PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. axle fitment honda to integra!!!!!!!!!
  2. Need help with Front Engine Mounts (02 Civic DX 1.7L)
  3. gears keep popping out of place.
  4. Squealing front end
  5. 2002 Driveaxle replacement
  6. Inexpensive ways to increase horsepower?
  7. Rain/water leak
  8. Replaced shocks and struts- now car rides high?
  9. does a 2011 wrx motor fit in my car?
  10. Timing belt question 1.7L SOHC
  11. power steering makes squeaking noise and won't turn
  12. Need help with slider pins
  13. AC Thermal Protector
  14. Trying to put si seats into non si 05 civic
  15. Need help with Rear Brakes noise
  16. HFP LIP Where to buy??
  17. 03 civic lx blower motor wont turn on
  18. HELP!! Acura EL 1.7 ECU
  19. 2001 Honda LX engine swap
  20. 2002 civic dx bearings question
  21. 2001 Civic HX Manual with 4 wire primary o2?
  22. Wire not connected to a clip, please help locate plug
  23. Engine will not stay running
  24. 2001 Honda civic 5 speed weird popping when first accelerating
  25. Replaced struts now wheels pointed out?
  26. head light all fogged up
  27. engine sound
  28. Jacking for tire rotation -- basic question
  29. Makes a clunk sound when going over bumps
  30. 02 sensor problem help
  31. Cluster swap
  32. 2004 honda civic no more than 4k revs
  33. 01 honda civic no compression
  34. Installing passenger window skill level required
  35. Help Me With My Squeaky Coilovers!
  36. 2002 EX Alternator Pivot Bolt questions
  37. 01 civic dx 5 speed..hard to get out of reverse and pops out in 4th and 5 th
  38. fast idle fluctuation
  39. engine shaking all the time
  40. how to measure?
  41. Disabled power steering - now leaking...
  42. Buddy Club Spec 2 Exhaust
  43. Cluster and vehicle speed sensor
  44. Two questions about the 2001-2005 Civic EX and LX.
  45. Civic coupe Body swap 2002 LX to SiR 2000
  46. AT drain and fill + Valvoline Maxlife ATF
  47. 2003 civic body parts.
  48. battery drain
  49. Question about ABS
  50. How many Fuel Filters ?
  51. In-Tank Fuel Filter Replacement
  52. My engine committed suicide
  53. 2001 dx
  54. Civic 02 No Start .. Help ?!
  55. Nubie Honda owner
  56. help with 01 civic
  57. 01 Civic LX excessive gas use
  58. ES1 A/C Delete
  59. Is my 02' civic ex worth keeping??
  60. '02 motor mounts (how to remove rear motor mount)
  61. Questions about oil pan replacement on 2002 civic 1.7l
  62. 02 EX em2 foglight power help
  63. Cabin Filter Alternatives
  64. 2004 Honda Civic DX HELP!
  65. confused and don't what to do next?
  66. Needing help with cluster pin-outs
  67. AC Suddenly Stopped Working
  68. 03 civic accelerarion problem
  69. Front Brake Locking Up
  70. Looking for the timing specifications - 2004 Civic
  71. es1 mild turbo setup
  72. 2005 Honda Civic EX SE
  73. light switch lever.
  74. CLUSTER HELP?!?! Video of Self-Test inside
  75. Low Idle, Tried some Fixes, Need more Suggestions Please
  76. 2004 Honda Civic Motor Mounts
  77. 2002 Honda Civic EX Wiring Diagram
  78. Crank, no start.. help?!!
  79. D17A1 Idle issue after Head Gasket Replacement
  80. Civic 2 door coupe door lock question
  81. wheel studs
  82. TPS Bolt Spec for 01 civic
  83. Left engine mount abs unit in the way
  84. 60K mile servicing
  85. Em2 hear a ticking sound from transmission side of engine bay
  86. 2003 Civic Hybrid Questions.....
  87. 2003 Civic LX Died while driving, Lights blinked off, only oil light on
  88. Is engine replacement necessary?
  89. air compressor clutch won't engage when relay bypassed
  90. Swaping an ex cluster into a dx EM2
  91. 04 civic rough idle
  92. Wont start after warmed up
  93. Idle, poor acceleration problems.
  94. Koni Yellow/Ground Control
  95. wipers won't stop
  96. Super Oversize Mobil 1 M1-207 Oil Filter for 04 civic
  97. 03 Civic EX Driver Headlight INOP
  98. 2003 Honda Civic LX(A/T) Died While Driving
  99. 2005 honda civic air wont turn on
  100. 2001 EX TRANSMISSION ISSUE...
  101. change battery
  102. After changing my Belt.
  103. ECU question
  104. 01 EX coupe short throw questions
  105. Need Advice/Help about transmission
  106. 0w-20 oil, 7th gen civic in Florida summers
  107. 05 civic bug deflector on 01-03?
  108. 2004 civic charging issue ! please read
  109. Steering wheel swap ??
  110. Bad Idle, Transmission jerks
  111. Battery light, brake light, abs light on and off
  112. door speaker problems
  113. Wiring harness question
  114. LX to Si conversion
  115. Steering wheel question
  116. 2005 DX-VP sedan - 44mph standing still
  117. Resetting Maint Req'd light with broken odometer button
  118. Gear slipping or...
  119. Fan not engaging
  120. shifter light not working
  121. You think you know head-gaskets?
  122. JDM Civic Question
  123. rsx motor mounts in es1 k swap?
  124. Thunk* noise when I put my car in reverse.
  125. Front suspension noise
  126. Need help on wheel fitment! Please
  127. Need Some Help On A Swap 2001
  128. Compression Test / Head Gasket
  129. Clicking noise in drivetrain
  130. engine swap questions. looking for help.
  131. airbag light/code
  132. Vtec Swap
  133. NEED HELP ! Beginner ! Automatic 05 Honda Civic Ex special edition STOCK . beginner!
  134. 2003 civic ex 5 spd, cuts off
  135. 2002 ex gauge cluster in a 2002 dx
  136. 2002 Civic LX 4 dr power window wiring diagram
  137. driver door lock not working!
  138. Crv chassis swap...
  139. 05 Civic automatic will not crank
  140. Factory service instruction for timing belt
  141. d17a1 to d17a in a 2003 civic lx. Any advice?
  142. Did I screw my engine up? Botched timing belt job.
  143. Interesting no-start scenario....
  144. CX rims on my 03 honda civic coupe
  145. Car will not move when in gear.
  146. 05 Hybrid cluster..NEED PINOUT W/names for each color plzz
  147. whats d17a1 and d17a2 series compression ratio?
  148. Need power steering help
  149. 2002 Civic non vtec to a vtec
  150. DIFFERENCE BETWEEN 2 QUARTER PANEL PART #'S
  151. Question about ECU and O2 Sensors
  152. 2001 Civic AC problem
  153. CAR WON'T GO INTO GEARS. HELP!!!
  154. 02 Honda civic Si Vtec VELOZ Problem
  155. 2002 Honda Civic - Flip Up Key?
  156. ELD UNIT LOCATION--HELPP!!
  157. 2005 lx how to take off front bumper
  158. dash lights are not working
  159. d17a1 oil leak
  160. - Hybrid Owners Please Check In -
  161. Current car or junk yard car?
  162. 04 Civic throttle position sensor
  163. 2005 Civic Base Coupe VIbration
  164. 2002 Civic AC not working - help!
  165. 2001-2005 Factory Spring Rates
  166. brake light bulbs
  167. 2003 Civic Hybrid P0172
  168. what name of this piece?[from Brazil]
  169. 2002 Civic EX struggles in the first 2 miles driving
  170. Engine rebuild question. Slightly egg shaped cylinders.
  171. Power door lock repair
  172. The Dreaded P0335 Code
  173. dc2 intake
  174. 2002 civic Lx Alarm no Beep
  175. Bypass?
  176. clunking from rear help
  177. Car sounds like a train chugging when turning right
  178. cracked block or head gasket??
  179. Clicking sound when I turn on cooling fan
  180. Keep Blowing Crankshaft Position Sensor
  181. 04 civic, dim headlights, missing fuse, was I scammed?
  182. '01 civic AT... D is flashing
  183. Crankshaft bolt torque spec? 14.5 ft pounds plus 90 degrees?
  184. Question on selling a 2001 Honda Civic
  185. Cheap Alternative to Spherical Front Control Arm Bushings?
  186. D16A6 Pistons in D17 Block?
  187. CRANK BOLT !!!
  188. 2004 Civic LX Hood?
  189. 2005 Honda Civic, 5-speed manual
  190. interior sensors
  191. clutch stuttering(slipping)
  192. 03 LX Civic Rear Defroster NOT working
  193. '01 Civic LX Cruise control not working
  194. Parasitic Electrical draw on fuse #9 under hood
  195. 02' Honda Civic LX 5-speed problems.
  196. 2003 Honda Civic Problem
  197. K Swap help
  198. o2 sensor questions
  199. aisin timing belt kit
  200. Torque Converter lock up Shutter and Vibration
  201. 04 civic lx question
  202. 01 Civic Intermittent Starting Issue
  203. D17A2 help
  204. 2004 Civic Hybrid Wiring Issue
  205. 2002 Honda Civic Won't Start
  206. driver, rear, and tranny mounts enough?
  207. 02 civic gear grind
  208. 2002 Civic - Alarm Issue
  209. weird vibration at 35-45 mph need help
  210. Just bought 05 civic. Won't start...
  211. 2004 Civic LX Left Headlight Brake Light Out
  212. High Idle & Stuck Gas Pedal After A Few Fixes
  213. Any way to diagnose 2001 Civic CEL without a scanner?
  214. car crapped out electrically now wont start
  215. 195K: Rebuild EX AT or buy a reman?
  216. Fix: 01 civic 5spd hard to get into gear
  217. Shaun's Fun Daily Driver Project (need suggestions)
  218. 2004 Civic Si Sedan - Shuttering/Vibration
  219. 2004 civic Manuel transmission noise
  220. 2002 DX Instrument Cluster Wiring Diagram HELP
  221. Honda Civic DX sputtering
  222. Central locking & Head-light warning signal NOT working AND handbrake light stuck
  223. P0335 crank sensor CEL, replaced sensor/ reset ECU, CEL still on?....
  224. Power door issue.
  225. Car headlights/dash lights flickering + more
  226. 2005 Civic Hybrid with P0139 code
  227. Old School new Technology
  228. 01 civic timing belt
  229. Rev Issues
  230. 2003 civic ex motor swap
  231. 01 civic dx problems HELP?
  232. Car Won't Start
  233. car doesnt reach opr. temp.
  234. What bearings do I need?
  235. right highbeam intermittently will not come on
  236. 2003 Acura 1.7 EL engine swap?
  237. broken lug nut help
  238. 2004 Civic: One High Beam No Power and DRLs Not Working
  239. 2002 EX Cluster swap question
  240. header and exhaust
  241. 2002 honda civic factory tires
  242. Performace mods
  243. 2000 Civic 1.6 into 2001 Vtec 1.7 Civic?
  244. 2001 civic Starts then stalls after timing belt Change. Help!!
  245. 2001 Civic LX D17A swap Immobilizer Issue
  246. Replace front engine mount
  247. 2001 Civic 1.7 Vtec
  248. Simple Question: 12v Socket Amperage?
  249. 2002 civic lx shut off wile driving wont start.
  250. Car won't start, no electronics working
