- Turbo off of Procivic.com?
- New Alternator, new whistle/whine, what the...?
- K20 Swap
- changing head gasket on 01 LX.
- hasport guys
- Seat fitting Problems...
- noob with new civic needs help
- Tow Hooks... Where can i get em...
- ReD LiNe aT 4,000 RPM.....???
- INPUT SHAFT BEARING
- Help Please! - Wheel-Fender Contact
- abs light
- Head swap - 01' EM2
- Ebay Acura wheels quality
- keyless entry for lx
- headlight wattage.. fried harness?? HELP!!!
- bucket seats
- Advice:
- power steering? i cut the wheel and the car turns off.
- What would be involved in switching from a trunk lid with the OEM optional wing to one with no wing?
- Need a lil help.
- awd civic??
- AC smells awful!
- omni full coilovers for a 01 2dr
- front bumper removal?
- 01-03 angel eye projectors
- back lip kit only?
- I need a SAN FERNANDO VALLEY Honda Mechanic.
- Auto tranny buildu??
- Really?
- Honda Stickers
- is there a door unclosed indicator light for lx?
- Wanting to learn about tires and rims.
- totally O/T But !!!! DONE SCHOOL!
- july 7th and 8th
- EM2 squad....
- My Build Thread
- Clutch problems! 2005 Honda Civic
- I have a 2001 civic ex coupe, my battery light comes on under 2500rpm.
- Off topic but..
- JUST BOUGHT AN 04 CIVIC HELP ME
- wierd spring problem nothing major
- SPRINGS BREAKING IN
- b16 spark problem
- Central Florida EM2 Meet come check it out
- First post, first issue: manual transmission shifter overthrow
- Forget how to manually disable stock alarm on my 2002 Civic
- Short Ram intake for 2002 Civic
- 03 civic lx fuel pressure regulator
- plain grill
- POLL: Should we start a new Picture thread?
- Fuel Tuning/controlling
- Boilermaker1 completes a major feat, motor installed in a weekend.
- How much do you think my rims are worth?
- Check engine light
- CEL from Intake
- Strange noise at lower rpms
- illinois only
- I need bikerack recommendations for Civic Hybrid '05
- Help with an issue.
- Irritating glovebox rattle
- I need estimates
- Stuck in overdrive
- Koni Yellow Inserts
- WTB: Automatic Tranny
- Anyone got a dyno of a stock D17a1?
- need help with fuel management
- Shaking when braking hard
- june danbury meet.
- Ebay fog light wiring different that Factory, how do i get them to work?
- new member needs advice from the pros
- Brakes problem Type S
- any special socket to remove rear lca's?
- Time for the 30k mile checkup...
- Back Seats
- Rim/Tire size?
- How to take apart a drivers side seat 2002 civic coupe
- Polyurethane lips
- __ Replacing Fuel Pump on '02 Civic __
- Garage Sale!! Civic 2001-up Blue Kevlar Hood
- Type R Stereo removal
- window stuck
- interior question
- cluster light issues : Maint. Trunk, and Battery all on
- civic vs accord
- tail light and Cluster ilumination fuse blown...
- sqeaky belts!!!
- My Build Thread
- Noob user needs advice on Frontlip,Sideskirts and backlip for his Civic '03
- I'm BAAACCCKKK... well almost...
- Help with Blackhousing headlights
- Engine Bolt-Ons
- foolish to buy 100K used civic?
- Civic Special Edition 20pin Audio Harness--How is it different?
- oil filters
- '02 Civic EX For Sale
- Suspension/Brake Setup
- will 01-03 shocks fit 04-05 ?
- 2002 civic si, turn signal/blinker/flasher relay?
- Viper Alarm, I cant find the brain!!
- I got a free daily driver for the next year
- cam problem
- is it legal?
- Question tranny
- Block ID
- original suspension
- TDC interuption problems
- where can i find altezza grills
- how do you change the mtf?
- my interior light bulb has just gone! anyone know the size of the bulb?
- Stock Radio... please help
- Cheapest place to buy Honda parts?
- Build d17a2
- Hi Guys!
- any1 have pics and specs on the es2 type r
- rsx-s rear sway bar... what endlinks?
- HELP ON MY SUSPENSIOIN !!!!
- Header Design
- Is there a 5 lug suspension for a 2002 coupe?
- new gauge cluster
- bad luck in my EM2 (new rims)
- how to install and clean cold air intake on 04 civic
- A/C compressor has 65+ psi on the low side
- PIC REQUEST: sedans with 04-05 tails
- Carbon Fiber Hood
- Door molding and pin stipes
- opinion on wheels
- *...Window Visor...*
- new pics of my em2
- i guess this is another way to bypass srs
- Center console.
- what tranny oil you guys using?
- Vibrating pedals-clu
- Recent civic timing belt question
- CD player stopped working in 2005 Ex Special Edition Civic!!!
- Transmission problem
- 2003 Civic Transmission Problems
- Painting lip with matched rattle can
- i searched couldnt find anything rsx back seats
- Front Lips: Spoon vs. Mugen ... Post yours!!
- slipstream color
- foglight wiring
- 01 civic ex beeps 6 times on startup
- 2002 Honda Civic - Stock Stereo
- Lower ball joint?
- 2001 civic ex
- auto to manual em2?
- Rear speaker covers
- 05 lip
- B series on 01 civic
- Aftermarket Deck *Searched*
- WTF FACTORYHONDA619
- Pattern (template) Front Fenders 01 civic ex
- Lowered on 15x7.5 wheels and 195/60 R15 tyres?
- Turbo timer wiring
- wth did i see??!!?!?!?
- Does any one have a picture with a 1.5 inch drop
- ex alternator
- how to change Radio antenna at A-Pillar
- Exhaust Manifold
- turbo exhuast similator?
- Light-weight Flywheel
- any one a wheel and tire expert!
- SRS light
- does any body have experiences with EBstores
- drop question
- My Build Thread
- Automatic Transmission Question
- dose anyone know
- 01 civic ex electrical question about dash cluster.
- does anyone know how to take the yellow lense out of your headlights? is it even possible?
- How to remove driver side door panel?
- K20A3 to K20A2 Intake Manifold Swap
- 2002 stock stereo removal
- Revo short throw shifter
- Need info on pulling radio from 2005 Civic LX
- 2001 Civic EX - Occasional Rough Loss of Power at Moderate Speeds
- Sport Suspension Package On 2001-2005 Civic EX
- 2003 Civic - pinging
- 02 Civic Si rides horrible, any suggestions?
- Turn signal not working at times?
- radiator overflow bottle replacement
- Smoke side marker lights for 2002 Civic Si HB
- ES1 strut bars
- painting a lip
- 01-02 Coilover on 04+
- WHAT IN THE BLUE HELL?
- k20a2 vs k20z1 wat is pro and cons
- Coilover Problems and thoughts
- My Build Thread
- k20a2 cams in k20a3?
- My Build Thread
- What's the lightest EM2 can get?
- Civic Ex vs. Lx
- VTEC cylinder head.
- found out what the front end noise was when i was steering!!
- New Rims and tails?
- if we had the type s k20 vs a type s....is it a drivers race?
- DC5 Rear Seats in a 01-05 Coupe
- Maint Req'd...
- Rear bumper
- Radio Question
- Updated Picts
- Overheating-Blown Head Gasket
- ok car wont start please help
- rsx strut tower
- Who makes a 16x8 for our cars??
- 2003 Civic Throttle Position Sensor
- what wheels are these
- where can i get a decent type r or mugen lip(04-05)
- Why do people like Turbos more than Superchargers so much?
- HX upgrades, help
- 2001 ferio
- Rear Bars... All 3.
- EX vs SI
- tein basics or megan track series
- King Motorsports engine rebulid
- Spare Key
- Auto Tranny Fluid
- My e-brake is loose, I have a question.
- Emanage wiring... <--Lost
- Does any one know about shaving and boring
- New lug nut specs
- Air Intake for Auto???
- Need some power for my 03 Civic EX
- any 2003 honda civic hatchback for sale?
- FAQ: Low beam headlights don't work but high beams & parking lights do, what's wrong?
- Tein S. tech springs
- RSX front end........
- passenger window & driver door lock issues...HELP trying to fix to sell
- ep3 question
- Hood molding clip??
- d17 non vtec header
- wat is the diffrence from RS, to the ex/lx base models
- Honda civic with k20 from canada
- Rear Lower Control Arms
- should i paint my lip
- How closely related are the EM2 and the RSX?
- IACV/Idling question
- question for fventura03!
- dismounting tires
- Price of the K?
- auto to manual switch
- srs back again
- Rota Slipstream size
- Turbo Kit on 04 Civic
- 2004 4dr EX makes a loud popping sound when turning into a driveway
- Drums squeaking
- newb
- well i broke my nuts today
