU Question.
- Ign Coil 2 & 3 stuck
- 2003 Civic ignition .
- Bought an overheating 04 civic lx.
- Video: Honda Civic Strut Installation
- Honda Civic 2004 performance.
- 2001 civic will crank but won't start
- Hey guys got engine and starting problems need help!!
- K20A Conversion
- Transmissions interchangeable
- Alarm Chirp Sound Not Audible Anymore
- HELP PLEASE? CV's are stuck in transmission
- NEED help with 04 honda civic instrument lights.!
- Inner door handles for Sedan
- 2004 Civic LX died and now has low power
- honda civic 4 doors 2003
- Civic 4Dr Dome light replacement
- headgasket replaced, problems spawning
- 01 civic major problem?
- need knowledgeable input on 5speed swap issue
- Changing the Air Filter
- 03 over heat issue
- Check Engine Light Flashes Randomly
- 2005 Civic EX alarm going off
- will it fit?
- 2002 Honda Civic Knocking noise when letting off gas pedal
- My transmission is slipping, but only when it's cold.
- Blower Fan stop working
- Timing belt broke
- Crankshaft broke after timing belt replacement. Am I being ripped off?
- Is there any diy to replace tie rod? I could only find for 93 civic but not for 03
- 7th gen autotrans failures investigation - pretty impressive.
- What does the drivers side axle connect to?
- what to do with a d17a1?
- What Civic is this? Confused (Asian Civics)
- which emblems for 2001 civic coupe?
- Where is this squeak coming from?
