PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. battery keeps draining
  2. Replacing Axle
  3. a/c acting weird
  4. 2002 civic dash trim
  5. Transmission rebuild kit
  6. exhaust......
  7. Multiplex control unit?
  8. Finally saved up :) lowering my ride :) opinion ?
  9. What DownPipe?
  10. Autolocks issues
  11. HEADLIGHT PROJECTOR !!!!! (USE BALL PROJECTOR)
  12. SOMEBODY GIVE ME IDEA ABOUT BRAKE SYSTEM
  13. Few audio questions before I purchase
  14. DIY Timing belt/tensioner/water pump change
  15. my car wont move when in gear
  16. Headlight Problems.
  17. EM2 factory sideskirts
  18. Will a cat-back exhaust fix P0420?
  19. Help.... V-Tech Problems?? i think
  20. 2004 honda civic lx
  21. 2002 Honda civic front wheel won't come off
  22. PLEASE HELP!! Power door locks not working
  23. B&G S3 coilovers...
  24. help with speedo in 5sp swap
  25. online parts
  26. modding front suspension? adjustable front endlinks?
  27. How do I remove the ECU?
  28. Looking to buy a Civic
  29. Getting my timing belt changed -- questions
  30. 03 civic EX seats
  31. throttle body
  32. wierd winding noise
  33. Ball joint question
  34. Tire size?
  35. 99-00 type r lip
  36. popping noise when turning
  37. VERY STRANGE overheating issue !
  38. Clutch Problem??
  39. Front end conversion
  40. foglights
  41. KYB AGX
  42. Performance chips or tuners
  43. What Does all these engine codes mean? and what is better for what situation?
  44. Battery/Electrical Issue
  45. Those old O2 sensor and catalyst issues
  46. EGR connector removal?
  47. Cooling issue?? 2002 honda civic lx
  48. SRS reset!
  49. Low Rumbling Sound
  50. Water Leak Passenger Door
  51. Problem with suspension Civic copue 03
  52. Will 01-05 Civic EX or SI wheels fit my 2005 HX Civic?
  53. Quick Immobilizer Q
  54. Throwing Code! Need Help!
  55. FG2 seats in EM2
  56. dc5 pigtails, desperate for pigtail connectors !!!
  57. 2005 Civic-Caliper Pin problem
  58. Lower Ball joint help!!!!
  59. Automatic tranny question
  60. Disabling Immobilizer?
  61. Cruise Cable too Tight
  62. More civic cold start issues, What OBDII PC software??
  63. *Help* thew O2 cell
  64. Car OverHeated Now will not Start at all.poss ECU?
  65. help checking out my head
  66. D17a2 - d16v1 to D16y8 İntake Manifold Swap (WARNING! Large photos!)
  67. Dual halo headlight help
  68. 02 Civic Questions (struts and Transmission)
  69. Newbie here!
  70. need a front bumper cover for my 03 4 door where to buy?
  71. RSX seats into 2004 honda civic EX sedan
  72. APEXI N1 Exhaust
  73. Honda Chassis Code I am confused??
  74. Cruise Control Problem
  75. 02 Civic Break Pedal Double Tap
  76. Limp mode?
  77. es Guage cluster
  78. 04 civic lx o2 sensor problem
  79. 01 suspension
  80. 03 coupe lx disc brake change
  81. HX rims on EX
  82. Transmission grinds in second gear
  83. 02 Honda Civic LX Coupe, Water Leak
  84. 2004 civic suspension question
  85. Cylinder Head Plug (seal) for 01-05 Civic
  86. Rear disc-brake conversion on 01 Civic
  87. CV Joint needed
  88. 01 em2 broke down
  89. 02 civic lx suspension question
  90. 16' rota slips...
  91. Finally Made it Over Here
  92. spark + fuel but no start
  93. 2001 Ex suspension problems
  94. WANT TO CHANGE STEERING WHEEL BUT HOW DO I TAKE OUT THE AIR BAG LIGHT OUT
  95. Axle comming out of transmission
  96. My Build Thread
  97. flushed my brakes 3 times but still spongy
  98. 01' rough cold start
  99. 02 civic LX ecu
  100. tensioner question?
  101. The Yellow Matinence Req'd light
  102. can an si exhaust fit an ex sedan?
  103. k series swap
  104. 05 front end conversion
  105. Coupe Exhaust on a Sedan
  106. 2001 honda civic tranny
  107. Moon Roof!! Help! 01 Civic EX
  108. How to change Honda civic 2002 Waterpump
  109. Radio HONDA Civic
  110. help with my 03 d17a2 please?????
  111. do i have to rewire my 01 civic coupe
  112. 2002 civic brake bleed problem
  113. exhaust rubbing on sway bar?
  114. EM2 Noises; Clicking & Whirring?
  115. **ENGINE REMOVAL and INSTALLATION**
  116. CAM, SPRINGS AND RETAINERS. D17a2.
  117. "ABS" and "BRAKE" light on
  118. car still blows cold heat and engine temp rises after fixing everything
  119. 01' civic 4D LX squeek on bumps?
  120. 2004 Civic Questions
  121. Intermittent AC electrical problem
  122. Clicking Noise while in Park
  123. Hid Kit Headlight Problem
  124. Pics Request, Window Visors
  125. a couple NOOB questions
  126. how to switch off check engine light?????
  127. help replaced headers now dash board says check engine
  128. trouble finding parts
  129. Dropline/Eibach/H&R Spring Review/personal experience
  130. HID question
  131. 05 Civic Timing Belt Replacement emergency
  132. cluster bulbs
  133. 2002 civic ex auto, won't go into gear SOMETIMES
  134. 1,2,3,4 misfire and random misfire, help!!
  135. 2001-2005 Honda civic sedan
  136. EM2 Crew HELP!
  137. How many motor/transmission mounts does my car have?
  138. Dealer want's to replace cylinder head per P1361/P1362??
  139. 2004 civic
  140. Help w/ Door Lock Cylinder for 03 Civic Cpe Lx
  141. JDM PARTS .
  142. Spring recommendations?
  143. 2001 Honda Civic LX $1000 to Mod; No mods after that.
  144. will 00 civic mirrors fit on a 02 civic?
  145. what does your k20 run at the track
  146. 2002 Civic LX D17A2 Overheating
  147. Noob question
  148. 2001 Civic EX heater problem
  149. D17a2 intake manifold?
  150. whats been your guys best 1/4 mile on a D17?
  151. Wiring an o2 sensor
  152. 03 honda parking lights don't come on
  153. where to find carbon interior pieces?
  154. Switching oil from 5w-20 to 10w-30
  155. 02 civic wont start
  156. can someone help me please? 03 civic cp 1.7L
  157. RSX Front LCA compatible w/ EM2?
  158. Can a 2001 honda civic 2dr dx fix a 2005 honda civic 2dr VP?
  159. 7th Gen Maintenance Check List (a supplement to the honda maintenance schedule)
  160. D17 Supercharger???
  161. 2001 Civic EX owner.....whats the right FCC ID # for the keyfob?
  162. will the EP3 grill fit a EM
  163. 2nd cylinder misfire in d17a2... not coil packs
  164. OEM engine mount ripped. anyone experience this?
  165. Where is the crank position sensor?
  166. Weird EM2 d17a1 Turbo Issues....
  167. Steering Wheel, what size, 320 350?
  168. AC evaporator failure
  169. 04 Civic EX antifreeze leaks
  170. rear brake change. . . help
  171. 04 civic radio code
  172. ► DIY: Programming Your Keyless Entry Transmitter
  173. HOW TO DO A PROPER INSPECTION?
  174. 01 civic Front lip
  175. is it really possibly my civic 01 getting 19 mpg?!
  176. High Beam question
  177. 2002 civic dies after starting
  178. 2003 Civic Si 2 Door Coupe - heating problems
  179. Looking at 2003 LX
  180. fix door panel covers?
  181. tranny problems
  182. Passenger side power mirror doesn't work
  183. Srs light - bad seat sensor?
  184. Power Windows & Locks in my DX
  185. Seatbelts
  186. Gauge Cluster Wire Color Codes
  187. not sure what to do
  188. Bizzare Tail Light Question
  189. HELP! FRONT DOOR WON'T LOCK!!!
  190. 2001 Civic EX overheating when heater runs
  191. Civic cracked manifold
  192. Power window Problem
  193. Possibly new em2 owner. Help please !
  194. please help!!! computer problem
  195. 10 point 17mm socket for control arms??
  196. Build thread Jamaica
  197. New from Monterrey, Mx.
  198. 2001 civic red emblem
  199. Found a good deal on a 01 civic but it has a bad tranny
  200. 05 civic lip
  201. 01 civc emblem removal
  202. How to change waterpump civic 2002
  203. Squeaking noise...
  204. 2002 honda Civic 1.7 Diesel 3dr
  205. What do i need to install a rsx cluster into a 02 em2 civic
  206. Headgasket or Water Pump???? or Something else :S ???
  207. 02 lx door locks?
  208. 2001 Civic LX starter question??pls help!!
  209. Need help installing Fog Lights!
  210. 2004 civic question
  211. brakes pads noise
  212. Replacement Bodypart Question
  213. Auto Trans | CEL fixed overnight? Weird...
  214. P2000 CEL on '05 HCH
  215. ep3 rear seats in 04-05 sedan?
  216. De-orange EM2 Head lights
  217. 04-05 front and rear 4dr lips question
  218. proportion valve
  219. 2001 Honda Civic LX Exhaust Manifold Problem
  220. Timing belt change for Civic 03
  221. 2005 Civic LX
  222. em2 headlights?
  223. Civic 02 - no heat in air system
  224. front end fire
  225. 2005 civic door locks broken
  226. Blower works then fades and does not work
  227. Tires
  228. 2001 LX 4dr - Instrument Guage Cluster Speedometer
  229. will sedan headlights fit a coupe?
  230. 2005 civic tps or TB
  231. New guy.Need help.
  232. Just got mine...
  233. Diagnosing SRS light on 2001 Civic LX
  234. BAD THINGS ON 01-05 CIVIC
  235. 01 Civic EX OEM Radio Head Unit Reads ERR
  236. 01 civic motor swap q..
  237. New OEM ECU - Can I reprogram it myself?
  238. OEM front and rear lip dimension
  239. Cooling/Heating System Problem - 05 Civic Coupe
  240. Rattle dissappears!
  241. Need help! Replacing crankshaft seal D17A1 (near timing pulley)
  242. Car Starter Bypass
  243. LCA compliance bushings removal anyone know?
  244. i've searched, and found nothing..
  245. New Head Swap Causing Lots of Issues Need Help!!!!!
  246. 05 transmission swap! help!
  247. My horn is not working on my 2002 Honda Civic EX
  248. center console, a/c bulb size
  249. Ran it to some problem
  250. Replace Interior Lights in Civic 2002
