PDA
View Full Version : Honda Civic (2001 - 2005)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Wiring in a few extra cigarette lighter sockets
  2. Random Leak
  3. Exhaust system on my 2003 Honda Civic EM2 Coupe
  4. Weird problem with 03 Honda Civic LX sedan
  5. Check engine light not working and a supposed electrical short.
  6. Major random vibration in steering - mechanics are puzzled
  7. 2003 EX Coupe no fuel after swap
  8. 05 Civic EX Special edition engine swap
  9. 2002 Honda Civic EX coupe
  10. Key Wont Turn Ignition on my Honda Civic Please Hel
  11. 01 civic lx rear turn signals and taillights out
  12. 2001 Civic LX is leaking water onto passenger carpet
  13. 2003 Honda Civic suspension components
  14. 2001 Honda Civic LX Won't Start
  15. Anybody ever put a f22b in a 2005 Honda Civic?
  16. 04 civic vp Loosing all 4 qts
  17. 2003 civic all bank error codes.
  18. 2003 Civic won't start - key chip? Immobilizer? Relay? HELP!
  19. Newly Restored Rims
  20. 01-03 OEM Honda Civic Coupe EM2 Tail Lights EDM
  21. Constructive criticism on my build plan 2001 LX
  22. Smells like GAS
  23. DRL Problem
  24. Trans swap help
  25. wat are the two boxes by the spark plugs called in a 2002 Honda Civic
  26. Puzzling Stiff Clutch Pedal Problem
  27. Aftermarket LCA problem
  28. Radiator / AC Help
  29. Honda civic 2003 check engine light issue
  30. Vibrating, Grinding Feeling from 0-10 mph
  31. Swap out Lx to a JDM D17A ignition issue
  32. EM2 -- Two Questions
  33. 12 Year Battery
  34. 2004 Civic EX power loss @ 4000rpm
  35. Stutter on 1st gear and high RPMs, clutch going bad?
  36. Please Help! Whining noise from oil pan? Oil Pump??
  37. 2004 Honda Civic Coupe Highbeam issue ** plz help
  38. E brake code not working.....
  39. Sticky Clutch Pedal
  40. my brakes depress themselves!
  41. exhaust manifold+converter price range?
  42. Swaping
  43. 04 civic oxygen sensor
  44. Honda Civic 2004 LX Ignition Switch?
  45. Best way to fire up an EX without the key..
  46. Wrong way connect battery terminal
  47. main relay honda 2001 to 2005
  48. Want to do h22 swap
  49. Mystery Valve
  50. Interior Piece Part Number
  51. 2003 Civil Ex need help or pointed into right direction to fixing it
  52. D17a swap from D17a1
  53. Cruise Control out
  54. What is a Special Addition LX.....
  55. 2005 civic starting issue
  56. 2002 Honda Civic ex randomly stalls (auto)
  57. Head gasket
  58. 2001 honda civic clutch problems
  59. 04 civic bmxa trans issue. P0741, P0730, P0700
  60. light scratch on crankshaft rear main seal mating surface
  61. Headlight adjustment
  62. 2004 civic dx engine swap to a vtec engine
  63. 2001 LX ATF cooling hose routing????
  64. Getting new struts, need help putting together a new complete assembly.
  65. 2005 LX, how to check for keyless remote option
  66. 05 airbag light stays on.....
  67. 05 bumper covers.....what works..
  68. Brake Lights and Park Release non functional
  69. tranny mariage
  70. 2005 Civic losing coolent
  71. Torque specs 2003 Honda Civic LX
  72. Swap '01 non-VTEC for VTEC engine
  73. 04 won t crank due to security lock out...
  74. How to reset your Factory honda oem Alarm civic 2001
  75. 2003 Civic EX - JDM transmission issues
  76. No crank
  77. Bolt identification
  78. Overheating while idle
  79. Edm taillights
  80. Motor noises
  81. Can you really do this?
  82. new to 1.7's but a seniored Honda owner questions
  83. how many miles
  84. Accelerator pedal stiff
  85. 03 guage cluster in an 01 civic lx
  86. Inner tie rod tools?
  87. Head gasket questions
  88. fuel gauge sending unit 01 to 05?
  89. 2002 Civic, error code P1457?
  90. Tie Rod Question
  91. Y8 intake manifold swap problems PLEASE HELP
  92. trans question
  93. Recommended spark plugs.
  94. Input shaft bearing replaced- cannot get in gear
  95. Timing belt tensioner
  96. Car died at hard stopping
  97. 2003 Honda Civic Repair Question
  98. 2002 Honda Civic Ex, white smoke from gasket after change valve seal gasket
  99. Another Civic door lock issue
  100. Civic starting problem
  101. Occasional starter noise
  102. So Many Questions...
  103. 2001 Honda Civic EX Coupe AT Ignition Key
  104. Completely stumped 2005 EX Brake Light problem
  105. 2002 to 05 Sedan Rear Tail light conversion/compatability?
  106. Battery warning light only comes on when radiator fan does
  107. Where is this oil leak coming from?
  108. Advice before I install rear camber kit
  109. Coolant Reservoir Bolt Snapped
  110. Keep or Delete?
  111. High Beams Not Working, DRLs Are Working (Canadian Model)
  112. Dim Cluster Lights & Power Locks - Civic 2002 EX
  113. 01 civic coolent fan problem
  114. Can l replace the ECU without replacing the key?
  115. New Civic coupe Value Package
  116. Help! Engine noise
  117. 04 LX rear windows not working
  118. Tail light fuse keeps blowing out !
  119. Weird noise in motor
  120. k24 auto swap
  121. brake line lengths for bending?
  122. Throw out or transmission bearing
  123. ecu question
  124. No reverse after transmission rebuild
  125. 05 Civic overheating and no heat after alternator change
  126. 2002 Honda civic idle problem
  127. 02 civic ecm swap
  128. 03 civic breaking vss gear?
  129. Where does fuse #2 get its power from?
  130. Fuel pump leaking
  131. 2004 Honda Civic ex (fried ecu, alternator problem)
  132. '02 vs '03 starter
  133. Mystery Enkei rims and fitment?
  134. Wheel fitment
  135. 2001 civic lx will not start
  136. 2005 Civic EX ECU pinout
  137. 2002 Honda Civic Stalls Randomly
  138. intermittent no-starts and stalling
  139. 2001 Honda Exhaust system shifted from tow truck
  140. HondaNoob seeks techno garb
  141. URGENT! 05 CIVIC WILL NOT START. ECU?
  142. D17A7 pistons in D17A2 performance benefit?
  143. Can I use a 03 Civic D17A1 engine with no EGR Valve in a 05 Civic LX with EGR Valve?
  144. Door lock part name?
  145. Cel P0122 comes and goes
  146. Transmission won't engage.
  147. Need some help with AC components
  148. 05 Civic DX P0420
  149. RHD Heater Core?
  150. Car overheating--fans not coming on?
  151. Question about 01 Civic hail damage
  152. 04 Civic EX P0963
  153. 2003 Honda Civic Brake Problem??
  154. Manual transmission fail! D17
  155. Axle Replacement - Tip
  156. 2005 Civic no rear brakes
  157. Help with temp guage
  158. New clutch installed in 2002 Honda Civic
  159. 2004 Honda Civic Ex Blower Motor
  160. Weird noise..
  161. EG Truhart suspension fit on my 2001 lx?
  162. Car cranks, does not start.
  163. Apexi VII
  164. Excessive play in steering wheel/clunking noise
  165. What to look for when buying...
  166. 2002 Honda Civic Ex 1.7L cooling fans won't turn on unless fan switch jumped
  167. Moog Springs
  168. 2003 Honda Civic LX overheats when climbing long hills?
  169. 2003 civic alternator wiring helpp
  170. 15x7 3" backspace
  171. em2 lowering question
  172. honda city 2005 Injector No. 1 And 4 both stop working ..
  173. 2004 Honda Civic ex swaps
  174. 2001 Civic LX Lower Control Arm replacement
  175. Squealing noise
  176. Tdc sensor problem
  177. D17A1 Engine for D17A2
  178. Noise from front springs Eibach Pro Kit
  179. Please Help, Can not pin point Oil Leak
  180. 2001 Honda Civic EX - Weird Overheating Issues
  181. 01-05 Civic Aitbag Light keeps coming back
  182. Weird noise
  183. Forced induction d17
  184. I can't find the immo box
  185. CEL code p0141 and p1130
  186. 2002 Civic Engine Noise
  187. Immobilizer System Won't Let Car Start
  188. 2002 Honda Civic Code P1457
  189. Timing Belt Advice Needed
  190. 2004 civic hybrid A/C delete belt
  191. Need help 03 civic non vtec
  192. Car Overheat randomly
  193. 2003 EX: I have oil in my coolant.
  194. '01 Civic revs but does not move when pressing gas
  195. Engine light on for catalytic converter
  196. Weight Distribution post K20 swap in EM2
  197. 2001 civic si po141
  198. help needed figuring out pins on ignition without wires to base off of
  199. D17a2 in 2005 Civic LX help
  200. Clutch
  201. PLEASE HELP! 2005 Honda Civic
  202. White smoke from back of engine after doing 115 on highway?
  203. charging problem
  204. Honda civic 7gen (2005-10) Power steering problems
  205. 01 EX stalling issue
  206. 2005 Honda Civic reciving now power
  207. 2004 Civic - only overheats after long highway run
  208. EMERGENCY - TIMING BELT SLACK????
  209. Dash lights don't work, and stuck on park
  210. No ground to injectors
  211. 04 civic EX - don't have ground to my injectors
  212. Timing issue ??
  213. Rattling at highway speed?
  214. AC compressor cracked
  215. Need advice
  216. 2005 Honda Civic EX - Steering Hissing Sounds
  217. 01 Driver seat compatibility
  218. HELP LEAKING OIL NEED DIY HELP
  219. 2003 EX - Timing Belt Replacment Advice
  220. replaced head gasket and theres white smoke from exhaust manifold
  221. Cooling fan trouble shooting
  222. Car stalling out
  223. 2001 Civic (Overheating)
  224. '01 Civic LX, transmission/engine won't spin
  225. Factory Radio / Activation ??
  226. Aftermarket header problems
  227. Clutch Kit
  228. Civic muffler gasket
  229. 2004 civic sedan lowbeams switch not working?
  230. 05 Honda Civic EX Battery Light stays on.
  231. D16y8 throttle body on D17a2
  232. 01 honda gas smell
  233. MAIN RELAY ON 2001-2005 LOCATION PLEASE HELP
  234. Clutch fluid
  235. eBay parts
  236. Default Manual transmission hard to put in reverse
  237. A/C problem
  238. 2002 civic head gasket
  239. Not all of my dash lights are working
  240. Weird AC Issue!
  241. Highbeam Lights and Indicator Problem
  242. Blower motor Always on full
  243. Skipped time belt??
  244. Rough idle when stopped, almost stalls when AC is on, but....
  245. Headgasket job, car ran fine afterwards. Changed the oil, then code P0340 comes up.
  246. What direction should I turn the crank bolt to get to TDC?
  247. SHORT SHIFTER HELP?!?!?!
  248. Stuck In LIMP MODE!!!!
  249. Mysterious intermittent overheating on 2005 Civic LX
  250. G23 Vs H22
